JKU 1 Ton project - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 10-14-2013, 01:57 PM Thread Starter
JKU 1 Ton project
So I told myself I would wait until I demolished my d30 and d44 but I got antsy and couldn't wait any longer. I bought a set of d60's... Front from a 86 F350 HP kingpin style 60, and a FF rear 60 to match. No 14bolt for me, just a little too big and I think ill be ok with 35splines and chromos... So as I said plan as of now is 5.13's, detroits, and 35 spline chromos... Here are a few of my clean up pictures! Cheers!
Talliwood is offline
post #2 of 19 Old 10-14-2013, 01:59 PM Thread Starter
Ok maybe not... Mobile app says I'm over data?
post #3 of 19 Old 10-14-2013, 02:04 PM Thread Starter
Over Quota?
post #4 of 19 Old 10-16-2013, 12:26 PM Thread Starter
Name:  ImageUploadedByAG Free1381948017.219215.jpg
post #5 of 19 Old 10-16-2013, 12:28 PM Thread Starter
Name:  ImageUploadedByAG Free1381948039.435861.jpg
Rear 60 cleaned up, shout out to RUFF STUFF for the diff covers and disk brake conversions, I plan on using them for all the brackets and etc.
post #6 of 19 Old 10-16-2013, 12:28 PM Thread Starter
post #7 of 19 Old 10-16-2013, 12:29 PM Thread Starter
post #8 of 19 Old 10-16-2013, 12:30 PM Thread Starter
post #9 of 19 Old 10-16-2013, 12:34 PM Thread Starter
Name:  ImageUploadedByAG Free1381948267.402768.jpg
Cheers fellas, I'm taking the jeep out today for a little hunt/camping trip! Be back in a few. When I start putting it together there will be pictures to follow...
PS I am planning on running 5.13's (have them in current stock axles and like them) but am debating jumping to 5.38 or 5.86 because I have a non rubi T-case??? Anybody running 5.38 w/40's???? Still plan on driving this thing around town occasionally....
post #10 of 19 Old 10-16-2013, 12:39 PM
mschaffer66's Avatar
I've got 5.38's running 40's and a stock 2.7 tcase. I really wish I had more gear for better control crawling things. I also wish I had more ass to get it moving and allow overdrive at 45+mph speeds.
Other than that I really don't have any issues with the 5.38's. I sure as hell wouldn't go higher though.
2007 Sahara Unlimited - Dana 60/14 Bolt - 5.38's with ARBs - 40x13.50x17 Goodyear MTRs - 3.5" Rock Krawler X Factor Plus - Rubi Rock Rails - XRC 10,000lb Winch
mschaffer66 is offline
post #11 of 19 Old 10-16-2013, 12:42 PM Thread Starter
thats exactly where i am at... plus i have a manual transmission so that helps a little.... haha thanks
post #12 of 19 Old 10-16-2013, 01:12 PM
VKS Fab
JK Vick's Avatar
I run 60/14 bolt with 5.38's, 40's, rubi case and a 6 speed. It's good around town and on the freeway (75mph at 3000rpm). On the rocks I wish it was lower but I'll be going to a 4 speed atlas soon.
Good luck with your build, I'll be watching.
Sent from AutoGuide.com App
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #13 of 19 Old 10-16-2013, 02:53 PM
jeepbronco1's Avatar
Cheers ! I'm subscribed !
My build
jeepbronco1 is offline
post #14 of 19 Old 10-17-2013, 07:10 PM
voodoo206's Avatar
I'm on 42s with 538 & it's ok on street & fine on trail. So my .02 is 538 &
40s should make you happy.
voodoo206 is offline
post #15 of 19 Old 10-27-2013, 09:58 PM Thread Starter
Sorry for slow process but finally got upper and lower control arm brackets, track bar mount and coil buckets in for front axle. It is gonna be a really tight squeeze fitting everything on the drivers side (86 F350).. Anybody have any pointers or tricks? I'm not going to cut the housing...
post #16 of 19 Old 10-27-2013, 10:19 PM
Why dont you want to trim the housing? If you were running coilovers it would be a little easier. How much room is there between the inner c and the housing?
"I used CAD. Cardboard aided design... "
HOT_DAMN is offline
post #17 of 19 Old 10-27-2013, 10:32 PM Thread Starter
Seriously I'm debating putting everything on hold and going to coilovers just try and avoid some of this hassle. Off the top of my head it's like 3 inches from housing to the C.....
post #18 of 19 Old 10-28-2013, 01:20 PM
I just welded my stuff to the cast . No probs . I've been pretty hard on it . I'm running 41.5s as well. I've got a few thousand miles on it now ... The wider you go with the links the straighter they need to be other wise they will hit your frame . I know this because I have RK arms and they hit. I should have gone with less bend and I could have more up travel .
My build
post #19 of 19 Old 10-28-2013, 03:25 PM
spookylynx's Avatar
It's not as scary as it sounds to cut some of the housing out, just measure twice and then again a third time. Did it on my friends TJ when we built his 60 and after a year of daily driving and wheeling, there have been no problems. Or, you can cut out a minimal section for half the bracket and weld the other half to the cast, CO4LO has a good example in his axle build thread.
But all that said,,,, going straight to coilovers is a good thing too
spookylynx is offline
