axle truss install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 31 Old 11-04-2013, 10:38 PM Thread Starter
FtHoodJK's Avatar
axle truss install
what would one expect to pay getting the axle truss done when lift is installed?
Im just curious. I would prob do it when they did the lift or gears. I assume the lift would be better.
Anyone paid to have this done?
FtHoodJK is offline
post #2 of 31 Old 11-04-2013, 10:41 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
I haven't been quoted, but my recommendation to lighten the cost is to drop the axle, pull the knuckles, replace the OE ball joints at the same time and have it welded off the vehicle. More work, but will make the install easier there by reducing cost. Also, the welder in question will do better work being able to position the housing for full access to the tubes, center, and C's...
JKCTAZ is offline
post #3 of 31 Old 11-04-2013, 11:22 PM
Abacabb's Avatar
I got quotes for $400-600, so I got a buddy to do the truss and c gussets for $150.
So the cheapest and best bet would be to just pull the axle and take it to whomever you get to do it.
2012 Jeep Wrangler - Gecko
3.5" Rock Krawler X Factor
Abacabb is offline
post #4 of 31 Old 11-05-2013, 05:04 AM
I've done full Artec kits for $350 fwiw. That's in my garage, pulling the axle, etc.
post #5 of 31 Old 11-05-2013, 07:49 AM
Abadjeeper's Avatar
We charge $400 for the truss and if you have the whole kit with gussets, control arm skids, and TB mount we charge $600. This includes labor to replace the ball joints also since most of the time you will want to replace them after welding the gussets on.
Abadjeeper is offline
post #6 of 31 Old 11-05-2013, 09:05 AM
M&M's's Avatar
The last Artec full truss/front end set up I did I think I charged like $600.00 for it.
That included pulling the axle, pulling the ball joints and pulling the carrier. I also installed new lower control arm mounts, heavy duty trackbar bracket and a johnny joint housing kit as well as new inner seals and the new ball joints and of course all the gussets that came with the truss kit too then primed and painted it and reinstalled it along with an alignment.
As everyone knows, that's a shit ton of work and takes a hell of a lot of time to complete. Anything less than $600.00 and you are honestly getting a hell of a deal in my opinion. I have done 10 full Artec truss set ups and they are really awesome. And if you do the truss you should also do the ball joints as well as add the johnny joint housing kit. I really feel that those 2 things should always be added to the job no matter what.
I feel like spending $750.00 in labor and consumables for the above mentioned work is more than a fair price when you figure everything involved in doing it. That's my .02 cents anyway...
Originally Posted by van7559
I can bury my pinky in the rear, and just barley feel it, the front is a little easier, but still seems low to me!
I fist fuck life with a nuclear powered pneumatic fuck hammer for 60, 70 hrs a week...
M&M's is offline
post #7 of 31 Old 11-05-2013, 01:08 PM Thread Starter
FtHoodJK's Avatar
good deal, we are close too. I might be giving you guys a call then.
FtHoodJK is offline
post #8 of 31 Old 11-05-2013, 02:15 PM
Man i got a heck of a deal. SBC offroad in gainesville ga did the full truss, c gussets, lca skids on the front and the truss in the rear. Both axles were removed for install and then repainted for 485.00
Redrockjeepin is offline
post #9 of 31 Old 11-05-2013, 05:17 PM
M&M's's Avatar
Yes you did
M&M's is offline
post #10 of 31 Old 11-05-2013, 07:36 PM
JJ housing kit
JJ housing kit What dat ?? What it do ?? and where do you get one ??
tnjeepguy is offline
post #11 of 31 Old 11-05-2013, 07:39 PM
Poly Peformance, replaces the front upper control arm bushings on the housing with Johnny Joints. Currie makes the joints.
post #12 of 31 Old 11-05-2013, 07:47 PM
welder
Thanks.
This would be the time to buy a welder if you were thinking about it !!
Would be mostly paid for after a truss project. Do the C's and housing take special care, rods, etc ??
post #13 of 31 Old 11-05-2013, 07:48 PM
Thanks.
No on special rod/filler, pre and post-heating would be the special care.
But I would certainly not "learn" how to weld on a axle housing to cover paying for the work!
post #14 of 31 Old 11-05-2013, 07:53 PM
M&M's's Avatar
Thanks.
Pre & post heat and cover with blanket to slow cooling waaayyy down. Best thing on cast dif is to use nickel rod or wire if at all possible.
M&M's is offline
post #15 of 31 Old 11-05-2013, 08:04 PM Thread Starter
FtHoodJK's Avatar
lots of great info here guys, thanks
FtHoodJK is offline
post #16 of 31 Old 11-06-2013, 05:23 AM
Are they holding up to 37's in wheeling like in M&M and Goody's signature pics ??
post #17 of 31 Old 11-06-2013, 06:29 AM
Abadjeeper's Avatar
Anytime. We are here to help.
post #18 of 31 Old 11-06-2013, 07:52 AM
I did one for a #5 from Whataburger and another one for a rib-eye and beers.
08jetvette is offline
post #19 of 31 Old 11-06-2013, 08:19 AM
M&M's's Avatar
Add a shrimp kabob and you got a deal...
M&M's is offline
post #20 of 31 Old 11-06-2013, 08:27 AM
M&M's's Avatar
The answer to that question is yes. At this point my weak link is the rear end. I go through rear passenger axleshafts like they were candy. Time to get million dollar rcv's or a 60 or 80 for the rear.
As far as front goes, sleeved, trussed and all gussied up like I am I'd throw 40's on there with no concerns at all except in time the unibearings would toast out but they are cheap and easy to deal with. With 37's it will hold up just fine. I have absolutely no issues whatsoever. Ram assist is a must to keep from busting boxes right and left not to mention steering the damn thing.
M&M's is offline
post #21 of 31 Old 11-06-2013, 09:42 AM
Axemistacampo's Avatar
Well son of a beeeeeeetch! Why are all these awesome labor deals outside of California?! Oh wait, that's because it's shitbox California! I have an Artec truss kit sitting on a shelf in my garage waiting to be installed but I can't pull thte axle and all that jazz because I had some back surgery and crawlin' around under the Jeep is a big "no-no" according to my surgeon.
My old man told me he'd teach me how to weld (finally) after I got all healed up however I agree with above posts, I'm not certain it would be a good idea to learn how to weld on my front axle. Instead, I am going to learn by welding metal legs onto the cat. I imagine it would work, and if not, well, it's a fucking cat.
So, anyone know of a shop in Sacramento that will do my front truss for the crackhead deals that you all seem to be getting?? I'm jealous.
Joe
P.S. I intend to retire to Texas when the time comes, but I'm afraid that they aren't too kind to "outsiders", even though I share the same views as most of Texas!
Axemistacampo is offline
post #22 of 31 Old 11-06-2013, 10:05 AM
shockwaveaz's Avatar
You will fit right in here in Texas provided you like guns and are not a liberal yuppie.
I was quoted $350 labor here in Dallas for the front armor kit to be set up.
Sent from my Galaxy Note 3
shockwaveaz is offline
post #23 of 31 Old 11-06-2013, 10:30 AM
I love Texas, and now their labor rates!! I also love guns, bacon, the death penalty (none of this bitchin' over the "coctail" and how it's "inhumaine"), tits, ass, and the Constitution!
OP, sorry to hijack your thread... back to topic.
I got an Artec truss kit and a shitload of beer. Maybe it's the best time to learn to weld with dad! HAHA!
post #24 of 31 Old 11-06-2013, 12:26 PM Thread Starter
FtHoodJK's Avatar
I can't wait to be back in Texas....
FtHoodJK is offline
post #25 of 31 Old 11-06-2013, 08:15 PM
bnb2010's Avatar
Y'all come on back, you can replace some idiots that have found their way to TX
bnb2010 is offline
