post lift issues..questions - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 10-28-2013, 06:21 PM Thread Starter
Diver's Avatar
I installed the RK 2.5 stock mod in August and have 2 issues I cant figure out:
1: I am getting a creaking from the passenger rear and am unable to pinpoint it
2: When taking some turns, ABS kicks in and feels like there is rubbing when there is no rubbing.
If anyone has experienced this or can provide some insight, I would appreciate it.
Concealed or Open, its how I roll
a true JOAT
وقف الجهاد على الاتصال
Diver is offline
post #2 of 6 Old 10-28-2013, 06:27 PM
bluewave's Avatar
why do you have crazy infidel shooter in your signature?
Sounds like you have a wheel speed sensor not reading right. Spray your rubber bushings with a silicone spray and see if it quits making noises.
Texas Complete Truck Center
5670 S Interstate 35
New Braunfels, Texas
(210) 412-6379
bluewave is offline
post #3 of 6 Old 10-28-2013, 06:31 PM
Did you loosen then torque the control arm brackets? Mine creaked and tightening up the arms eliminated the creak.
nj jk is offline
post #4 of 6 Old 10-28-2013, 06:38 PM Thread Starter
Diver's Avatar
because I am a shooter and a crazy infidel (Blue)
thanks for the quick response. Do I need to go to a shop for the wheel speed sensor?
I dont this so for the control arm brackets, I will have t odouble check
a true JOAT
Diver is offline
post #5 of 6 Old 10-28-2013, 10:36 PM
SoCalJK2010's Avatar
are you getting an ABS light, an ESP/BAS light or both?
Roads?
2010 2dr Rubicon
2.5 Rock Krawler Flex
Riddler Diff Covers
Ace Rock Sliders
Mopar Winch Bumper with Bull Bar
Smittybuilt XRC8Comp
Olympic Rear Rock Bumper
Rock Hard Skids
SoCalJK2010 is offline
post #6 of 6 Old 10-29-2013, 08:27 AM
Did you ever get the vehicle aligned?
Since the stock mod does not come with a lot of components, it should be pretty easy. Make sure the spring is sitting in the spring pocket properly, then go through a sequence of loosening and retightening all the control arm and track bar bolts to make sure their is no pre-stress in the bushings.
RK
