Fox 2.5 IBP Remote Reservoir Coilovers with Short Rod End - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By TRD
post #1 of 1 Old 07-20-2017, 03:12 PM Thread Starter
TRD
TRD's Avatar
We have had a lot of requests for custom configured Fox 2.5 Internal Bypass (IBP) coilovers so we made a new configuration and part numbers specifically designed for the needs of JK's and other solid axle vehicles.
Fox Custom Fox Internal Bypass Coilovers By AccuTune Off-Road
Custom Tuning:
Every shock is tuned using AccuTune Equations, and re-valved by hand to deliver the best comfort and performance possible right out of the box. Learn more about our tuning here: How AccuTune Valving Works | AccuTune Off-Road
Fox Internal Bypass:
Fox IBP coilovers work like a multi-tube bypass shock with several compression and rebound zones. This gives you a soft ride with excellent bottoming resistance. At AccuTune Off-Road every shock is custom valved by hand for your exact rig, terrain and driving style.
Rotating Remote Reservoir:
The standard PiggyBack Fox IBP shocks can be hard to package so we designed ours with a rotating remote reservoir. The entire reservoir assembly now rotates 360 degrees around the body, and the 90 degree fitting also rotates 360 degrees, making packaging extremely simple.
Shorter Rod End:
Our IBP shocks come with shorter rod ends for easier packaging.
Shorter Reservoirs:
Some of the Fox shocks come with excessively long reservoirs that have waaayy too much nitrogen in them, allowing for excessing piston plunge and making the reservoir much longer than necessary. By shortening the reservoirs the performance is better, and they're easier to package.
DSC Performance:
While IBP shocks work amazingly well, they are difficult to tune because there aren't any external adjustments like traditional bypass shocks. We solve this problem by adding Dual Speed Compression Adjusters.
Lead Time:
We keep these shocks in stock and ready to ship!!!
Call us at 424-377-0808 to order yours today, or to learn more about the benefits of our IBP coilovers.
BlackOps82 likes this.
-Ryan @
424-377-0808
Pre-Tuned
Shocks
Coilovers, IBP's, Bypasses & Adjustable Shocks In Stock
TRD is offline
