Temporary solution to a bigger problem? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 10-11-2013, 11:33 AM Thread Starter
2009 Rubi, 22k miles, 2.5" lift, 35s. NOT A DD.
While driving along today my ABS, BAS, & ESP went off and damn near pulled me off the edge of the road. I pulled over, turned off the Jeep, started it up and the shit kept pulling me right. Finally after 2-3 attempts, I pulled J6 and drove home. I don't mind driving without ABS and ESP and will probably do the wonderful steering wheel dance tonight. But, what caused this in the first place? I have no idea where to start diagnosing. Speed sensor maybe?
Shammy O'Shea is offline
post #2 of 5 Old 10-11-2013, 12:03 PM
tiltz's Avatar
Bad speed sensor could be the culprit.
Here is a way to disable:
http://www.jkfreaks.com/forums/showt...P-Kill-Switch&
tiltz is offline
post #3 of 5 Old 10-12-2013, 10:51 AM Thread Starter
sweet. thanks man.
post #4 of 5 Old 10-12-2013, 11:02 AM
V8 dreams
jvandy50's Avatar
you have a programmer? my hypertech pulled the code so i knew which sensor to replace, $23 off amazon and 5 minutes to switch em out
2010 Silver JKU
jvandy50 is offline
post #5 of 5 Old 10-30-2013, 08:22 AM Thread Starter
Just an update in case anybody else has the same issue: checked the codes at my local O'Reilly. It was a bad left rear speed sensor and sensor cable. After tearing it out, I noticed that the sensor cable runs underneath the axle for some un-godly reason. I'm guessing it was crushed by a rock or "something" last trip out. Sensor was ~$16 and the cable was ~$10 at O'Reilly. I took the liberty of re-routing all the cables over the frame to make sure they don't get crushed/cut again. Thanks for the help guys.
