Arrington Oil Separator - Anyone tried it? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 11-09-2013, 08:42 AM Thread Starter
SoK66's Avatar
Stumble across this a few days ago. Seems to be a way to trap excessive oil vapor passing to the PCV on the 3.8. Comments?
http://www.shopjeep4x4.com/p-2578-du...rformance.aspx
SoK66 is offline
post #2 of 3 Old 11-09-2013, 10:14 AM
gold knight's Avatar
It looks really well thought out and easy install on the JK.
FWIW I see Moroso makes a couple in the $130-160 range.
http://www.jegs.com/i/Moroso/710/85632/10002/-1
Here's a random youtube video that looks promising as well using a $30 BMW 11151705237 oil/air separator. The video is really long and turbo-related but it shows the size of the unit pretty well right up front.
VW Jetta TDI Cyclonic Air/Oil Separator for ALH Engine with lower IC bleed line - YouTube
gold knight is offline
post #3 of 3 Old 11-09-2013, 12:29 PM
this is just a catch can. you can find some cheaper than $200. wouldnt be worth it for me since their mounting location is where my compressor sits. I'd rather spend less and have it mounted else where
MISHIMOTO IS JUNK
chknkatsu is offline
