Going to 40's :) - JKowners.com : Jeep Wrangler JK Forum
post #1 of 26 Old 10-11-2013, 03:32 PM Thread Starter
Going to 40's :)
I've been running 37 13;50 nittos for over a year now and they are getting low on tread (bought used). So I decided to step up to some 40's. Getting the Good Year Mtrs on Monday.
I'm sitting on the TF 4"lcg with flat fenders and have already trimmed some pinch seam. Hoping not to need to do too much extra. If I have to run some adjustable coilspacers or something I will.
Front end is inner and outer sleaved, Cs have been boxed in and I have the upgraded synergy ball joints.
I know I"m pushing it with 40's, but they are the same weights as my 37s, actually a couple pounds lighter. I plan on D60's in the next 6 months to a year and using this 44's under a hemi tj that I'm going to build for my boy.
ShizNizy is offline
post #2 of 26 Old 10-11-2013, 03:44 PM
Homeless Hank's Avatar
Awesome! I wish I could do that, but Im stuck with 37"s since I cant go any taller at the house because of the garage.
You getting new tires this time?
-Hank
Homeless Hank is offline
post #3 of 26 Old 10-11-2013, 03:46 PM
bgall's Avatar
I sometimes wish I had stayed at 37s. The sacrifice in bump stop does not make me happy. Having the axles (mostly diffs) up higher has helped noticably in some spots. Not sure if I would go to 40s from 37s knowing what I know now. You will have to do significant cutting on the rear unless you are going to go extreme on the bump stop.
I have jeeps. I do shit to them.
bgall is offline
post #4 of 26 Old 10-11-2013, 06:27 PM
Good luck, 40's are a whole different ball game vs 37's. Steering is likely going to be a problem unless you have 3" bs wheels and spacers.
post #5 of 26 Old 10-11-2013, 08:44 PM
Good luck and enjoy!
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42” MTR's
17" Spyderlock Beadlocks
post #6 of 26 Old 10-11-2013, 08:51 PM Thread Starter
Well, I decided might as well go all in I'm upgrading shocks and coils for a 6" lift.
I hear ya on the garage issue, I was building my old home when I had a TJ with a 6 inch lift and 36's. I verified the height of the garage probably no less then 20 times. Yup, 7 foot. I informed them that "should" work since my jeep stood 6'11". Well they forgot about the 2" trim, so it didn't fit. Good thing I rolled it before the house was done
Yes, new tires this time, now that I have some more cash then before
Steering we may have to limit, but we were flexing it out as is and I still have a fair amount of room with my current setup and the mudgrapplers I have are a 13.5, but have heard they measure more like a 14.50.
2012 Jeep Unlimited Rubicon Gecko Green!
6" longarm, 40" tires, 4:88's Synergy inner/outer sleeves, trussed, c's and hvy duty ball joints,Tom Woods DS f/r, Bush Whacker Flat Fenders.
RSE Rear Bumper, Smitty Stinger front.
ShizNizy is offline
post #7 of 26 Old 10-11-2013, 09:08 PM
That didn't take you long!! haha. You could probably get away with 40's on 4" of lift depending on how much you're willing to trim.
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.” - Jeremy Clarkson
wranglerblackout08 is offline
post #8 of 26 Old 10-12-2013, 08:10 AM Thread Starter
Yeah, but I had a real hard time deciding between the 4inch and 6inch when I first got my lift and going to 40's will make it so I can't fit in the automated car wash already so might as well go another 2inches.
It's not too much money to go from the 4 to 6 inch. The coils are only $300 and the shocks are $400. I have the stock teraflex shocks so I'm upgrading fox shocks.
I'll probably be able to get a little bit out of the 4inch coils and shocks, or at least that's what I told the wife And I was even able to sleep in the bed last night after telling her how much.
In my defense if it weren't for my Jeep in high school we would have never met.
ShizNizy is offline
post #9 of 26 Old 10-12-2013, 08:48 AM
VKS Fab
JK Vick's Avatar
You main issues is going to be the 6" coils. Running them is going to make your caster/pinion angle horrible. Years back I tried to run 6" springs, to keep the front pinion angle decent (read: no vibes) and caster was right around 2 degrees. Running that low of caster makes it have horrible road manners so just keep that in mind. My advise would be to run 4" coils, 2.5" of bump stop, a set of wheel spacers and trim what ever is left in your way... That's what I did. Now I'm running even lower, right around 2.5-3" of lift and 40's with plenty of up-travel, you just can't be afraid of cutting.
Old
Now
Sent from AutoGuide.com App
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #10 of 26 Old 10-12-2013, 08:59 AM
You can run the 40's on 4" of lift but you got to push the wheels out there pretty far or limit your steering. Stretching the front would be a big plus as well.
post #11 of 26 Old 10-12-2013, 11:56 AM Thread Starter
Thanks for the heads up. I think I should be fine as when I had gears, sleeves, truss etc. My guy rotated the knuckles so hopefully the extra 2 inches shouldn't affect anything.
If I hate it, put my old stuff in and pull out the sawsall
ShizNizy is offline
post #12 of 26 Old 10-12-2013, 03:15 PM
VKS thats a lot of good info! Especially on stance for on road driving!
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
post #13 of 26 Old 10-12-2013, 06:15 PM
Acey's Avatar
-Hank
Give the garage a lift kit!
There! Problem solved!
2008 JK Rubi on big tires and stuff, RIPP supercharger.
Various dents and scratches.
Acey is offline
post #14 of 26 Old 10-12-2013, 08:39 PM Thread Starter
Or a winch front and rear hooked to the axels and just suck it down to pull into the garage
ShizNizy is offline
post #15 of 26 Old 10-13-2013, 10:44 AM
Robbs2008JK's Avatar
I went from 37's to 40's but I was planning on going to 40's when I started my build. I am running tge terafkex 6" Lcg kit. My jeep still fit in tge garage with about 1" clearance. You will need to trim the hell out of the the pinch welds. I am running 4"bs wheels and 1 1/2" wheel spacers. I still rub tge frame at full lock but not very hard just my side lugs rub. I have also pushed the front forward 1" and rear back 2" to min the cutting need to clear these beast. Also you will need to do hydro if you want to turn on the trails. I am running the rubicon d44's still but they are fully built. I pick my line wisely and stay out of the skinny peddle. Be prepared to go through front end parts especially ball joints. I am buikding a 60/70 the begining of the year. These tires will find a weak link. If I was to do it over I would of build 1 tons first.
Oh and my garage is standard height
I have 4.8 degrees of caster and converted the d44 to manual hubs. Drives and handles better than stock.
This was before trimming and redoing my bump stops with 40's
This after trimming and redoing my bump stops and pushing the front forwad 1" and the rear back 2"
Robbs2008JK is offline
post #16 of 26 Old 10-14-2013, 12:10 PM
Keith B.'s Avatar
I went to 40's about 2 weeks ago. This weekend I had to notch out the frame to make the tires clear when turned. Not a fun project, but necessary unless you stretch the front or run big spacers.
07 JKU, 14 bolt rear/ Teraflex 60 front, Tera Long Arm, King Coilovers, 40" MT/R-Ks, Antirock etc. 430HP LS3 engine swap. Cage and 14 bolt swap thread-
Keith B. is offline
post #17 of 26 Old 10-14-2013, 01:04 PM Thread Starter
Pics?
I'm just sitting at home waiting for the call that's its ready to pick up
ShizNizy is offline
post #18 of 26 Old 10-14-2013, 04:31 PM
Keith B.'s Avatar
I did something very similar to this.
https://www.jkowners.com/forum/showthread.php?t=35808
Theirs was prettier than mine though.
Keith B. is offline
post #19 of 26 Old 10-14-2013, 07:04 PM Thread Starter
Well bad news....
My tires broke their tire mounting machine so they had to out source that along with the balancing so it wasn't able to get done today.
I should be able to pick it up during lunch tomorrow.
ShizNizy is offline
post #20 of 26 Old 10-14-2013, 09:30 PM
37" vs 42"
stock rubi vs 42"
post #21 of 26 Old 10-15-2013, 07:50 AM
ALASHA's Avatar
^ Lo2ay's rig right?
ALASHA is offline
post #22 of 26 Old 10-15-2013, 08:35 AM
It never ends...
LeftHandRubi's Avatar
Sure looks like it.
T-REX
Meet Rex Thread:
Adventures of Rex Thread:
LeftHandRubi is offline
post #23 of 26 Old 10-15-2013, 08:59 AM
mschaffer66's Avatar
Well bad news....
We call that foreshadowing...
2007 Sahara Unlimited - Dana 60/14 Bolt - 5.38's with ARBs - 40x13.50x17 Goodyear MTRs - 3.5" Rock Krawler X Factor Plus - Rubi Rock Rails - XRC 10,000lb Winch
mschaffer66 is offline
post #24 of 26 Old 10-15-2013, 11:56 AM
Originally Posted by LeftHandRubi View Post
Sure looks like it.
Yes
post #25 of 26 Old 10-15-2013, 03:18 PM Thread Starter
If I break my axles I just get bigger ones sooner
I don't think they will be any harder on my axles then my heavy 37's were.
ShizNizy is offline
