NEW!! JK Super Duty High Steer Arm and Tapered Knuckle Sleeves - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 05-03-2016, 10:08 AM Thread Starter
Fusion 4x4's Avatar
High Steer Arm for JKs running 05+ Super Duty axles with Reid Passenger Knuckle
What is different about our arms? They are geometry correct for a JK! Any other arm is based on the Super Duty drawing, which places the drag link hole too far out, which reduces steering stroke and causes slow steering.
- 1" 1018 Plate
- Water Jet cut! No laser, no plasma, just water.
- Holes CNC machined and designed for tapered nuts
- Zinc coated
$195 shipped. ARP studs and nuts are an additional $55. Or, message us for a sweet package deal including a Reid knuckle!
Tapered sleeves to take 05+ Super Duty knuckles from the crazy Ford taper to a 3/4" straight hole!
Finding a tie rod solution for the 05+ Super Duty is a challenge. We're making it a little easier with these tapered sleeves that allow the use of heim style ends.
- CNC turned
- Direct fit into top and bottom of passenger knuckle
- Driver knuckle needs to be drilled to 3/4"
- Driver knuckle requires reaming if using a sleeve
$15/each plus $7 for shipping.
Fusion 4x4 is offline
post #2 of 3 Old 05-03-2016, 12:20 PM
You're making this too easy for all of us! I need to go buy a damn superduty d60 already.
raven12 is offline
post #3 of 3 Old 05-03-2016, 02:24 PM Thread Starter
Fusion 4x4's Avatar
We're trying! We'll be rolling more stuff out over the next couple weeks as well.
