Dual battery gauge - A pillar mount - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 10-06-2013, 10:45 AM Thread Starter
GreenGIAnt08's Avatar
So I finally received my A pillar dual gauge mount from Quadratec. The install was quite simple, since I already had the wiring done for my dual battery power gauges. Figured I would post some pictures in case anyone else is tempted to do something similar.
Gauges are normally used on a battery powered forklift, 12-24v reading, and are keyed to turn on when you start the vehicle or by a switch. Name:  1381077708856.jpg
These are the clips on the stock no mount pillar cover.
A comparison of the stock (left) and the Quadratec mount (right). You can see the gauges fit nicely and cable management isn't really an issue. Plenty of room.
There is a drilling template for JKs that do not have the same mounting system. It was very easy to use and took only a couple extra minutes.
Mount installed. Granted it's a bit darker than I'd care for, I think it is a much nicer look than how I originally had the gauges installed. Only thing I would change is the angle that the gauges are tilted but that's me being picky.
I hope this helps anyone make their rig designs better or at least provides some info on a very simple install.
2008 JK 2DR X -3" Lift, 8,000 Waterproof winch, Rugged Ridge Snorkel, XHD front Bumper, Dual Batteries, CB and other random electronic bits.
GreenGIAnt08 is offline
post #2 of 5 Old 10-07-2013, 08:13 AM
usmcdoc14's Avatar
where did you get the guages from or model number/maker for those people looking for them.
usmcdoc14 is offline
post #3 of 5 Old 10-13-2013, 06:16 AM Thread Starter
They literally are from a fork lift. I used to work at a forklift dealership so they were easy to come across. Any 12v battery gauge (fuel gauge) from a battery powered forklift should work just fine.
post #4 of 5 Old 10-13-2013, 05:06 PM
Homeless Hank's Avatar
Can you show another pic with the jeep running?
Homeless Hank is offline
post #5 of 5 Old 10-16-2013, 04:48 AM Thread Starter
Its still dark here but both with and without flash.
