6.1 Hemi conversion error code. Help! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 10-18-2013, 11:35 AM Thread Starter
I have a 2007 JK unlimited w/ a 6.1L Hemi conversion. It has ran fine up until two weeks ago when it threw an error code. It started running rough and smelled very rich. The code was p0202. Which is #2 cylinder injected problem or an open ground in the wire. I have switched the injectors and the code has stayed the same. I can hear the injectors ticking so I don't think it's the injectors. Not really sure how to check all the wiring. The conversion is from Burnsville Offroad. Any suggestions would be helpful. Thanks
Lift6in is offline
post #2 of 12 Old 10-18-2013, 03:31 PM
SSrubi07's Avatar
Give Burnsville a call?
07 Sahara Unlimited, D44s Supercharged LS on 37s....
SSrubi07 is offline
post #3 of 12 Old 10-19-2013, 03:34 PM
MGV
Check your coil connections to cylinder / plugs...they can. They can come loose - happened to me on my 5.7 hemi...same code - easy fix
MGV is offline
post #4 of 12 Old 10-19-2013, 07:36 PM Thread Starter
I gave Burnsville a call and they weren't much help at all.
Lift6in is offline
post #5 of 12 Old 10-19-2013, 07:38 PM Thread Starter
Thanks. I will try that. If it was pulling the same code, was it the cool pack from that cylinder or another one? I have taken that cool pack off ad out it back in and nothing has changed. Could it be a spark plug issue?
Lift6in is offline
post #6 of 12 Old 10-19-2013, 07:40 PM Thread Starter
How can u make sure the coil oaks are connecting well? All u can do is push the coil packs down onto the spark plugs and tighten bolts. Can u pull on the springs inside to help make the connection better? Just wondering.
Lift6in is offline
post #7 of 12 Old 10-22-2013, 07:01 PM
SoK66's Avatar
One would think for what a Burnsville Hemi conversion costs they'd be more helpful. It's feedback like that that keeps me from considering them.
SoK66 is offline
post #8 of 12 Old 10-22-2013, 07:21 PM
Slow and Low
Co4Lo's Avatar
Can you elaborate on this?
Did you try calling Dakota Customs and asking for Dan?
http://dakota-customs.com/
Co4Lo is offline
post #9 of 12 Old 10-22-2013, 08:41 PM
Mr Google Says
What does that mean?P0202 means that the PCM detected a fault in the injector or the wiring to the injector. It monitors the injector and when the injector is activated, the PCM expects to see the voltage pulled "low" or close to zero. When the injector is switched off, the PCM expects to see a voltage that is close to battery voltage or "high". If it doesn't see the expected voltage the PCM will set this code. The PCM also monitors resitance in the circuit. If the resistance is excessively low or high it will set this code.
Potential SymptomsThe symptoms for this code will likely be a misfire and a rough running engine. Poor acceleration. The MIL will also be illuminated.
CausesThe causes of a P0202 engine light code could be any of the following:
Bad injector. This is usually the cause of this code but doesn't rule out the possibility of one of the other causes
Open in the wiring to the injector
Short in the wiring to the injector
Bad PCM
Possible SolutionsFirst, using a DVOM check the resistance of the injector. If it isn't within specs, then replace the injector.
Check for voltage at the fuel injector connector. It should have 10 volts or more.
Visually check the connector for damage or broken wires.
Visually check the injector for damage.
If you have access to an injector tester, activate the injector and see if it operates. If the injector operates, then you likely have either an open in the wiring, or a blocked injector. If you do not have access to a tester, swap the injector with another one and see if the code changes. If the code changes, then change the injector.
At the PCM, remove the driver wire from the PCM connector and Ground the wire. (Make sure you have the correct wire. If you're not sure, do not attempt) The injector should activate
Replace the injector
JK07 is offline
post #10 of 12 Old 10-23-2013, 07:06 AM Thread Starter
Yes. That is who I talked to. He is w/ Dakota Customs now. He says he has never had a PCM of his come back bad. As for the other post, if someone is on the fence to use them, all I can say right now is I talked to the guy I bought this jeep from. He has never had the engine light come on and has never had a problem w/ the set up at all. He drove it from southern Ohio to Florida and back and has had it in high altitudes in Colorado trail riding. No over heating or anything. I'm just hoping this is a dumb problem that I haven't been able to track down just yet. I'm going today to have the computer read by a more capable computer that my hand held code reader. We will see what that and a mechanic w/ more electrical knowledge comes up with. With any luck I will let you know what the problem is. Thanks for the input.
Lift6in is offline
post #11 of 12 Old 10-31-2013, 08:57 PM Thread Starter
The fix
Well, after a lot if research, taking the jeep to a friends shop with a good scan tool here's what I have found. Unrealated but the battery should have been putting out 750 cold cranking Amos and was only putting out 150. Got a new battery. I rented a nous light tester to check if I had a pulse going to the #2 cylinder and it was just a constant light which I was told either u have a wire grounding somewhere or it's grounded in the PCM and your computer is shot. However I was able to get a pulse while moving the wire harness so I took the Harness apart and started moving every wire. I noticed a little running on the harness on the fuel rail but wires didnt look bad. I never pin pointed the problem like I would have liked to but I rewraped the worn area and I now cannot replicated the problem. I've tried everything to get it to do it again and nothing so I'm back in business. Thanks for all the help.
Lift6in is offline
post #12 of 12 Old 11-03-2013, 07:33 AM
jss
jss's Avatar
You might need to check the wiring gauge, it might be to small?
["jeep speed shop The GuineaPig Build"]
VVT Truck Hemi Conversions
The ONLY CARB LEGAL JEEP ENGINE CONVERSION
7911 Redwood Dr, Cotati, Ca. 94931
707-338-3154
jss is offline
