I've about had it!!! Needs fix or am selling - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 10-27-2013, 06:13 PM Thread Starter
EWL
EWL's Avatar
So I have a 2007 2 door rubicon that I have highly modified.
It has
Yukon 5.13 gears
Off road evolution sleeves and c gussets
Rock krawler 3.5" mid arm flex lift
bilstien shocks and steering stabilizer
Rock krawler hd drag link and tie rod
Moog tie rod and drag link ends
Poison spyder front and rear bfh bumpers, diff covers, crusher corners, rocker armor, an rocker knockers, tramp stamp, hood louvre
Warn m8000 winch with synthetic rope
Synergy hd ball joints
Trek armor seat covers
Daystar dash components
Best top trek top nx
Tom woods 1310 drive shafts
37" Goodyear mtr w/ Kevlar
4 ATX slabs beadlocks
MBRP off road exhaust
K&N air
Diablo predator programmer
Smittybilt flat fenders
Viair on board air
Hi-lift jack and accessories
Rugged ridge hi-lift mount
Dupli-color beadliner with Kevlar interior
Lube locker diff gaskets
Tuff Knucks gloves for off road use
Or-fab heavy duty crossmember
Truck litez LED headlights
Rigid industries duallies
However I still have this death wobble that comes and goes. All tierod ends an ball joints are new. The lift has 20,000 miles on it but everything else listed is new. I'm at my wits end.
To top it off it's started making a strange sound that almost sounds like it's coming from the t-case.
Anyone want to help?
EWL
2007 2dr Rubi
37" MTRs
17" Atx Slabs
Poison Spyder everything..
3.5" RK lift....
EWL is offline
post #2 of 12 Old 10-27-2013, 06:19 PM
TXCAJN's Avatar
Loose track bar? Have you followed Planmans "how to" for diagnosis?
2012 JKU Altitude
2014 Grand Cherokee Overland
TXCAJN is offline
post #3 of 12 Old 10-27-2013, 06:23 PM
10jk's Avatar
First thing, put a little bit of Toe-out in the front of that thing, The caster is probably a little jacked up. Now if you adjusted the lower control arms (or upper) to get your caster fair then the angle on your front drive shaft might be a little jacked up and causing the drive-line vibration. So I would take out the front drive shaft or just take it from the axle end and tie it up and see if the vib sound goes away. Swap tires from front to back. These are things I would try. Also are the unit bearings good to go?
2010 JKUR, 4" Pro C., 3/4" f Daystar spacer, 5.38's, EVO sleeve/gusset/custom trussed, Rear Ten Factory axle shafts, 1.5" wheel spacers, Pro C. 17 x 9 wheels, 38 x 14.50 x 17 MTR's, SuperChip FP, no fenders, B&M Tranny cooler, Magnaflow, Fr./ Rr. frame hacked off, HD Balls
29,000 miles as of 12/13/14
10jk is offline
post #4 of 12 Old 10-27-2013, 06:27 PM Thread Starter
EWL
EWL's Avatar
Havent seen plan mans how to. Do you have a link to it?
EWL
2007 2dr Rubi
37" MTRs
17" Atx Slabs
3.5" RK lift....
EWL is offline
post #5 of 12 Old 10-27-2013, 06:29 PM Thread Starter
EWL
EWL's Avatar
It's only got the adjustable lower control arms. It drove great after I did the lift 20k miles ago and never had an issue until recntly. All bearings are new in both axels
EWL
2007 2dr Rubi
37" MTRs
17" Atx Slabs
3.5" RK lift....
EWL is offline
post #6 of 12 Old 10-27-2013, 06:36 PM
10jk's Avatar
Ok, then what could have changed? Tire wear, wheel balance, wheel bent, track bar hole or mount hole wallowed out or bolt came loose. Or, control arm bolts came loose, or bushings worn?????? Many things up front. I usually take a day out and check and re-torque everything, and when I say everything, I mean everything up front.
10jk is offline
post #7 of 12 Old 10-27-2013, 06:55 PM
Cavallini03's Avatar
https://www.jkowners.com/forum/showthread.php?t=30723
Planmans write-up. Should answer most of your questions
Cavallini03 is offline
post #8 of 12 Old 10-27-2013, 08:02 PM
spookylynx's Avatar
I thought the JK was supposed to have Toe-IN? I've got mine set at about 1/8" toed in....
spookylynx is offline
post #9 of 12 Old 10-27-2013, 10:02 PM
planman's Avatar
Correct.
People toe out when they have worn ball joints to band aid it until they replace them.
planman is offline
post #10 of 12 Old 10-27-2013, 11:04 PM
JKO Dickhead
Asmmns's Avatar
^ this
^this will fix it !
reading this thread prior to ever experiencing death wobble I knew what the usual culprit was. After getting it after a wheeling trip I was able to climb under it and diagnose it in a parking lot in about five minutes. - track bar holes ovaled out - ordered an artec bracket for the axle and a poly frame side bracket, in the time it took me to get to them it happened a handful of times, resulting in new joints for the track bar being needed.
sometimes its as simple as retourqing the track bar, but willing to bet your bolt holes are ovaled out at the track bar, and there is play -
cliffs - get someone to move the steering wheel back and forth while looking at your trackbar, and you will most likely see the movement in the joint area prior to the wheels turning.
__________________
CURE SMA !
Asmmns is offline
post #11 of 12 Old 10-28-2013, 06:56 AM
10jk is right about the drive shaft. My 2011 just started making a squeaking sound. The girlfriend was driving it and told me about it - and from here description I couldn't understand what it was. Finally when I got back on the east coast and drove it, heard it, had her drive slow and I followed listening for the sound and I was 90% sure it was my front drive shaft (ds). Posting in a few groups they all concurred with my thesis so once I get it back from the dealership today (they couldn't tell where it came from - never going back to this dealership) i'm taking it to a shop and have them look at my ujoints on the front ds. Good way to tell is to remove your front ds and drive - if the sound goes away there's the issue. hope this helps.
Mathie84 is offline
post #12 of 12 Old 10-28-2013, 07:20 AM
Here is a link to our video as well. If you would like, give us a shout and we will try to walk you through some things.
https://www.youtube.com/watch?v=iTpVF0jgF8o
Or you can take a road trip up to us and we will probably find it in about 5 minutes or less.
RK
