How can I recognize RCV shafts in the rear ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 10-14-2013, 10:22 PM Thread Starter
This might be a stupid question, but how can I recognize RCV shafts on the rear axle ?
I got a JK offered, which should have RCV´s in front and rear. The front ones have the orange covers, so this ones are there.
But how can I recognize, whether the rear axle also has RCV shafts, without dismounting anything .
Thanks in advance for your answer,
M.
Traviso is offline
post #2 of 9 Old 10-15-2013, 04:39 AM
kjeeper10's Avatar
You have to remove the tire and drum. I don't see any other way ?
Sent from AutoGuide.com App
kjeeper10 is offline
post #3 of 9 Old 10-15-2013, 05:17 AM
May be able to pop a center cap off a wheel and see if there is a sticker in the hub of the rear axle..if RCV does that..
post #4 of 9 Old 10-15-2013, 06:38 AM
Abadjeeper's Avatar
The part number is on the flange. You will have to remove the caliper and rotor to see it. Might be easier to see if the owner has a receipt for them.
Abadjeeper is offline
post #5 of 9 Old 10-16-2013, 12:48 PM Thread Starter
Thanks for the answers. It seems, I have to see the receipt and trust.
Traviso is offline
post #6 of 9 Old 10-16-2013, 07:37 PM
spookylynx's Avatar
I have RCV rears and unfortunately there were no visible markings on mine (or that I noticed).
BUT..... the wheel studs were bolts that threaded through the mating surface so look there. If they are pressed in then probably not RCV
Hope that helps
spookylynx is offline
post #7 of 9 Old 10-16-2013, 08:05 PM
TCdawg's Avatar
Hope that helps
A number of aftermarket chromo axle shafts use screw in lugs
TC
TCdawg is offline
post #8 of 9 Old 10-16-2013, 08:12 PM
spookylynx's Avatar
I figured, but it's a start..
post #9 of 9 Old 10-16-2013, 09:42 PM Thread Starter
Hope that helps
Thanks. Thats a good start for me.
Traviso is offline
