fast ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 05-19-2009, 01:33 PM Thread Starter
fast ?
i am trying to figure out how much of a rake my rubi has, how is the proper way to do it? and another dumb question can i fit 33's without a lift on a 2007 4 door rubi?
jchmelo is offline
post #2 of 20 Old 05-19-2009, 01:43 PM
MaRShiN's Avatar
Pretty bad, doggy style or jackhammer, and yes
Few companies out there have "JK leveling kits". If all you want is to get rid of the factory rake, throw some spacers in the front, toss those 33's on (probably need spacers if going on the stock rims) and call it a day.
nah nah nah nah nah nah, I made you eat your parents - E.Cartman
MaRShiN is offline
post #3 of 20 Old 05-19-2009, 01:49 PM
Openly Hostile
It's not lift you need to keep 33's from rubbing, it's bump stop extensions.
Jason
SDMF is offline
post #4 of 20 Old 05-19-2009, 01:50 PM Thread Starter
what if they are goin on new rims with 5.00 bs
jchmelo is offline
post #5 of 20 Old 05-19-2009, 04:17 PM
Gunny's Avatar
This is what I 'm using till I get my lift.
Gunny is offline
post #6 of 20 Old 05-19-2009, 06:03 PM
TrailDuty.com
PhilD's Avatar
That's a lot of BS, they may still rub especially when flexed.
PhilD is offline
post #7 of 20 Old 05-19-2009, 06:05 PM Thread Starter
then whats a good bs?
jchmelo is offline
post #8 of 20 Old 05-19-2009, 06:14 PM
From what I've heard and read, 4.5" BS with what you already have will help you avoid 99.9% chance of rubbing.
4" and there's absolutely no chance you'd rub, no matter how much flex.
Correct me if I'm wrong?
SilverX is offline
post #9 of 20 Old 05-19-2009, 06:15 PM
TrailDuty.com
PhilD's Avatar
That would sound about right for that setup, although I'm always reluctant to say "absolutely no chance"
PhilD is offline
post #10 of 20 Old 05-19-2009, 06:31 PM
jacktuttle's Avatar
Lightbulb On the Other Hand
A 2.5" BB Lift from TeraFlex is less than $300.00...... Then the 33's are no issue.
jacktuttle is offline
post #11 of 20 Old 05-19-2009, 06:40 PM Thread Starter
what about an offset of -12mm? would they fit with a 1.25 or 1.5 inch wheel spacers?
jchmelo is offline
post #12 of 20 Old 05-20-2009, 04:54 AM
TrailDuty.com
PhilD's Avatar
Backspacing is what you need to know, which you can calculate if you have offset and rim width. What rim width?
PhilD is offline
post #13 of 20 Old 05-20-2009, 04:56 AM Thread Starter
its a 17x9 so 9.....
jchmelo is offline
post #14 of 20 Old 05-20-2009, 05:07 AM
TrailDuty.com
PhilD's Avatar
9" wide and -12mm offset = 4.5" backspacing
PhilD is offline
post #15 of 20 Old 05-20-2009, 05:22 AM Thread Starter
so i could run them without a lift then? or would it still be better to run some spacers?
jchmelo is offline
post #16 of 20 Old 05-20-2009, 05:57 AM
BigO's Avatar
With those rims and spacers added, your tire tread is going to be sticking out between 3" or 4" beyond your flares. Also, you're going to be spending around 200 bucks plus shipping for a set of 4 spacers.
If I was in your shoes, I'd put the 33's & new rims on and see what happens. If you get rubbing while flexing, then either add bump stop extensions or get a budget lift as mentioned above. Spacing the wheels out further to avoid rubbing is not the way to go in my opinion.
Who knows, all you may really need is front coil spacers to get rid of the rake to keep from rubbing. Stock Rubicon tires are only 1" smaller in diameter than what you want to buy.
'07 Rubicon
BigO is offline
post #17 of 20 Old 05-20-2009, 06:03 AM
TrailDuty.com
PhilD's Avatar
X2
Depends, when you get to a certain tire size you'll have to move out to avoid rubbing, regardless of bump stops or lift, but I'm not 100% if that will happen with 33's. Best thing to do would be as BigO suggests and see what happens.
PhilD is offline
post #18 of 20 Old 05-20-2009, 06:07 AM
BigO's Avatar
Correct. I should have added "in your situation" to my previous post.
'07 Rubicon
BigO is offline
post #19 of 20 Old 05-20-2009, 08:50 AM Thread Starter
thats great thanks guys you all are a big help !!!
jchmelo is offline
post #20 of 20 Old 05-20-2009, 11:49 AM
tazzman121's Avatar
I have been considering the same thing on my 2009 rubi. I do not believe that the 33 part will be a problem. The stock tires on mine are 255/75/17 which is 32.06 tall and 10.04 wide. One thing to look into is, are the 33 that you are looking at actually 33in tall. Many tires saying 33 are not actually 33in tall. What if I wanted to put on 33 x 12.5 would 4 bs be enough without a lift? A small left is on my list but the wife is only 4ft 10 and already has a hard time getting in.
tazzman121 is offline
