Drill Out RK Rear Lower Control Arms? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 29 Old 10-18-2013, 09:21 PM Thread Starter
I have a 2012 JK with a 3.5 X-factor lift from RK. I just put on some Synergy integrated rear lower shock mount and skid. These installed great but they use 9/16" bolts. The problem is the RK arms are a 14mm joint.
What's better, drill out the RK joint (How?) or just get some 10.9 Grade 14mm bolts and hope they aren't too loose in the Synergy brackets? The 9/16" bolt already fits through the axle bracket ironically.
sdr0303 is offline
post #2 of 29 Old 10-18-2013, 09:38 PM
thaduke2003's Avatar
I would run the smaller bolts and put a bushing in there WAAAAAY before I'd dream of boring out the control arms. Think about it- what makes things stronger- adding metal, or taking it away? Now, think about it as a structural, load-bearing point, like a control arm mount. Yeah... bushings look PRETTY good, don't they? Mark W.
thaduke2003 is offline
post #3 of 29 Old 10-18-2013, 10:12 PM
Cavallini03's Avatar
Wouldn't welding some washers to the Synergy bracket work too?
If so I can imagine it to be easier than trying to drill out the control arm.
Cavallini03 is offline
post #4 of 29 Old 10-18-2013, 10:34 PM
Abadjeeper's Avatar
I bet 9/16 bolts fit unless the RK arms are brand new. Even then all it took was a quick drill throughout them for me. You aren't taking much material off.
Abadjeeper is offline
post #5 of 29 Old 10-18-2013, 10:39 PM
not to mention if you drill out the RK control arms, and they snap on the trail, i'm 99% sure they will not replace them because you modified their joint. I'd weld washers to the brackets. 2 washers each side should work.
Mathie84 is offline
post #6 of 29 Old 10-19-2013, 02:24 AM
OH9JK's Avatar
I thought RK had started shipping joints that accepted 9/16" hardware?
OH9JK is offline
post #7 of 29 Old 10-19-2013, 04:15 AM
bgall's Avatar
If they are the older RK joints do NOT open them up to 9/16. While you are not removing a lot of material you are removing the hardened material. RK advises against opening up their joints to 9/16 for just this reason. There is a thread here where it is discussed. I would weld washers to the brackets or see if RK offers 9/16 joints.
I have jeeps. I do shit to them.
bgall is offline
post #8 of 29 Old 10-19-2013, 06:27 AM
I've opened a few arms up before for people to run 9/16". It is a very small number, ~0.0114" approximately.
post #9 of 29 Old 10-19-2013, 01:27 PM
i find it strange that RK uses 14mm in stead of 9/16. especially when stock bolt holes are 9/16
MISHIMOTO IS JUNK
chknkatsu is offline
post #10 of 29 Old 10-19-2013, 02:05 PM
Ringer's Avatar
They do it because stock bolts are 14mm. I have reamed a few sets out as well. No issues.
Ringer is offline
post #11 of 29 Old 10-19-2013, 04:17 PM
No they aren't..OEM is 14mm.
post #12 of 29 Old 10-19-2013, 06:07 PM
bgall's Avatar
I had issues with mine after drilling them out. Your joints, your call.
bgall is offline
post #13 of 29 Old 10-19-2013, 06:28 PM
kjeeper10's Avatar
RK's new joint is 9/16
Just ream the 14mm joints ?
I wouldn't go drilling them. Id use a Bridgeport at work.
Sent from AutoGuide.com App
kjeeper10 is offline
post #14 of 29 Old 10-19-2013, 07:37 PM
nicholsmf's Avatar
What issues did you have?
2010 JK - Rock Krawler 2.5 Max Travel Kit - Fox 2.0 IFP Shocks - 37" Nitto Trail Grapplers - Genright Aluminum Tire Carrier - Poison Spyder Front and Rear BFH Bumpers - Warn M8000 - VKS Fab Sliders - Offroad Evolution Full Skids - Teraflex Sleeves - ARTEC Truss - EVO C Gussets - Synergy Bumpstops - JKS Control Arm Skids - Rigid 10" E-Series Light Bar and SRM Backup Lights - ARB Compressor w/ 5 Gallon Viair Tank - Offroad Evolution Half Doors
nicholsmf is offline
post #15 of 29 Old 10-19-2013, 09:28 PM
spookylynx's Avatar
I drilled mine out. Use a drill press, TAKE YOUR TIME!!! make sure they are lined up and straight in the press, and...... TAKE YOUR TIME! did it two years ago and it's been no issue at all. The size difference is so small, you are really just shaving them instead of "drilling" a larger hole.
spookylynx is offline
post #16 of 29 Old 10-20-2013, 06:54 PM
DiscoBayJoe's Avatar
Send a message via Yahoo to DiscoBayJoe
I just upgraded from the old RK joints to the new. I'm now able to use 9/16ths hardware.
2008 JKUR 3.5" Frankenlift : RK/Artec/Synergy/Reid/Currie/PSC - Spyder'd Out - 35" MTR/K's on Spyderlocks - BinksFab Tailgate
DiscoBayJoe is offline
post #17 of 29 Old 10-20-2013, 07:28 PM
bgall's Avatar
Joint was weakened and bent. To RK's credit, they replaced them since one of their reps had said it would work. They came back and said they did not advise doing it. If you do it on a press with a good bit and cutting fluid you may be fine. I would not suggest it though. Ask RK how deep the hardened material goes.
bgall is offline
post #18 of 29 Old 10-20-2013, 09:08 PM
PIG
PIG's Avatar
What bent, the ball?
PIG is offline
post #19 of 29 Old 10-21-2013, 04:08 AM
bgall's Avatar
The cylinder/ball portion bent.
bgall is offline
post #20 of 29 Old 10-21-2013, 07:32 AM
The flanges on the balls will be thin and could possibly fail with the old balls. The new Pro series joints are designed around the possibility of people upgrading the 9/16 hardware so it should not be an issue with the new ones! That was one of the reasons for the upgrade, besides more available misalignment, improved dampening and the fact that the new ones just plain old looked better!
RK
post #21 of 29 Old 10-21-2013, 08:51 AM
spedly's Avatar
.011" less material is going to cause a failure? if that was the case I don't think I would want to run that joint in the first place.
spedly is offline
post #22 of 29 Old 10-21-2013, 11:15 AM
You are taking out the case hardened surface on the inside leaving only ductile material. Keep that in mind. The new joints are designed around this anyway.
RK
post #23 of 29 Old 10-21-2013, 12:09 PM
AllJumpStyle's Avatar
OEM bolt size is 14mm. OEM hole size is about 9/16". There is a bit of slop with the stock bolts and is why most manufacturers use 9/16" bolts.
Chris Steimle
Product Manager
AllJumpStyle is offline
post #24 of 29 Old 10-21-2013, 12:24 PM
lank's Avatar
RK
I don't understand why the inside of the bolt hole needs a hardened surface. As long it's installed properly, that part of the joint should be clamped in place by a bolt and shouldn't move/rotate relative to the bolt, right? No movement => no friction => no wear. Case hardening doesn't affect anything structurally, it's just for impact/wear resistance.
The part is case hardened so that the outside of the ball can resist wear... the inside of the bolt hole shouldn't matter, right?
lank is offline
post #25 of 29 Old 10-21-2013, 01:58 PM Thread Starter
So I drilled them out last night with no real issues. The vice slightly marred the finish on the edge of the cylinder, but other than that it went fine. It barely took any real material off at all. I'm struggling to see how that might weaken the joint.
I went very slow with a sharp, new bit and used a lot of cutting fluid. The new 9/16" bolts fit snug with no slop.
If there are problems I'll order another set of joints that fit 9/16" from RK but otherwise it seemed to work fine.
sdr0303 is offline
