D60 Castor? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 11-02-2013, 03:41 PM Thread Starter
Good's Avatar
D60 Castor?
On page 9 of this it says to set up the brackets with the pinion up at 1.5 degrees but it's for a 44. Is this the same figure for a 2004 Superduty 60, or anyone know where to find this info? I'm getting ready to tack brackets.
http://synergymfg.com/instructions/PPM-8009-INST.pdf
Good is offline
post #2 of 9 Old 11-03-2013, 10:12 AM
Robbs2008JK's Avatar
Are you going to rotate the inner c's or leave them in stock form? If you are leaving them in stock form them just rotate the housing where your c's are c at 4.5 degrees of caster and run it
My build
Robbs2008JK is offline
post #3 of 9 Old 11-03-2013, 10:49 AM
A JKO DICK
ASSFROW's Avatar
Doesn't he need to consider pinion angle too?
ASSFROW is offline
post #4 of 9 Old 11-03-2013, 11:40 AM
jeepbronco1's Avatar
when I set mine I referenced RK instructions. I set the pinion as they recommend and that put D60 at 6degrees or so. I didnt rotate my C's . I googled ford D60 castor and found the recommend angle. You should be good , mine handles great.
My build
jeepbronco1 is offline
post #5 of 9 Old 11-03-2013, 01:10 PM Thread Starter
Good's Avatar
OK, so 6 degrees measured from a machined surface? Like y'all, I'm going to try to set the link geometry up like stock, as I'm working with a system designed for factory axles.
Way excited!
Good is offline
post #6 of 9 Old 11-03-2013, 01:19 PM
Way excited!
I think there are 2 ways . My 94 had adjustable caster bushing so I had to take a rod and go between the 2 mounts and measure the angle . Also the machined surface should work as well. Good luck ! It will all be worth it !
Sent from AutoGuide.com App
My build
post #7 of 9 Old 11-03-2013, 02:54 PM
VKS Fab
JK Vick's Avatar
Use the machined flat area where the alignment bushing goes into the upper ball joint. She'll be dead on.
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #8 of 9 Old 11-03-2013, 04:57 PM
Yes, but if you arent rotating the inner c's then your pinion angle should be good too. That way you can have 2 +/- degrees of adjustable caster with bushings on the upper ball joint
My build
post #9 of 9 Old 11-03-2013, 05:13 PM Thread Starter
Good's Avatar
yeah, not cutting Cs, just going to match factory specs as closely as possible. Thanks for everyone's help.
Good is offline
