Which Tatton Shaft? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 10-18-2013, 07:53 PM Thread Starter
Which Tatton Shaft?
Apparently there is a high speed cv front shaft as well as a Std. cv with u joints. This is my daily driver and I live in Florida where there is many more highways and malls than rocks and fun. does anyone have experience with either of these two or that can tell me the difference (other than the $75)
I'm looking at purchasing later tonight or tomorrow based upon replies. Thank you for your help.
Standard shaft
"High Speed" shaft
2009, 2 Door X, Rancho 4" Sport Lift w/ 9000xl shocks, 35" Firestone Destination MTR on Spidertrax spacers Bulldog Front Bumper w/XRC8 Winch, LoD Rear Bumper, FinishLineWest Rock Sliders, 5.13 G2's, ARB Rear diff cover, LineX'd tub, JL Clean Sweep, JL 900/5 Amp, JL C5 components in front, JL Marine MX-770's in soundbar, JL FS-110 Marine sub, Tuffy security deck, HID's in Cibie's, Piaa 520s
DanNEBTD is offline
post #2 of 12 Old 10-19-2013, 11:37 AM
SoK66's Avatar
I don't know what year & model JK you have, but looking them over I'd be tempted to with the "high speed" shaft as He retains the rzeppa joint at the t-case. It appears from the photo he's developed a boot that will survive high misalignment on a lifted rig.
JMHO, of course, but the rzeppa joints on a JK are a far better design than the old fashioned u-joints we all use with our aftermarket shafts. They're stronger and far smoother. I knew it was just a matter of time before someone solved the boot problem on the front shaft and developed the rzeppas into a better JK shaft.
Only warning I'd give you regards Tatton shafts. Back in Spring '09 I got a set of them with my first lift as a package deal. Problems with both. The front was off-center about .050" and out of balance. The rear one has CV issues, the "H" is screwed up and it has a binding center ball. I had Off Again in Farmington correct the front one. I finally threw up my hands and ordered a set of Tom Woods shafts as replacements and have been good to go. I kept the Tattons as spares. YMMV, of course.
SoK66 is offline
post #3 of 12 Old 10-19-2013, 12:26 PM Thread Starter
Thanks for the reply, I will consider your advice but will probably still got with Tatton for the spicer ujoints and overall satisfaction . . though his grammer does concern me a little. If I have any issues I will probably go TW as well but I like what I see/hear w/ Tatton (plus all American which weighs in a little). I will probably fork over the extra $75 as well . . to do it tight the first time.
FTR I have a 2009 2dr X w/ 4" Rancho sport lift.
DanNEBTD is offline
post #4 of 12 Old 10-19-2013, 09:36 PM
spookylynx's Avatar
I run the standard Tatton shaft with the traditional double cardin. 37s 5.5 LA and its my daily driver. you do have to be vigilant on greasing every 3000 miles or so, and use a grease with a high drop point.
Also, I did blow a cardin due to my own inexperience when I first got it, used cheap grease and it dried out. Excellent customer service, he fixed it with no charge other than me shipping it back despite the fact that it was my fault. so that goes a long way too.
spookylynx is offline
post #5 of 12 Old 10-20-2013, 01:18 AM
kjeeper10's Avatar
I run a front Adams and have 0 problems. It does retain the yoke and flange at the diff.
What grease do you recommend ?
Sent from AutoGuide.com App
kjeeper10 is offline
post #6 of 12 Old 10-20-2013, 09:56 AM
A JKO DICK
ASSFROW's Avatar
I've searched and can't find any info on the Tatton/Rzeppa shaft. Does anyone have a link to a pic and more info?
ASSFROW is offline
post #7 of 12 Old 10-20-2013, 10:06 AM
Rolltidejk's Avatar
How long did you have yours and who did you talk with? Mine decided to take a shit yesterday and have had it on less than. A year and less than 5k miles. I'm leaning towards the Woods DS, but if I can get this one fixed it'll help me for the mean time.
Rolltidejk is offline
post #8 of 12 Old 10-20-2013, 10:12 AM Thread Starter
This is the "high speed" shaft I was referring to. I cannot find any information on it either. I offered him $800 for both this and the front shaft shipped . . Still waiting on a reply.
DanNEBTD is offline
post #9 of 12 Old 10-20-2013, 06:07 PM
spookylynx's Avatar
I've had good luck with Lucas Red. I think the drop point is above 500degrees, so it's pretty sticky.
post #10 of 12 Old 10-21-2013, 04:28 AM
kjeeper10's Avatar
Hmm. I would like to know how much of an angle the Cv will take. Assuming a rzeppa joint Is a rzeppa joint and there would be no difference then stock ?
post #11 of 12 Old 10-21-2013, 12:55 PM
SoK66's Avatar
I use the Lucas red as well. Recommend it.
SoK66 is offline
post #12 of 12 Old 10-21-2013, 02:41 PM
kjeeper10's Avatar
Lucas it is .... Thanks
