Wiring ARB solenoids into the factory 2013 Diff switch - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 11-11-2013, 03:23 PM Thread Starter
I am planning on ordering upgraded axles and my Rubi axles will be for sale shortly after Christmas.
I am ordering a Pro Rock 44 and 60 for my JKUR, 2013.
Can I wire the solenoids into the wire leads going to the existing electric lockers? Are the lockers in the Rubi on/off or are they some kind of goofy can bus?
I was hoping to avoid lights on the dash or check engine lights.
Milkman3371 is offline
post #2 of 21 Old 11-11-2013, 05:16 PM
maniacal_rick's Avatar
Correct me if I am wrong but arent they momentary switches? Or are they positionable?
maniacal_rick is offline
post #3 of 21 Old 11-11-2013, 05:21 PM Thread Starter
yeah, i guess they are momentary. I don't mind running ARB switches, i just need to know what to do about the locker lights, CEL and such. I want to have a plan in place.
post #4 of 21 Old 11-11-2013, 05:36 PM
jeeperjkj's Avatar
Most of the programmers on the market that support the JK will turn those lights off. I'm running the TrailDash now and have my sway bar light turned off with it.
Unless you're in love with those electric switches, take a look at manual toggle switches for the lockers. I put them in for both my axles and I love them.
jeeperjkj is offline
post #5 of 21 Old 11-11-2013, 06:49 PM Thread Starter
I have a flash cal. I don't think that will do it will it? What about if I get the upgrade and get the tuner software?
Keep in mind, mine is a 2013 I don't think the flashcal will do over 2010 for locker options
I don't mind using the ARB switches at all. In fact I prefer them.
post #6 of 21 Old 11-11-2013, 09:01 PM
Independent switches will give you more options of running just the front or running them in 2 wd, both high and low speeds. The rubi switches run off the can bus and I have not seen anyone convert them to run abs switches.
post #7 of 21 Old 11-12-2013, 06:33 AM Thread Starter
does anybody know about the lights in a 2013?
post #8 of 21 Old 11-12-2013, 07:18 AM
I splice rocker switches on mine (to factory solenoid) but still have the factory d44. complete control of the locker all the time but without the factory locker, you can probably fool the computer by sending it a signal when the switch is on then the computer think the locker is engaged... but maybe not if it's canbus wired.
jk007 is offline
post #9 of 21 Old 11-12-2013, 08:08 AM
The lights that show the lockers are on work off a plunger in the axle. If you look at the axle there are two sets of wires going to it. Your after market lockers will not have this plunger and the lights will not work. The ARB switches are lighted so you have a visual that they are on.
post #10 of 21 Old 11-12-2013, 12:53 PM Thread Starter
Maybe my question is not clear.
When I remove my axles and install the dynatrac axles with the arbs, I am installing the arb switches.
How do I prevent issues with the existing lights flashing etc? Any check engine lights?
post #11 of 21 Old 11-12-2013, 01:34 PM
jeeperjkj's Avatar
You shouldn't have any issues. When I put in my Rock Jocks w/ ARBs, I never saw the lights again. Personally, I think the light is a little superfluous. I mean, if you can't tell your diff is locked by how it feels when you drive, then maybe you shouldn't be wheeling/driving anything with a locker in it.
post #12 of 21 Old 11-12-2013, 01:54 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
You shouldn't have lights on the dash for the lockers.
Check out the sPOD for a simple wiring solution too. They offer a harness for the ARB wiring as well.
http://www.4x4spod.com/category_s/12.htm
Marcus
RiverCityOffroad is offline
post #13 of 21 Old 11-12-2013, 06:40 PM
jeeperjkj's Avatar
Marcus
ONLY IF you're using the ARB compressor.
post #14 of 21 Old 11-12-2013, 07:57 PM Thread Starter
I hope your just being funny about wheeling something with lockers and worrying about the lights.....and maybe I "shouldn't be wheeling something with lockers"
ALL I WANT TO KNOW IS AM GOING TO GET A CHECK ENGINE LIGHT OR FLASHING LOCKER LIGHTS WHEN I DISCONNECT THE FACTORY LOCKERS. I COULD CARE LESS ABOUT THE LOCKSR LIGHTS.
ITS A 2013 JKU.
This isn't my first rodeo. I recently sold my TJ I had for 13 years with Dynatracs in it.
thank you.
post #15 of 21 Old 11-12-2013, 07:59 PM
No, as it was already stated.
post #16 of 21 Old 11-12-2013, 08:03 PM
jeeperjkj's Avatar
ITS A 2013 JKU.
thank you.
I wasn't saying that YOU shouldn't be wheeling with lockers. Read the bolded part... if you need a light to tell you that your diff is locked, then the statement that follows applies to you. I'm guessing that your experience driving a TJ for 13 years with Dynatracs (assuming they were locked) means you don't fit that bill.
post #17 of 21 Old 11-12-2013, 09:38 PM
ITS A 2013 JKU.
thank you.
If you've ever turned on the lockers in the Rubicon you'll know what he meant. The lights flash and blink and wink and ect but you can't really tell that it's locked until you FEEL it. The lights aren't a solid sign that you are locked or unlocked. I believe that was all he was trying to tell us. Not that you were an idiot or anything of the sort.
You won't have lights on the dash unless you push the locker button on the OE switch. I'm sure they'll blink if you hit them and they aren't connected at the housing/diff.
Marcus
post #18 of 21 Old 11-13-2013, 04:28 AM
bgall's Avatar
You won't have lights on the dash when the lockers are gone. I would second the suggestion for manual toggle valves for the air lockers. I did the toggle switches from powertank and have been very happy. It is nice to know when you are locked/unlocked and hear the "whoosh" when you unlock. As a bonus, it take electricity out of the locker activation.
I have jeeps. I do shit to them.
bgall is offline
post #19 of 21 Old 11-13-2013, 05:27 AM Thread Starter
Ok I took it wrong,
I apologize if you were not being a smart ass.
post #20 of 21 Old 11-13-2013, 01:57 PM
jeeperjkj's Avatar
Ok I took it wrong,
Oh, I WAS being a smart ass. I just wasn't directing it at your personally. I was directing it at the people that rely on those lights...
post #21 of 21 Old 11-13-2013, 02:06 PM
Light is not necessary but it is ok feedback . I can feel the difference. Other than that a switch would be better. I have the trail dash by superchips but I don't like that for when turning it on. There is a screen that comes on to notify you that you turned on your locker. It's annoying.
JeepUpKeep37s is offline
