Shock Question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 09-28-2013, 10:16 AM Thread Starter
GreenGIAnt08's Avatar
Shock Question
So I purchased my 2008 JK X two door about a year and a half ago with a stock 3" lift. Recently I had to replace the shocks, and used ProComp shocks for an installed 2-3" lift kit. The installation went fine but I did notice that the stock lift kit has 3" spacers for the existing stock shocks. I'm wondering if, since I have shocks for a 3" lifted Jeep, can I remove those spacers?
ProComp Shocks I installed are #924507 (rear) and 924510 (front)
GreenGIAnt08 is offline
post #2 of 12 Old 09-28-2013, 10:52 AM
There is no such thing as a stock lift kit...if Jeep installed it, it is made by probably RE or such...and maybe they just used spacers that came with the lift kit. Again, no such thing as a stock lift...
NRA Lifetime member
It takes a special kind of stupid to think criminals will follow gun laws...
08 JK Red - NV241OR Tcase, Ripp GenII, 3"OME lift and Nitrocharger shocks, JKS F/R adj trackbars, Rockrawler UF adj CAs, Teraflex UR adj CAs, Ruggid Ridge Modular front bumper with M8000, Olympic rock rails and rear bumper, BFG KMs
rlanderton is offline
post #3 of 12 Old 09-28-2013, 11:27 AM
You can remove the coil spacers but make sure you have the top rubber coil perch bushing. Post up a photo of the top of the front and rear coils.You will also want to check the sway bar links as these may have been added because of the additional height.
post #4 of 12 Old 09-28-2013, 11:34 AM Thread Starter
But I'm not asking about coils. I'm asking about the shocks. I'll get a picture in a little bit.
2008 JK 2DR X -3" Lift, 8,000 Waterproof winch, Rugged Ridge Snorkel, XHD front Bumper, Dual Batteries, CB and other random electronic bits.
post #5 of 12 Old 09-28-2013, 11:36 AM
Sorry about the mis read. If you got new shocks for a 3" lift then yes take the shock extensions off. You should have only about 2" of up travel available with the extensions on.
post #6 of 12 Old 09-28-2013, 02:10 PM
PIG
PIG's Avatar
X2... However, if Jeep installed it it's prob gonna be hard to tell what brand without some pics.
A pic is gonna go a LONG way here. Taking the shocks off and measuring the collapsed and extended lengths will go even further.
PIG is offline
post #7 of 12 Old 09-28-2013, 02:36 PM
KevinJBurt's Avatar
Send a message via Yahoo to KevinJBurt
X3 I know exactly what you're talking about and yes you can remove the shock extension brackets! You should have them on the front and back and as long as you bought 4 extended shocks you can and should take out all 4 brackets!
Sent from AutoGuide.com App
Always forward never straight sometimes upside-down!
KevinJBurt is offline
post #8 of 12 Old 09-28-2013, 02:45 PM Thread Starter
Here are pictures of the front shock and the rear. Rear shock you can see how much of the ram is exposed with the bracket in the picture. Other two are the ram of the front shock and a pic of the bracket.
post #9 of 12 Old 09-28-2013, 02:59 PM
KevinJBurt's Avatar
Yep.. Take those off!! You don't need them anymore!!
Edit.. They look like Rough Country but TeraFlex look the same also....
post #10 of 12 Old 09-28-2013, 03:46 PM
PIG
PIG's Avatar
X2...
FYI, MOST of those white body twin tubes are Tenneco units.
PIG is offline
post #11 of 12 Old 09-28-2013, 04:14 PM Thread Starter
They are ProComp.
post #12 of 12 Old 09-29-2013, 11:00 AM
TXCAJN's Avatar
They are ProComp.
They have a Pro Comp sticker...like Pig said, they are most likely a Tenneco shock spec'd by PC.
2012 JKU Altitude
2014 Grand Cherokee Overland
TXCAJN is offline
