Any LS Swap Guys Question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 11-02-2013, 03:51 PM Thread Starter
Sgo70's Avatar
I've finally gotten everything done and all re geared and wanted to go for a test drive. I hooked up my Aeroforce gauge and it's not coming on, tried another one of my scanners, still no signal. The Jeep one works but not the GM side. I have the two jumpers in as Robbie suggested, they were already there. Anyone have any ideas??
I checked all the breakers on the Motech harness as well. Don't want to call Robbie on his day off.
Thanks,
Sean
Sgo70 is offline
post #2 of 11 Old 11-02-2013, 04:50 PM
MoTech's Avatar
If not running the BCM jump the two tan wires and two brown wires together at the BCM breakout.
Check for power at pin 16 of the DLC with the key on and ground at pins 4 and 5.
If the gauge boots up you should have communication; if not check to be sure the transmission connector is fully seated.
MoTech
725-502-8507
MoTech is offline
post #3 of 11 Old 11-02-2013, 07:19 PM
i know all about that transmission connector problems.
dwn134 is offline
post #4 of 11 Old 11-03-2013, 08:45 AM Thread Starter
Sgo70's Avatar
I'll go out and check everything this morning and post back. Not looking forward to the tranny plug with my belly skid all bolted up.
I took it for a test drive yesterday and it ran pretty good, shifted nicely and everything. It's hard not to get on the gas but I just put new gears in it. Sure sounds cool with the 3" AFE exhaust.
Thanks,
Sean
Sgo70 is offline
post #5 of 11 Old 11-03-2013, 10:16 AM Thread Starter
Sgo70's Avatar
Okay I got power to 16 using ground on both pins 4 and 5???? Gonna check the plug but I think it's in all the way.
I have a white and a purple wire both coming off the main harness under the hood that never hooked up to anything, those don't do anything do they???
Sean
Sgo70 is offline
post #6 of 11 Old 11-03-2013, 10:26 AM Thread Starter
Sgo70's Avatar
The plug is recessed about 3/4" at least.
Sgo70 is offline
post #7 of 11 Old 11-03-2013, 10:59 AM
MoTech's Avatar
Sean
Those are for the new electronics.
MoTech
725-502-8507
MoTech is offline
post #8 of 11 Old 11-03-2013, 04:55 PM Thread Starter
Sgo70's Avatar
Got it all figured out with thanks to Robbie once again. I sure feel bad getting a guy to work on Sunday but that's the kind of customer service he gives.
Sean
Sgo70 is offline
post #9 of 11 Old 11-03-2013, 05:54 PM
greenenvey's Avatar
Yeah robbie is a good guy!
2010 rubicon. 3.5 rk lift. 37,s. 6.2 Ls3.
greenenvey is offline
post #10 of 11 Old 11-04-2013, 05:27 AM
Dont leave me hangimg. I want to know what the problem was.
dwn134 is offline
post #11 of 11 Old 11-04-2013, 09:07 AM Thread Starter
Sgo70's Avatar
I just had to move a couple of wires in the DLC, they weren't lining up with the pins. Easy fix when you got a guy that knows where to look.
Sgo70 is offline
