Adding 3/4" day star budget boost to a 3.5" RE lift.. Thoughts. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 10-11-2013, 08:42 PM Thread Starter
So I found a free brand new Daystar 3/4" Comfort Ride Budget Boost Kit... I'm thinking why not throw it on... I have a 3.5" Rubicon Express standard kit... I can just toss the spacers in right? I mean theoretically the day star kit is used on a stock suspension so I should be good... Has anyone else done this?
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42” MTR's
17" Spyderlock Beadlocks
post #2 of 6 Old 10-12-2013, 06:10 AM
Grant211's Avatar
Short answer is yes.
Only thing to really check will be the brake lines.
Grant211 is offline
post #3 of 6 Old 10-12-2013, 07:16 AM Thread Starter
awesome! I like the crown products one because it comes with front and rear... but i should only need the rear... anyone else? has anyone done this? pictures?
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
post #4 of 6 Old 10-17-2013, 01:30 PM
ATX_JKU's Avatar
I just got the same spacers at 4 wheel parts an hour ago for 35 dollars. About to stack them on top of my 3'' Trailmaster lift.
ATX_JKU is offline
post #5 of 6 Old 10-17-2013, 01:56 PM
planman's Avatar
You will want to adjust your control arms for pinion angles and caster specs.
You will want to adjust your trackbars to center your axles.
At over 4", your steering angles will be a little steep. If you feel like you end up with a little bumpsteer, you can upgrade to a drag link flip kit, or you can remove the coil spacers.
Your shock length limits your droop. So, with the same shocks, you shouldn't need longer brakelines.
Your driveshaft angles will be steeper. So, the joints wouldn't last as long.
Edit:
I missed that you have an RE 3.5" Standard instead of a Super-Flex.
In that case, you cannot adjust your control arms. You are limited to front lower cam bolts. You cannot adjust your rear trackbar because you use the stock one with a relocation bracket.
Because the only adjustability you have is the front trackbar and front lower cambolts, I would suggest you do not add the coil spacers.
planman is offline
post #6 of 6 Old 10-17-2013, 07:36 PM Thread Starter
Edit:
And this is the response I look for! Thank you planman! I'll wait it out!
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
