Jolly Green Giant's Rear bumper build - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 11-08-2013, 09:49 PM Thread Starter
The reason I decided to build instead of buy is the "high clearance" bumpers that are on the market i.e. jcr slimline dagger and ps brawler light leave an big gap between the body and the bumper. The only way it looks good is to paint everything black so it blends. I didn't really want to do that, it'd just be a lot easier to build a bumper.
So at first I was just going to trim the frame rails and leave the crossmember.
Then I decided that wasn't going to give me the angle of the bumper I wanted, so out came the Sawzall.
I made these brackets to slide inside the frame rails, they are .250 3x4 square cut to fit inside the framerails. They should be pretty stout.
dcain is offline
post #2 of 16 Old 11-08-2013, 09:51 PM Thread Starter
Got a little ahead of myself and forgot to get pictures of the next couple of steps. Pretty simple I trimmed the 3/16 thick steel to fit the shape of the tub, then I cut the angle into the brackets, and capped the angle with 2'' and 6'' steel.
I did the same thing for the ends, like a puzzle and pieced it all together.
Here it is all tacked together
All welded up, just needs to be ground, should be fun!
dcain is offline
post #3 of 16 Old 11-08-2013, 09:52 PM Thread Starter
Here's a couple of shots to see how much shorter the bumper is. You can see the tailpipe hanging out past the bottom of the bumper.
Couple of pics of the inside if the bumper
dcain is offline
post #4 of 16 Old 11-08-2013, 09:54 PM
Cavallini03's Avatar
Looks awesome man. Great fab work
Cavallini03 is offline
post #5 of 16 Old 11-08-2013, 09:54 PM Thread Starter
When I first started this project I had 35's and non beadlocks. Since I have a different offset and bigger tires now I decided to notch the bumper so I could tuck the tire closer to the tub. Since I am going to the trouble of making everything tuck up tight there's no reason not to do it right.
So, I might have went a little overboard here, I decided to cut the framerail, and mount the bottom of the bumper flush with the bottom of the framerail.
I replaced the rear crossmember with 2x2 120 wall, and some hitch material. I spaced the 2x2 up 3/16 on the hitch, so it would all be flush across the bottom.
Painted the crossmember with duplicolor bedliner,
Also painted the bumper, but in my haste to install it, I messed it up and will have to respray it.
dcain is offline
post #6 of 16 Old 11-08-2013, 09:55 PM Thread Starter
I have no clue how many hours I have in this. I know it's a lot.
Just enough room.
dcain is offline
post #7 of 16 Old 11-08-2013, 10:28 PM
Abacabb's Avatar
Looks great man. Now just needs some shackle tabs.
2012 Jeep Wrangler - Gecko
3.5" Rock Krawler X Factor
Abacabb is offline
post #8 of 16 Old 11-08-2013, 10:32 PM Thread Starter
Went back and forth on them, I couldn't come up with a way to make it look good, and incorporate the shackle tabs. I decided that if I needed a rear recovery point I'd just use my receiver hitch. Which is all that I had before I built the bumper.
dcain is offline
post #9 of 16 Old 11-09-2013, 03:27 PM
DynoGuy's Avatar
I like it. I been thinking of doing something similar for the rear of mine.
RK 2.5MT w/ Fox remotes. Front Rubicon axle with Terraflex sleeves & upper C gussets & self made axle truss & skids. Rear Rubicon axles with self made skids. Stock 4:10 gears. 37x12.5x17 Nitto Trail Grapple on stock painted wheels. XRC8000Comp winch on stock stubby bumper. Smitty overhead console. Uniden CB w/ 105" whip. DiabloSport Trinity.
ΜΟΛΩΝ ΛΑΒΕ!
DynoGuy is offline
post #10 of 16 Old 11-09-2013, 04:40 PM
damon.l's Avatar
holy fawk, awesome fab work. congrats on making your own stuff! looks killer.
damon.l is offline
post #11 of 16 Old 11-09-2013, 04:52 PM
Stopher's Avatar
Very nice. Glad you took into account the beverage support.
08 "X", RC BB, 33" Duratracs, Coast 1310 front, Hellfires, Woods evap relo.
Stopher is offline
post #12 of 16 Old 11-10-2013, 03:40 PM
lank's Avatar
Very nice work. What'd you use to cut the steel up?
lank is offline
post #13 of 16 Old 11-10-2013, 04:05 PM
manuel's Avatar
Wow that looks great it looks better than a psc bumper
What type of welder did you use?
Mine :Build 2008 Rubicon unlimited black on black
Wife's :2014 All white Rubicon unlimited (mall crawler)
manuel is offline
post #14 of 16 Old 11-10-2013, 06:08 PM Thread Starter
I used a dewalt portaband band saw, with a swag offroad stand. Does really well for my limited space. The only downfall with it is you can only cut 6 inches deep at a time, you have to "chunk" away at it.
dcain is offline
post #15 of 16 Old 11-10-2013, 06:10 PM Thread Starter
Thanks, I am glad everyone seems to like it.
Welder used is a Lincoln 180 mig welder.
dcain is offline
post #16 of 16 Old 11-10-2013, 07:28 PM
Made in the U.S.A.
GenRight Off Road's Avatar
Nice work!
805-584-8635
GenRight Off Road is offline
