New Ultra Clearance Front Bumper from GenRight! - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By rob_p
post #1 of 16 Old 09-13-2016, 06:34 AM Thread Starter
Made in the U.S.A.
GenRight Off Road's Avatar
  • Ultra Hi ground clearance shape provides your Jeep best approach angle.
  • Winch is recessed down between frame rails for better air flow to the radiator.
  • Extremely light aluminum construction..
  • Greatest protection for your winch on the market.
  • Can be painted or powder coated or left in natural aluminum finish.
  • Will not rust or corrode.
  • Best balance between strength and weight!
  • Laser Cut and formed from 3/16" thick 6061 Aluminum Alloy.
  • Unsurpassed quality and hand TIG Welded.
  • This model features a 1-3/4" thick wall tube protects the winch.
  • Our uniquely designed winch tray will fit Warn; Power Plant, Zeon & CTI winches.
  • Fits the 2 door and 4 door Jeep JK.
  • Compact design fits tight to the frame and wraps around each side.
  • 8 bolt mounting fits tight up against the frame.
  • 100% Made in USA!
Use code GRCHRISH on our website to save 10%! GenRight JK Low Profile Winch Guard Front Bumper - Aluminum
Also available without the winch bar:
805-584-8635
GenRight Off Road is offline
post #2 of 16 Old 09-13-2016, 06:46 AM
whats that great looking , aluminum bumper weigh-in at ( with the shackle points and driving light mounts& winchplate ) , @GenRight_Off_Road ?
Thanks !
post #3 of 16 Old 09-13-2016, 06:49 AM Thread Starter
Made in the U.S.A.
whats that great looking , aluminum bumper weigh-in at ( with the shackle points and driving light mounts ) , @GenRight _Off_Road ?
Thanks !
I don't have one here to weigh but I'd say the bumper is around 20 pounds and the shackle mounts are probably around 12 pounds combined. Low to mid 30s?
805-584-8635
post #4 of 16 Old 09-13-2016, 01:51 PM
Thanks , that's what I ball-parked it around. I really like the bumper.
post #5 of 16 Old 09-26-2016, 01:36 AM
Comfortably Numb
RubiCajun's Avatar
Will it fit a Superwinch EPI 9.0 ?
RubiCajun is offline
post #6 of 16 Old 09-27-2016, 03:18 PM
Love the lightweight bumper
1FSTREX is offline
post #7 of 16 Old 09-28-2016, 05:43 AM
j-rod17's Avatar
is the bumper limited to only the winches listed?
Does it work with Rubicon sway bar?
2008 JKU: continual work in progress
j-rod17 is offline
post #8 of 16 Old 09-28-2016, 11:51 AM Thread Starter
Made in the U.S.A.
We have not tried that winch, but I do not see any reason it would not work. Sorry for the delay in getting back to you!
805-584-8635
post #9 of 16 Old 09-28-2016, 11:52 AM Thread Starter
Made in the U.S.A.
No, those are just the ones we actually tested.
yes, it will work with the Rubi sway bar.
805-584-8635
post #10 of 16 Old 09-28-2016, 01:32 PM
I was looking at this bumper on your website yesterday, I really like it
Can you tell me if it will work with the Rubi IF the sway bar motor has been rotated?
Can the winch still be mounted recessed with the sway bar motor rotated?
Thanks.
Art_M. is offline
post #11 of 16 Old 09-19-2017, 05:15 PM
Just installed this bumper and very happy with it.
I removed a stock chopped stubby bumper, with winch plate and steel cable and replaced it with the Ultra and rope. I didnít weigh everything but I absolutely lost weight with the new combo.
The installation is pretty straight forward, if you watch the Genright YouTube video for their other bumper youíll get the general idea. You have to grind the frame in a couple of spots and chop the crash bar neither are a big deal. I was more stressed by drilling and tapping the frame hole for the top bolt but it was simple in the end, just get the right drill bit.
In summary...
Negatives - not compatible with the Ace sway bar motor flip. [ @GenRight Iíd love to see a fix for this, that thing hangs low! ]
Positives - really light weight, really low profile, looks great, low recessed winch and ground clearance! and plenty of room to mount lights ( I plan to add lights wired to my fog light switch) AND NO RUST!!
Still rocking the bare AL but will probably go black soon
Art_M. likes this.
rob_p is offline
post #12 of 16 Old 09-19-2017, 07:01 PM
Amazing how 10-20 lbs can make such a difference,huh?
On these lunch-box aerodynamic equivalent machines, every bit is noticeable.
I am definitely a JK aluminumophile...
that's a nice lookin' bumper!
post #13 of 16 Old 09-20-2017, 01:32 PM
Originally Posted by rob_p View Post
Negatives - not compatible with the Ace sway bar motor flip. @GenRight Iíd love to see a fix for this, that thing hangs low!
Good to know, I contacted GenRight and they say theoretically there was enough room to work. I'm not willing to give up the my e-disco, so I guess I will be looking for a different bumper.
Art_M. is offline
post #14 of 16 Old 09-30-2017, 05:39 PM
Lookin' good Genright!
JRWid is offline
post #15 of 16 Old 10-03-2017, 09:12 PM
Can you flat tow from the recovery points?
Kennykustom is offline
post #16 of 16 Old 10-19-2017, 12:20 PM Thread Starter
Made in the U.S.A.
Yes.
805-584-8635
