09 JK Popping out of 1st gear - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 05-24-2009, 10:17 AM Thread Starter
So in the last few weeks my 09 JK has been popping out of 1st gear, during take off from stops between 10 and 15 mph. as you may think makes a great noise and rattles the whole freaking vehicle. This past week I had my wife drop the jeep off at a local dealer this event actually took place while she was pulling into the dealership drive thur it happened.
The dealer locaed in northern Kentucky says this is not happeneing and that there is nothing wrong with the vehicle. I love the NPF commitment for the dealer. So I am askeing has this happened to any of you?
Vehicle stats 09 X 6 speed. rubi bfg shocks and springs. no other mods.
the dealer did put 7 miles on it and I have had a previous 5 speed. and manual transmission vehicles for 10 years..
they seem to think I do not know how to drive a stick lol....
again thanks,
Bill
RSVbill is offline
post #2 of 6 Old 05-24-2009, 01:23 PM
qqq
qqq's Avatar
they know
the probleme is the shifter boots the one underneat the consol , the ruber boot is to thick, jeep dealer have receive a note about that, a jeep employes toll me they cut mine ok now?
qqq is offline
post #3 of 6 Old 05-24-2009, 05:06 PM
Moose512's Avatar
Probably the case, I did not have any issues when I was stock but when I had a 1" body lift installed I had that issue with 2nd and reverse. I cut the inner boot a little and after a little break in the problem was resolved.
Moose512 is offline
post #4 of 6 Old 05-25-2009, 07:51 PM
YES.
This has happened to me three times in the past 2 weeks Its like there is something blocking the shifter from getting it all the way into gear, then POW - WTF??!!??
Post back if you get this solved.
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
Dancin Dan is offline
post #5 of 6 Old 05-26-2009, 11:16 PM
Roland's Avatar
07 JK 6 speed and yes it has happened to me. Mine seems to only occur when I first get started (in the morning) and only happens once like it is cold or something. It may only happen once because it really pisses me off and then I make sure it is in gear fully. The boot thing sounds viable if it happened all the time, but not sure I believe it yet. Got to take a look.
Roland is offline
post #6 of 6 Old 05-27-2009, 05:14 AM
thaduke2003's Avatar
Easy test: If it happens when cold, simply pull back to second and shove it forward to first, and you should be golden- it could simply be that the synchro rings aren't lined up, and are blocking your entry into first gear Try it. If it fixes it, I accept payment in cash and beer
If that doesn't fix it, try adjusting/cutting the boot as necessary- another easy test there is to fully remove the boot and see what happens.
If THAT doesn't fix it, you may have a physical synchro or gear issue, and THAT needs to be checked out ASAP- Mark W.
thaduke2003 is offline
