Motobilt DIY Beadlock kits coming soon! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 10-05-2016, 08:44 AM Thread Starter
Motobilt DIY Beadlock Kits coming soon! Click here to find out more!
We have been working to get the pricing set for a new line of DIY Bead Lock Kits at Motobilt. We are going to start them at $199 for a 15" wheel plus options such as anti-coning rings, and more. The bead lock kits are CNC plasma cut here at Motobilt. The material used on the set pictured here is a 3/16" steel for the inner ring and 1/4" for the outer clamping ring. This DIY bead lock kit was designed to weld to a steel wheel. They are considered an off-road use only product. A qualified welding professional is required to weld the inner ring to the wheel. When welding DIY Bead Lock Kits on it is important make sure the weld is completed with no gaps or holes. If not your tire will leak down. This image shows the inner ring. It sits inside the lip of the steel wheel to help center the ring.
This image shows the outer clamping ring. This ring is the one that clamps the tire to the inner ring
The Motobilt DIY Bead Lock Kits we be offered in various designs and for 15", 16.5", and 17" wheels. We will add other sizes at some point in the future. If you have any questions feel free to call 334-219-2333.
MOTOBILT, INC.
Call Dan DuBose or Bobby Cox
334-699-6300
Check us out on the web:
Visit our Facebook Page:
motobilt is offline
post #2 of 4 Old 10-13-2016, 08:23 AM
mack2's Avatar
$199 for a set or each wheel? If a set 4 or 5? Hardware included?
Mackenzie
mack2 is offline
post #3 of 4 Old 10-13-2016, 08:53 AM Thread Starter
Updated! 17" rings are now out! 15's coming soon!
Motobilt DIY 17" Beadlock kits at Motobilt.com click here!
Motobilt "Traps" 17" DIY Beadlock Kit
Motobilt "Cap Gun" 17" DIY Beadlock Kit
Motobilt "Stellar" 17" DIY Beadlock Kit
Motobilt "Simple" 17" DIY Beadlock Kit
MOTOBILT, INC.
334-699-6300
motobilt is offline
post #4 of 4 Old 10-13-2016, 08:55 AM Thread Starter
We just released the 17's and all of the info is posted in the above links so be sure to check it out. The 15's will be coming soon and those will be in that $199 range.
They come in sets of 4 but you can add a spare on the site. All of the details and options are listed on the site now.
Thanks,
Bobby
Motobilt
334-219-2333
MOTOBILT, INC.
334-699-6300
motobilt is offline
