OD button doesn't work after Hemi install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 09-21-2012, 05:43 AM Thread Starter
v10kingsnake's Avatar
Is that normal? I just took possession of my BOR kit Hemi JK and so far, the only factory feature i've noticed not working is the dummy button on the console. Everything else is as advertised as working. Auto-start, cruise control, etc... Just not the OD button. BOR doesnt open for an hour but I was wondering if anyone here knew. Likely not going to be a concern when the 5.13 gearing is completed next month but if it is supposed to work and its not, I would like that addressed.
2009 Sahara Unlimited. 5.7L Hemi truck setup. Rock Krawler 5.5 coil over LA. Maxxis Trepador 40's . ATX Rims, XRC front rear and side armor. RROR Crusher corners, RROR flat flares. Warn XD9000i. Prorock 44 with RCV shafts. 5.13 gears, ARB front and rear lockers.
v10kingsnake is offline
post #2 of 5 Old 09-21-2012, 05:45 AM
sixty5vdub's Avatar
Mine works. But I used an AEV DIY kit. I am not sure what kit BOR uses.
AMP
AMP
sixty5vdub is offline
post #3 of 5 Old 09-21-2012, 05:55 AM Thread Starter
AMP
Interesting...
Thanks for the info. Anyone else?
post #4 of 5 Old 09-21-2012, 06:55 AM Thread Starter
Dans the man!
Just got word that my installer must have skipped that step!
It does work with their kit too when you connect the damn wire to the pcm.
post #5 of 5 Old 09-21-2012, 07:42 AM
sixty5vdub's Avatar
Glad that they got is sorted out.
AMP
AMP
