Artec JK 3-Link Builder Kit - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 09-01-2015, 09:06 AM Thread Starter
Artec's Avatar
Looking to build your own Suspension and save a few bucks? Then this is the kit you have been waiting for!
Over the past few years we have developed a number of Heavy Duty Components for the JK and now they can be used to build your very own 3 Link Kit.
The JK 3 Link starts with the HD Crossmember with integrated Link Mounts. In addition to the added strength across the frame, we have added in 2 5/8" wide mounts. This will allow you to bolt in your lower control arms and this width is the most common for 1.25" Rod Ends.
The 3-Link Frame Mount Bracket provides a stable and adequate mounting location for the upper link for the suspension. It mounts far back on the frame and utilizes a link nearly as long as the lowers to give the suspension unmatched articulation.
On the axle side the Front Axle Truss for the 3 Link is the base. When you add this to your axle you not only add strength the the axle, but you also provide a well thought out place to install the Adjustable Upper Control Arm. The Adj. Upper Mount takes the place of the factory sheet metal upper and fork style mount and allow you to run a flex style joint.
**If you are using one of our JK 1 Ton Swap Kits, this system works the same, you simply need to purchase the kit without the truss**
Simply add Springs/Shocks or Coilovers, and extended brake lines and you are dialed in!
AVAILABLE NOW!!
http://www.artecindustries.com/JK_3_Link
ARTEC INDUSTRIES
1-855-ARTEC99 Like us on
Quick Links:
Artec is offline
post #2 of 5 Old 09-01-2015, 10:19 AM
Recharge's Avatar
Awesome! I've been waiting for this. Question, do you need to run the lower control arm brackets with the factory D44? Also, I already have the D44 tuss, is the upper link mount compatible? I assume you just cut the top off the factory mount and weld this on.
Any thoughts about a rear kit?
Recharge is offline
post #3 of 5 Old 09-01-2015, 11:03 AM Thread Starter
Artec's Avatar
You can use the Factory LCA's or use our HD Mounts: http://www.artecindustries.com/JK_Front_LCA_Mounts
If you already have a Truss, you can lop off the Factory UCA Mount on the Passenger Side and attach the Adjustable Link Mount to the top of the Truss. **We do suggest you fill in the open space where the Factory LCA gets cut off with a filler piece to keep water/mud from building up in there**
We will have a rear Kit coming out shortly, but you can build your own from parts we already offer:
http://www.artecindustries.com/JK_Rear_3_Link_Bracket
http://www.artecindustries.com/3-Lin...Kit_p_524.html
As with the front kit you need to add in Coils/Shocks or Coilovers and Extended Brake Lines, but it will also need the Rock Krawler Rear 3 Link Frame Bracket.
ARTEC INDUSTRIES
Quick Links:
Artec is offline
post #4 of 5 Old 09-11-2015, 12:03 PM Thread Starter
Artec's Avatar
If you are looking to do the matching rear, a Kit is not availablle yet, but the parts list is as follows:
http://www.artecindustries.com/JK-Lo...air_p_494.html
For Factory Rear Axles:
http://www.artecindustries.com/JK-Re...uss_p_322.html
Doing a 1 Ton Swap:
http://www.artecindustries.com/JK_1_Ton_Swap_Kits
Ends and Tube:
http://www.artecindustries.com/Rod_End_Parts
Call our Support line if you need help putting it all together! 855-278-3299
ARTEC INDUSTRIES
Quick Links:
Artec is offline
post #5 of 5 Old 10-07-2015, 09:29 AM Thread Starter
Artec's Avatar
Looking for a reason??
How about Free Shipping on Orders over $300 and a Free Artec Shirt?
http://www.artecindustries.com/sale to get full details.
ARTEC INDUSTRIES
Quick Links:
Artec is offline
