Teraflex Fox Resi front shock mounting question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 09-27-2013, 04:54 PM Thread Starter
SoK66's Avatar
Have a new set of Teraflex Fox reservoirs to install, but I'm currently laid up after shoulder surgery. Right arm is mostly imobilized so I can't check this out personally. Wondering if in front I can mount the reservoirs to the shock bodies without risk of tire rub, or should I consider another mounting location? Thanks!
SoK66 is offline
post #2 of 13 Old 09-27-2013, 09:02 PM
Depending on a lot of factors. Tire size, rim backseat and shock diameter. I run icon 2.5 on 35" tires with 4" back spacing (I think). The reservoirs are mounted in front of the shock tower due to rubbing issues.
Doormandan is offline
post #3 of 13 Old 09-27-2013, 09:14 PM
Vin
Vin's Avatar
Feel better soon!
Vin is offline
post #4 of 13 Old 09-27-2013, 10:24 PM
Robbs2008JK's Avatar
Mine clear even with the poly relocate kit on the front
The resi is mounted to the shock. I am running 40's
Robbs2008JK is offline
post #5 of 13 Old 09-28-2013, 08:05 AM Thread Starter
SoK66's Avatar
Thanks all. I'll probably try just mounting the resis to the bodies and cycle the axleq to see what the clearance is. Gonna be months before i can do it though.
SoK66 is offline
post #6 of 13 Old 09-28-2013, 10:28 AM
n8rb8r's Avatar
I ran 37" mtr on 4" backspacing with mine, the tires would grab the body's and spin them into the coil mounts and scar them up. Get the resi mounts that Tera sales, they are cheap and easy and securely mounts the resi well out of harms way. http://www.teraflex.biz/bracket-kit-...-on-frame.html
n8rb8r is offline
post #7 of 13 Old 09-28-2013, 06:03 PM Thread Starter
SoK66's Avatar
Thanks, that's exactly the setup I have. I'll get those mounts.
SoK66 is offline
post #8 of 13 Old 09-28-2013, 06:09 PM
heres mine
dahreno is offline
post #9 of 13 Old 10-03-2013, 08:04 AM Thread Starter
SoK66's Avatar
Originally Posted by dahreno View Post
heres mine
Nice! What are the details on your suspension?
SoK66 is offline
post #10 of 13 Old 10-03-2013, 08:07 AM Thread Starter
SoK66's Avatar
Following up on this one, I have the TF reservoir mounts and a set of TF limit straps on the way. Due to a bad shoulder injury, surgery last month and months of upcoming rehab I won't be able to install any of this stuff myself. I have a local outfit I'll farm it all out to. Will report when done.
SoK66 is offline
post #11 of 13 Old 10-04-2013, 11:06 PM
I feel for you , I also had shoulder surgery and was out of commission for quite some time . Just do what the doctor tells you .When it comes time to stretch and exercise it , don't baby it .A lot of people will not do the exercises they are supposed to do and end up having problems for life .My jk has a 6" pro comp long arm with Fox remotes . As you can see the remotes are attached to the shocks.The tires are 35 x 12.5 and the rims have 3.75 back spacing . they do not rub the shocks or remotes .It also has Rancho diff. covers front and back with Rancho lower skids on the front lower shock mounts .It also has skid plates for the engine , tranny and gas tank , all 3/16 thick.Front bumper is a Teraflex shorty with a Warn 9.5 and the rear bumper is made by Hanson with tire carrier.It is very capable and I do like the suspension and I have had it for about 4 years with no problems. I just got some new sliders custom made by LOD with a step going from wheel well to wheel well . They just arrived today and can't wait to install them . I had to get them made with no rear mount because the mount would not fit because the lower long arm is in the way . I will have to make some rear mounts for them to make them fit .
dahreno is offline
post #12 of 13 Old 10-05-2013, 11:42 AM Thread Starter
SoK66's Avatar
Nice rig! Yes, into physical therapy now and although a bit uncomfortable at time it's progresing. Prolly will be months before I can wrench on the JK.
Did you install limit straps on your rig? Got a set from Teraflex but not sure they'll be needed.
SoK66 is offline
post #13 of 13 Old 10-05-2013, 03:44 PM
Didn't install limit straps on this Jeep but , will need them for my other Jeep I'm building .
dahreno is offline
