Ring and Pinion Pattern....G2 gears help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 10-29-2013, 03:25 PM Thread Starter
Sgo70's Avatar
I'm installing my new ring and pinion after burning up the outer pinion bearing on my old one. I've got the pinion in with the set up bearings snugged down to require about 15 in/lb of force to turn. I put my ARB locker in with a good preload (dead blow hammer to get it in), I'm pretty confident it's good cause it took three tries to get the backlash set to 5-6 thousandths, and taking it out was about the same as original.
My problem is the wear pattern. It seems perfect on the drive side but quite far back on the heel on the coast side. Not sure if I should adjust it and loose the good drive pattern. Does it look like I need a thicker pinion shim or something else. I put a prybar into my welding glove to give it a good load to get the readings, pretty tough to turn that way.
Any help?????
Thanks,
Sean
Sgo70 is offline
post #2 of 11 Old 10-29-2013, 04:24 PM Thread Starter
Sgo70's Avatar
Ok now I added shims to the carrier to increase backlash to about 8 thousandths and got these patterns:
Should I increase my pinion depth or does that look okay??
Thanks again.
Sgo70 is offline
post #3 of 11 Old 10-29-2013, 04:26 PM
SoK66's Avatar
I liked the first pattern better.
SoK66 is offline
post #4 of 11 Old 10-29-2013, 05:08 PM Thread Starter
Sgo70's Avatar
Yea me too and the backlash was in the lower end too.
I tried adding pinion shims and it went in too deep on the drive and was about the same on coast. I guess I'll go with the first set up unless someone has a better idea.
Thanks,
Sean
Sgo70 is offline
post #5 of 11 Old 10-29-2013, 08:01 PM Thread Starter
Sgo70's Avatar
I went back to the first set up for final assembly. Backlash is consistently 6-7 thousandths and this is my wear pattern, any input before I close it up??
Thanks,
Sean
Sgo70 is offline
post #6 of 11 Old 10-30-2013, 07:52 AM
CUNT
Matti's Avatar
Location: The Land of the Polite, Where shits covered in Ice.
i think it looks ok to me now, but im far from an expert. ( only done 4 installs myself)
Originally Posted by DMadole View Post
As previously mentioned, the key step in this process is saturating those whores in piss.
Originally Posted by maunder View Post
I just gotta say.. When you're being butt hurt by your fudge packer minions.. how do you decide which one gets to pull the pony tail n who's left to cup the balls.. If there is any..
Matti is offline
post #7 of 11 Old 10-30-2013, 09:14 AM
Thanks,
Sean
I think you will be fine with this setting. If I remember correctly as long as you don't go over .010" on backlash it works OK.
scubatech is offline
post #8 of 11 Old 10-30-2013, 05:45 PM Thread Starter
Sgo70's Avatar
Thanks, a little input makes me feel better. I have specs that say 5-8 thous so I figured I wouldn't mess with it. Gonna close it up and do the rears now.
Sean
Sgo70 is offline
post #9 of 11 Old 10-31-2013, 09:46 AM
SoK66's Avatar
Yukon supplies a very good reference guide to setup with their ring & pinion sets. One thing I chuckled about when I read through it, they urge the installer not to obsess over a "perfect" pattern. Looks like you nailed it.
SoK66 is offline
post #10 of 11 Old 10-31-2013, 10:22 AM Thread Starter
Sgo70's Avatar
Thanks, after burning up a pinion bearing on the last I decided to get as perfect as I could. I couldn't imagine a front end lock up on the highway during the winter as being fun. Gonna try to get the rear done so I can finally drive this thing.
Sean
Sgo70 is offline
post #11 of 11 Old 10-31-2013, 10:33 AM
Jeepineer
JKred07's Avatar
Looks good dude. "Tighter" backlash isn't always a good thing. 6-7 should be just fine. You could try to draw the coast in a bit, but your drive pattern looks good to me. I'd run it.
-Mike
JKred07 is offline
