Bolt in Spidertrax Axles - JKowners.com : Jeep Wrangler JK Forum
 8Likes
  • 6 Post By ALASHA
  • 1 Post By TravisW
  • 1 Post By thedirtman
post #1 of 12 Old 04-11-2019, 08:05 AM Thread Starter
ALASHA's Avatar
About damn time someone started advertising this. Its almost what I wished it to be
https://www.millerrockracing.com/i-8...ef=category:68
ALASHA is offline
post #2 of 12 Old 04-11-2019, 08:18 AM
That's a beautiful axle. You're right about the lack of exposure.
scubatech is offline
post #3 of 12 Old 04-11-2019, 03:45 PM
holiday13's Avatar
Wondered for a long time why no one was doing bolt in 9" axles for the JK (other than Currie who didn't really push it), superior to the 60 in every way. Awesome Erik took that need and is bringing product to market!
2012 JKU Sahara, basically stock
1989 4Runner, SAS, ARBs, 35's, yada yada yada
1998 Tj 1ton build in progress, stretch to LJ dimensions, chevy v8 (350+hp), auto, duals, 1tons, 40's, coilovers, the usual family wheeler
Former Team Quadratec driver #831
holiday13 is offline
post #4 of 12 Old 04-12-2019, 04:16 AM
TravisW's Avatar
Erik has been successfully testing these in his JK for a while now.
Rancho Suspension likes this.
2012 JKUR, auto, tons, a little lift, 4Ds, not much else
TravisW is offline
post #5 of 12 Old 04-12-2019, 06:27 AM
ITs because they are expensive when you get done and dynatrac PR look like a bargain. I would not buy a "bolt in" and would just buy the housing so the brackets have better clearance and you can put the brackets where you need them to better optimize whatever lift you are running.
post #6 of 12 Old 04-12-2019, 10:25 AM
holiday13's Avatar
I do not mean this to be a pissing match but when you put paper to pen 9" is the same or could be less than DT PR 60's. Pair of PR 60's with ARBs you're at $13k (before shipping). 9" figure:
Housings $1500 (pair)
Knuckles $1800
Floater end caps $240
Unit bearings $2400
Brackets $800 (figure use Artec and modify to fit)
Truehi9 front third $3000
Low pinion rear third $2000
Shafts rear $400
Shafts front $750
Total $12,890
And that's with unit bearing knuckles from ST and their unit bearings, if you went with Solid or Reid knuckle and bearing kits you could shave $ off. Yes there are labor costs in welding and final assembly but these are also retail prices for you and me and a shop producing these would see disocunts on parts that would offset the labor and then some. 9" built similar to DT PR 60s are right there price wise but have stronger R&P, more ground clearance, and are lighter, A LOT lighter!!!!
post #7 of 12 Old 04-12-2019, 12:05 PM
gt1guy's Avatar
Always good to see another option out there.
Spidertrax isn't a name you'd equate with inexpensive though. I'd expect there to be some sticker shock that comes with them.
Kevin
gt1guy is offline
post #8 of 12 Old 04-12-2019, 07:27 PM
Knuckles $1800
Unit bearings $2400
Shafts rear $400
Shafts front $750
Total $12,890
No lock out hubs, pinion yokes, or brakes in your breakdown. I priced out building them once and it was closer to $18k when all said and done.
ChuckTheRipper likes this.
post #9 of 12 Old 04-14-2019, 12:12 PM
gt1guy's Avatar
^^This^^
Besides, who's going to choose to take this route and then go budget build?
Kevin
gt1guy is offline
post #10 of 12 Old 04-15-2019, 07:54 AM Thread Starter
ALASHA's Avatar
I believe you are pricing out Spidertrax knuckles which this axle doesnt appear to be using so there is some cushion there to probably account for the lock outs at least.
I dont think this is being marketed as a cheaper alternative than Dynatrac but I think there is a market out there that is willing to pay a slight premium for the weight savings and ground clearance.
ALASHA is offline
post #11 of 12 Old 04-16-2019, 04:51 PM
These axles must be using the Spicer inner c from the ultimate 60 axles, which are compatible with 05+ superduty knuckles, making all of those parts dirt cheap.
wellstig1 is offline
post #12 of 12 Old 12-05-2019, 02:09 PM
I want to see someone running these in a jku! What would you do for abs tone rings? If they could be made to work with stock sd or dodge calipers and rotors then sign me up! ( as long as they are kingpin and not bj's)
08 JKU 6.0 LC8 6L80 Atlas 2 39" KM3's on Trilogy race beadlocks, prorock 44,rcv's arb front. rock jock 60 rear 40spline shafts,arb 5.13's and a bunch of other stuff
89yjon is online now
Similar Threads
Spidertrax Axles - which unit bearings? jk12blk Modified JK Tech Dept. 3 11-02-2015 08:02 AM
USA MADE JK Rear Chromoly Axles Rubi and Non-Rubi 30 32 or 35 spline COMPLETE BOLT IN RWKHausSupply Vendor's Marketplace 2 08-29-2014 11:17 AM
Spidertrax, first bolt on for new JKR RedundanT JK General Discussion 1 08-28-2014 01:28 AM
HUMMER WHEELS!!! 8 bolt and 12 bolt 100dollarman For Sale 0 04-13-2011 09:05 PM
6 Spidertrax 5x5 to 5x5.5 Bolt Pattern - 1.375 in Wheel Adapters WHS-012 Slippery For Sale 0 10-11-2009 05:17 PM
