JKU REAR Armor and Customized armor - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 08-09-2017, 08:08 AM Thread Starter
bigworm36's Avatar
Have a another new product out ! Protect your Jeep and customize it with custom graphics. There are two plates per side with this kit. The back plate are cut from .125" bare steel. The front plate or graphic plate is cut from .075" thick bare steel. The two plates are bolted on top of each other for a custom look showing your graphic or text of choice. These do not require any cutting or grinding for installation and are shipped bare steel. They are designed to fit the 4 door jeep JK from 2007-2017. These do not come with mounting hardware which can be found at most local hardware stores. You will need 28 1/4-20 button head cap screws and 28 1/4-20 nutserts. It is recommended to use a good nutsert tool or borrow someones when installing nutserts. I do not have an installation instructions yet but there is a lot of info online on how to install armor like this and nutserts. Designed to fit with most fender flares but if your flares cover the lip in the sheet metal these may not fit or further modifications may be needed. Any questions feel free to ask. These are much cheaper than the big name companies and good quality steel. No extra cost on custom designs as long as it it not super complex. Cost is 227.00 for the custom orders. Contact me for information on your design and I can send you a picture of what it will look like before I cut it out. Or you can order just a pair of .125 thick plate armor for 140.00 which is still about 40.00 cheaper than most other companies after you add in hardware cost. Check out my website at www.ceeplasma.com. All metal shipped bare.
Sent from my SM-G955U using Tapatalk
bigworm36 is offline
post #2 of 2 Old 08-09-2017, 08:10 AM Thread Starter
bigworm36's Avatar
I should also add these are made to order so allow some time on shipping especially on custom orders where I have to design the text and graphics
