JKU Smugglers Floor (coming soon) - JKowners.com : Jeep Wrangler JK Forum
 1Likes
post #1 of 34 Old 06-11-2015, 07:21 AM Thread Starter
Grenadeacorp's Avatar
Another product in the final stages of development we want to share. . Aluminum cargo floor and drop in storage box. The floor is constructed from a single sheet of 3/16' 5052 aluminum and makes for a smooth flat surface for mounting fridge slides, storage boxes etc. The Drop in box is constructed from 5052 aluminum and is a great mod for those who have relocated their factory muffler. Requires surgical removal of the factory cubby. Both the floor and box make for a great secure storage solution for the JKU but could be used as stand alone items. We used ours for installing an onboard air system and it has worked out great. Currently working on production times and pricing.
Secure Concealed Storage for all models of Jeep JK with a hard top, Tactical and expedition gear, Front Runner Vehicle outfitters dealer.
Grenadeacorp is offline
post #2 of 34 Old 06-11-2015, 07:22 AM Thread Starter
post #3 of 34 Old 06-11-2015, 07:23 AM Thread Starter
post #4 of 34 Old 06-11-2015, 09:20 AM
pixeldzn's Avatar
Can you explain how you would mount a fridge slide on this and still have access to the cubby?
- offroad inspired decals for your jeep
2008 Unlimited Rubicon - Silver (Locked and Loaded)
2014 Unlimited Sport - Billet Silver (Mall Crawler)
pixeldzn is offline
post #5 of 34 Old 06-11-2015, 10:16 AM Thread Starter
You wouldn't: that's why I chose to install onboard air inside. Frequent access is not required. Other plans are for the box to be used for a water tank. Using the box as a locking storage would be an option for you if you didn't have a fridge or storage boxes bolted to the cargo floor.
post #6 of 34 Old 06-11-2015, 12:23 PM
j-rod17's Avatar
seal up water tight?
Hilblee likes this.
2008 JKU: continual work in progress
j-rod17 is offline
post #7 of 34 Old 06-11-2015, 12:33 PM Thread Starter
Box seals up with a bulb seal on the bottom of the flange to the body.
post #8 of 34 Old 06-11-2015, 12:47 PM
pixeldzn's Avatar
How about a version with a split in the cargo box cover so that a fridge slide could be in the left and you could still open the cover on the right?
pixeldzn is offline
post #9 of 34 Old 06-11-2015, 01:01 PM Thread Starter
That could be an easy option.
post #10 of 34 Old 06-11-2015, 01:32 PM
Descent's Avatar
Like that
Descent is offline
post #11 of 34 Old 06-12-2015, 12:48 PM
Thantos's Avatar
2 door version?
2014 Billet Silver 2-Door Sport on 37's with a bunch of other expensive chit
Cutts Crew
Thantos is offline
post #12 of 34 Old 06-12-2015, 04:12 PM
GoGetEmTurbo's Avatar
How "surgical" is the OE cubby removal? Just some sheetmetal cutting?
GoGetEmTurbo is offline
post #13 of 34 Old 06-13-2015, 06:58 AM Thread Starter
Correct, fairly strait forward. Sheet metal cutting and and a few spot welds to drill.
post #14 of 34 Old 06-13-2015, 07:00 AM Thread Starter
Originally Posted by Thantos View Post
2 door version?
There are plans for the two door version and I already have a local volunteer for making that happen.
post #15 of 34 Old 06-15-2015, 10:10 AM
Not too bad. I'm a bit tentative to cut a big ass hole in there but I really dig the idea of a bigger storage spot there that is lockable. I have less of a problem drilling holes or cutting the exterior sheetmetal, haha.
What is the noise difference with the new insert? Do you get a little more exhaust noise now? I'll be running a long arm eventually with a turndown after a shorty muffler. Certainly don't want fumes coming in the cab.
post #16 of 34 Old 06-15-2015, 11:14 AM Thread Starter
haha. Completely understand. My wife thought I had gone crazy cutting a huge hole in a perfectly good jeep, she came around after seeing the finished product though
Haven't noticed any noise difference and certainly no fumes. My exhaust exits right above the rear axle slightly turned down. The seal does a good job at keeping water and fumes out.
post #17 of 34 Old 06-17-2015, 02:35 PM
That's great
And I am definitely interested in what pixeldzn mentioned with the split door. Could make it more expensive/complicated but would be great for installs that utilize the storage for items you'd like to access more regularly.
post #18 of 34 Old 07-01-2015, 08:12 AM
WeBeRockin's Avatar
Do you have a picture of the unit itself not installed? Does it interfere with the sway-bar or upper shock mounts at all?
WeBeRockin is offline
post #19 of 34 Old 07-01-2015, 09:39 AM Thread Starter
I'll get you a pic later today. No it does not. It is designed to clear them both.
post #20 of 34 Old 07-02-2015, 12:24 PM
WeBeRockin's Avatar
Pic?
post #21 of 34 Old 07-13-2015, 10:31 PM
MAC7's Avatar
Liking this, updates?
"Government is not the solution, it is the problem."
"We are never defeated unless we give up on GOD."
"Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be protected, and handed on for them to do the same."
Ronald Reagan
Life is 10 percent what happens to you and 90 percent how you respond.
MAC7 is offline
post #22 of 34 Old 07-20-2015, 05:41 PM
MAC7's Avatar
Looked up your website and nothing mentioned about this yet. Any updates?
Ronald Reagan
MAC7 is offline
post #23 of 34 Old 07-21-2015, 12:49 PM Thread Starter
Hey: great talking with you today, will definitely update you when things are looking more solid for production. As I said before our plan is for this to be available in the next couple months. If you ever have any further questions don't hesitate to give me a call.
post #24 of 34 Old 07-21-2015, 12:56 PM Thread Starter
Pic?
Sorry brother: we got extremely busy with a couple events during the last few weeks. I apologize for not getting back to you sooner. This is a rather bad picture, as I said before the box clears both the shock mounts and the sway bar with minimum clearance to maximize box space. There is room for a larger size sway bar if you have one.
post #25 of 34 Old 11-15-2016, 12:24 PM
Any update on these? They'd make a great option for gun storage.
Thanks,
Chris
kewlwhip is offline
