TeraFlex Product Highlight: JK Rear Utility Cargo Rack - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 11-17-2015, 12:28 PM Thread Starter
TeraFlex's Avatar
www.youtube.com/watch?v=u9PiRVf9D5s
The TeraFlex JK rear utility cargo rack provides additional storage options to organize and secure cargo. Taking mounting cues from the Nebo roof rack, the cargo rack also provides universal accessory mounting compatibility. The extruded aluminum rails take advantage of industry standard 10 series T-slot mounting to allow the use of readily available hardware to mount small accessories or recovery equipment.
An optional side panel kit is available separately
Fits Wrangler Unlimited 4-Door models only. ( A 2dr version is in the works)
• Height adjustable to customize for different cargo needs (from cargo floor to bottom of rack on highest setting = 23.625" and on lowest setting = 18.825")
• Sleek low profile aluminum design
• Composite corner assembly support
• Extruded aluminum construction for reduced weight
• UV resistant hard anodizing finish
• T-slot channels on each rail for tie down points & accessory mounting
• 18 ga. stamped steel floor for rigidity and structure
• Floor panels include accessory mounting holes
• Black powder coat floor and side panels to resist abrasion and increase durability
• Load is carried and supported by the factory sport bar
#4820000 $299.99 Natural Aluminum Finish (December 2015)
#4820020 $425.99 Black Finish (January 2016)
https://teraflex.com/shop_items/563b...a25c5bb19c9976
801-713-3314
TeraFlex is offline
post #2 of 14 Old 11-17-2015, 02:45 PM
TXtoAZ's Avatar
What's the load capacity?
Two other racks I've been looking at are rated at 125lbs. and 300lbs.
Funny, now that I look at it, those 2 cost about $2 per pound/carrying capacity, so is this one rated at 150?
TXtoAZ is offline
post #3 of 14 Old 11-18-2015, 02:54 PM
Vryce's Avatar
From what I can see, this system uses the same mounting point as the soft top. Can you use both at the same time?
Vryce is offline
post #4 of 14 Old 11-18-2015, 03:39 PM Thread Starter
TeraFlex's Avatar
It will not work with the factory soft top, sorry.
801-713-3314
TeraFlex is offline
post #5 of 14 Old 11-18-2015, 05:57 PM
TXtoAZ's Avatar
No answer for my question?
TXtoAZ is offline
post #6 of 14 Old 11-19-2015, 08:17 AM Thread Starter
TeraFlex's Avatar
Load capacity is 75lbs secured.
801-713-3314
TeraFlex is offline
post #7 of 14 Old 11-19-2015, 11:10 AM
TXtoAZ's Avatar
Thanks!
TXtoAZ is offline
post #8 of 14 Old 11-25-2015, 06:21 AM
bass5money's Avatar
UMM LOOKS LIKE ITS FOR A JKU NOT JK.. BE MORE SPECIFIC PLEASE
2014 jk oscar mike edition. Manual. 3.5" Rubicon super flex suspension lift. 35" AT tires 17" method rims. Body armor doors. Smitty built MOD front bumper. Smittybilt 9500 lb winch, ARB twin compressor, Spod with gauge, D2 LED's.
bass5money is offline
post #9 of 14 Old 11-25-2015, 09:22 PM
JK Timmay's Avatar
This . . . is . . . no bueno
JK Timmay is offline
post #10 of 14 Old 12-01-2015, 08:31 AM
n3tfury's Avatar
You and the Youtube personality need to arm wrestle.
n3tfury is offline
post #11 of 14 Old 12-01-2015, 04:45 PM Thread Starter
TeraFlex's Avatar
Nice..... This mounts in the same location as the soft top. Time to have a chat with someone here, thanks!
801-713-3314
TeraFlex is offline
post #12 of 14 Old 12-03-2015, 10:05 AM
Will the 2 door version work with a soft top? I have a Trektop NX and I'm trying to decide if one of these style racks is worth it or is even compatible. Thanks.
Mike
'07 2 door soft top
Espo78 is offline
post #13 of 14 Old 12-03-2015, 01:45 PM Thread Starter
TeraFlex's Avatar
We are still out a ways on making the 2 door brackets, sorry. If your Trektop mounts in the stock mounting location on the roll bar, that it will not work with this cargo rack.
801-713-3314
TeraFlex is offline
post #14 of 14 Old 12-03-2015, 08:33 PM
Ok thanks. The Trektop does not use factory mounting locations; it does not use a frame like the factory top.
Espo78 is offline
