NEW!! JK Front Inner Fender Liner - JKowners.com : Jeep Wrangler JK Forum
post #1 of 1 Old 06-29-2017, 09:56 AM Thread Starter
Nemesis Industries's Avatar
Talking NEW!! JK Front Inner Fender Liner
$299.00
https://www.nem-ind.com/jk-inner-fender.html
Nemesis JK Inner Fenders were another response to issues we saw with the options for JK inner fenders: the factory plastic liners are prone to catching on big tires and look cheap, and after market fenders often are flimsy, have fit and finish issues or are downright gaudy. Like everything we do, we wanted to create a the best inner fender you can buy using Nemesis's standards for quality, form and function.
Our JK Inner Fenders are the highest clearance liner you can get! They start past in the inside of the frame and hug the fender opening, coming all the way up to the battery box on the right hand side, leaving maximum real estate for your tires.
Installation is easy thanks to our innovative two piece design, making it so you don't have to fight to position the inner fender around the suspension components. Nemesis JK Inner Fenders also use all of the factory mounting holes, making installation quick and painless.
They're made of .090 aluminum to ensure they remain rigid and hold their shape, able to withstand punishment from the road and off the road.
Build Specs
Nemesis's superior construction
Built from high strength .090 aluminum
Formed and welded using Nemesis's proprietary manufacturing techniques using hand built custom tooling
Uses factory mounting holes, two piece design for ease of installation
Slotted vent to allow air flow with minimum debris entering the engine bay
Inspected for precision fit and finish to Nemesis's high standards, fits right the first time
Notes
Available in raw, black or texured powdercoat
Designed to accomodate most aftermarket fender flares and shock configurations, some modification may be required
Unfinished
Another image
Powder coated with the Falcon piggy back east to access
NEMESIS INDUSTRIES
INDUSTRY'S FIRST ALL ALUMINUM PRODUCT LINE
(303) 974-2460
Follow us on
Nemesis Industries is offline
