New UNIVERSAL Dual Battery Kit from Genesis Offroad - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 05-17-2015, 09:41 PM Thread Starter
genesisoffroad's Avatar
Genesis Offroad is happy to announce that our new universal dual battery kit was officially launched at Jeep Beach in Daytona.
This kit includes a tray that can be mounted into any application. You can drill holes or weld tabs onto the tray to bolt it into your vehicle or trailer. If you can find a way to mount the tray, you can have all the same great features as our JK kit.
The tray has pressed-in threads to easy secure the top lid with our stainless bolts.
The tray is made to follow the outline of the Odyssey batteries, but any Group 34 size battery will fit.
It uses the same top lid from the JK kit, with the smart isolator, boost button, power and ground bus bars, and the G Screen interface port all pre-wired for you out of the box.
You can wire up this universal kit 3 different ways to meet your needs.
1. Standalone - Only 2 batteries in the vehicle. One designated as cranking, and one as the accessory battery. This is the default option out of the box. This is for vehicles that do not already have a cranking battery under the hood, or if you are removing the cranking battery under the hood and replacing it with our tray. Great for dedicated rock crawlers, race cars, or custom cars that need the batteries relocated.
2. Two accessory batteries and one cranking battery. This is the best option for vehicles that already have a cranking battery under the hood, and allows our smart isolator to manage all 3 batteries. You'll move the 2ga red wire from the right side of the isolator and reconnect it to the red power bus bar. This combines the 2 batteries in the tray at all times. Then run a new lead wire (sold by the foot from the options on our webpage) to your factory positive harness and connect it to the right side of the smart isolator. Now when your cranking battery is above 13.2v, the smart isolator will connect all 3 together, giving you even more run time. We recommend using 3 identical batteries for best results. Great for adding extra accessory power to your RV, boat, camper, trailer, etc.
3. Two cranking batteries and one accessory battery. This option is best for heavy duty vehicles that need a lot of cranking apps to start the engine, or for vehicles in cold weather conditions. Simply connect your lead wire (sold by the foot from the options on our webpage) from the factory positive harness to the positive post clamp with the wing nut on our kit. This links one battery in our tray to the cranking battery under the hood at all times. Again, when they are above 13.2v, all 3 batteries will be connected, giving you even more cranking power. We recommend using 3 identical batteries for best results. Great for diesel motors, tractors, service vehicles, etc.
If you need to mount the tray in the back of a Jeep or in the bed of a truck for example, you can order the heavy duty 2ga welding cable lead wires by the foot from our website. We also offer a couple options for the ring terminals on the end. The most popular option is the heavy duty tinned-plated copper lugs, the same ones we use on the wires included with the kit, shown below. These lugs can be soldered or crimped to the wire. They also come with high quality 3M adhesive-lined heat shrink.
We also offer the Magnalug Fusion lugs from Quick Cable. These are severe duty lugs that are twice as thick as the normal lugs. They also have flux and solder preinstalled inside the terminal, allowing you to easily install onto your wire with a torch.
Here you can see a comparison of the Magnalug Fusion vs the normal heavy duty tin plated copper lugs.
For more details, please visit our website: http://www.genesisoffroad.com/Univer...p/151-udbk.htm
For the Jeep JK version, please visit this page: http://www.genesisoffroad.com/JKDual.../131-jkdbk.htm
For our Australian, South African, and UK friends, the right hand drive version is available here: http://www.genesisoffroad.com/RHD-Je...-jkdbk-rhd.htm
Kits are in stock for immediate shipping! No waiting!
Join us on
901-214-JEEP (5337)
genesisoffroad is offline
post #2 of 2 Old 06-22-2015, 09:11 PM Thread Starter
Here's a new video shot at the Unlimited Off Road Expo explaining all the features of the universal kit.
We're running a cool rebate program for the early adopters. We want to see how the universal kit is being used in various different vehicles. The first 10 people who buy the kit and then send us some pictures of the final installation and details about your rig that we can share on our website, we will kick back a $100 rebate.
Obviously we know this is a JK forum, so it may be hard to find some takers for this deal here, but if you have a buddy with a rig that needs dual batteries, pass the word along to them!
Join us on
901-214-JEEP (5337)
