Axle Swap Electronics - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 10-26-2013, 08:27 AM Thread Starter
In all the axle swap talk I see lots of concern of keeping the tone rings etc and some folks that have evidently not used them.
If you swap axles and disreguard any ABS sensors what happens ??
Can the computer be fooled or disabled ??
If you swap in an LS and LS computer (Motech) does that change things ??
tnjeepguy is offline
post #2 of 9 Old 10-26-2013, 08:57 AM
TCdawg's Avatar
Without tone rings...no speedo, no odo, no abs or traction control. Lights on the dash
VKS fab has made some tone rings for a 14 bolt, Vick could probably make you some.
TC
TCdawg is offline
post #3 of 9 Old 10-26-2013, 09:15 AM Thread Starter
Can you just use only the front or rear ??
post #4 of 9 Old 10-26-2013, 11:26 AM
TCdawg's Avatar
I'm pretty sure you need all four. What you could do is put tone rings on one axle and run two sensors to each tone ring. In theory, that would work.
TC
TCdawg is offline
post #5 of 9 Old 10-26-2013, 04:28 PM
CashMoney's Avatar
You need at least the rear for the speedo to work correctly (I think only 1 rear will work but I cant remember) and you will need all 4 of them to make all the dash lights go off. There's a bunch of threads with good info on here and really everyone's figured out all the leg work so there's no real reason not to run them now that I can see
CashMoney is offline
post #6 of 9 Old 11-02-2013, 09:19 AM Thread Starter
Tone rings
In talking with others found out you can splice in the wires from the front tone rings to the rear ones and hav the computer think there are four. Seems to work just fine ?? Others experience ??
Thinking of an F9 front with hubs, 5 on 5.5 37's max but more strength than the 44 and unit bearing ?? So no tone rings in the front.
post #7 of 9 Old 12-24-2013, 07:56 AM
On a LSx swap, why are people not using the VSS output on the ECM/TCM?
tunedportcj5 is offline
post #8 of 9 Old 12-24-2013, 05:37 PM
51%
I was doing some testing on mine, and with the rear sensor unplugged, no speedo and the auto trans won't even shift gears, so apparently the PCM is using those to calculate shift points.
14 JKU 4-1/2 AEV Dualsport RS, 37" KM2 on Pintlers, PR44, 4.88, ARBs .... under construction
51% is offline
post #9 of 9 Old 12-25-2013, 12:30 PM
jeepbronco1's Avatar
I put 2 rings per side in the rear. Works perfectly no lights on my dash. Splicing wouldnt work for me... I tried all on 1 sensor and no bueno and then tried 2 per sensor and wouldnt work either. If some one gets it to work Id like to how they did it....
My build
jeepbronco1 is offline
