Linear vs. progressive springs - JKowners.com : Jeep Wrangler JK Forum
post #1 of 24 Old 09-20-2012, 05:08 PM Thread Starter
ChryslerChris's Avatar
I know the difference between linear and progressive springs: one has a set rate from rest to full compression, while the other has two rates: the first one is much lower and comprises 1/6 of the coil length and once that bottoms out the higher rate kicks in the rest of the way.
What I wanted to understand, however, is what benefit does a progressive rate spring give you aside from a longer stretched length so that the coil doesn't come unseated during full flex?
I am thinking about switching from my linear rough country springs to a similar lift height progressive spring set (favoring metal cloak at this point). What would be the differences in ride quality, sag and flex be?
Any input from experience is welcome, especially vendor input since you sell suspensions. Thanks!
Jeeping: The art of getting dirty and going broke while slowly heading nowhere, and taking all day to do it
2011 JK Sport. Detonator Yellow. RC 3.5 Series 2 lift, 35 inch BFG TA K/O's, RC front winch plate and Smitty XRC8 winch, bedlined tub, 5.13's, Aussie front, Truetrac rear, Teraflex Speedbumps... and NO STICKERS!
ChryslerChris is offline
post #2 of 24 Old 09-20-2012, 05:39 PM
bthomas's Avatar
ive noticed that my springs (2.5 progressive rk) have about 2-2.5" gap between coils vs rc that look like 1-1.5" between coils. that alone would allow for more compression under a really hard bottoming out.
bthomas is offline
post #3 of 24 Old 09-20-2012, 06:15 PM
Rob50lx's Avatar
I think the MetalCloak springs are "dual rate" springs. They are not the same as most other progressive rate springs. I can't tell you the differences/benefits between the 2 different types of springs.
Rob
Sent from my HTC Glacier using Tapatalk 2
2009 Sunburst Orange Rubicon, 2dr, 6spd.
PSC BFH front bumper, Motobilt rear frame chop bumper, GenRight Rocker guards, Metalcloak Overline Fenders, 3.5" Metalcloak lift with 6pak shocks, 37" Cooper STT Pro
Rob50lx is offline
post #4 of 24 Old 09-20-2012, 06:38 PM
There a some threads on the metalcloaks springs, like pages about them. I'm saving to get a set of 'em.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #5 of 24 Old 09-20-2012, 07:37 PM
HeloJeff's Avatar
Pages 8-12 of this thread go into a lot of detail about the different types of coils
https://www.jkowners.com/forum/showth...al+cloak+build
Have to skip through some of the bs but there is a lot of good info in that thread.
HeloJeff is offline
post #6 of 24 Old 09-20-2012, 08:25 PM Thread Starter
I've since starting snooping around on other forums as well, and it appears that almost all "progressive rate" springs offered on JK's are actually dual-rate. True progressive rate springs, it seems, not only have varying coil spacings, but also varying diameters as the coil winds down. Fairly complex and expensive stuff. I'll let the vendors confirm that.
Just judging from what I've read so far, here and on Jeep-Forum, Wrangler-Forum and Pirate4x4, there really shouldn't be a difference between linear and dual-rate/progressive springs aside from popping off their perches if flexed too far (linears will, dual rates won't)
But I wonder how a dual-rate helps with sag? Does the higher rate portion of the spring resist heavy loads better?
post #7 of 24 Old 09-20-2012, 09:07 PM
SlvrJK's Avatar
Having run 3 different sets of linear springs from 3 different manufacturers (factory,OME,and Teraflex) and then swapped them out for Synergy/Poly progressive springs...it's like night an day. The ride quality of the poly springs is great, the harder I push the suspension the smoother they seem to get. And more importantly they aren't sagging like my old springs did. So it was the right move for me.
SlvrJK is offline
post #8 of 24 Old 09-21-2012, 03:09 AM Thread Starter
Cool. Thanks for that input. Wasn't sure if I should take the leap or not but that may have sold me. You're the 2nd guy who endorsed poly springs. My buddy did too.
post #9 of 24 Old 09-21-2012, 11:24 AM
lohchief's Avatar
My only experience with progressive spings were on my harleys and they make a world of difference....all good.I used them in the front end and used progressive rate shocks on the rear.It was well worth it from a 2 wheel point of view for sure.
lohchief is offline
post #10 of 24 Old 09-21-2012, 01:20 PM
I know that the AEV springs are triple rate. I am not sure how the ride quality varies between a dual and triple rate spring, but I do like prograssive springs much more than the linear springs I have run before.
Jon
08 Rubicon
JeepinJon is offline
post #11 of 24 Old 09-21-2012, 03:08 PM
TeraFlex's Avatar
There will be a TeraFlex video on this.
801-713-3314
TeraFlex is offline
post #12 of 24 Old 11-06-2012, 04:00 AM
kjeeper10's Avatar
I switched out my Tf springs for RK and it made a big difference in ride.
RK uses a front progressive/rear linear.
kjeeper10 is offline
post #13 of 24 Old 11-06-2012, 05:22 AM
2k2wranglerx's Avatar
i'm a big fan of progressive springs. BUT, i will say, the Offroad evolution 4" springs ride AWESOME and they're linear.
keep in mind on a progressive spring you're almost always riding on one spring rate.
2k2wranglerx is offline
post #14 of 24 Old 11-06-2012, 06:17 AM
bgall's Avatar
Last time we had mine off the jeep we were looking at them beside a friend's teraflex springs. We counted coils and realized that my progressives (3.5 AEV) had 5 more coils. When fully compressed, more coils = less up travel. Just something to consider when fine tuning bump stops and stuff.
bgall is offline
post #15 of 24 Old 11-06-2012, 07:07 AM
ALASHA's Avatar
Not always true. The thickness of the coil itself plays a role.
ALASHA is offline
post #16 of 24 Old 11-06-2012, 10:59 PM
Topgun863's Avatar
Spring rate and type of spring (linear, progressive, dual rate) is a very complex topic that can be rather difficult to explain. Like a few have said here there are pages and pages where it's been discussed on here. Many factors determine the type of spring ie: coil rate, coil diameter, distance between coils, type of steel, diameter of the steel used to make the springs, temper, etc. progressive rate coils are usually ones which offer a varying spring RATE and usually achieve this by winding coils that are close together on one end and progressively get farther apart. Progressive rate sprigs constantly change spring rate as they compress. This is because they are designed so that the spring compresses all of the coils move the same distance, thus causing the coils that are closest together to collapse on to each other and as they do that they almost become solid and are no longer actively part of the spring and thus making the spring stiffer. Dual rate springs are technically another type of progressive rate spring except that instead of having a continually changing rate they have two distinctive rates usually accomplished by part of the spring being wound with coils closer together (the same distance apart for this rate) and another part with coils that are farther apart (the same distance apart for all the coils in this section). This was a pretty brief explanation and much more info is out there on this, but hopefully this will give you an idea of the concept.
Benefits to a progressive or dual rate spring would be softer and better ride quality at normal ride height, and better suspension response offroad. They tend to flex a little better, and function in somewhat of a similar method to a dual rate coilover. They are often used in offroad race applications as well as it helps absorb hard hits to the suspension when going fast offroad, because as the axles travel upward, the rate increases, thus dampening the bumps (good shocks and air bumps should be used if you intend to do this however as they also play a role)
07 X 2dr- 6spd
Topgun863 is offline
post #17 of 24 Old 11-07-2012, 06:18 AM
bgall's Avatar
You are absolutely correct. The springs we compared (AEV and Teraflex) were close enough in thickness for it to be statistically insiginificant. Hence my comment that it is something to consider when setting up bumpstops. Now I am curious as to spring thickness of the various springs. My guess is that they are mostly going to be pretty close in material thickness.
bgall is offline
post #18 of 24 Old 11-07-2012, 06:40 AM
WranglerJR83's Avatar
Progressive rate springs give a better ride by allowing the softer rate absorb bump at high speed. This allows you to ride offroad at higher speeds without being beat to death. They just did a great info session on it on extreme 4x4 like 2 weeks ago. They did everything from breaking down regular coil springs to calculating spring rate for coil overs.
Sent via evil monkey!
"If you don't drive a Jeep, !#(% you! - Ricky Bobby
"all that is necessary for the triumph of evil is that good men do nothing." - Edmund Burke
2007 JKU - 2.5 RC, Teraflex LK, 315/75R16 Cooper Stt
1995 YJ - stock on 32x11.5R15 SS TSL-R
WranglerJR83 is offline
post #19 of 24 Old 11-07-2012, 11:05 AM
cloaked willys's Avatar
The thread in this link gives full explanations of all 3 types of springs. Pages 8-9 have the spring info.
https://www.jkowners.com/forum/showthread.php?t=71064
MetalCloak, It's Your Jeep, Only Better
Will (916)631-8071
Originally Posted by -SLADE- View Post
Metalcloak claims to have the highest clearance flat fenders and their Duroflex joints appear to bridge the gap between stock clevite bushings and re-buildable joints making them a great option for daily drivers. Metalcloak's dual rate coils actually backup the available travel in their suspension instead of just making claims of "flex" and "max travel" only to provide short coils with little travel like some have done.
cloaked willys is offline
post #20 of 24 Old 11-08-2012, 10:02 PM Thread Starter
That was an excellent write up by the MC guy! Thanks for the reference! That was the answer I needed.
post #21 of 24 Old 11-22-2012, 09:45 PM
Hello, I am Aleks.
I just got Jeep Wrangler Sahara 2013, already start back pain. Could you please email me a link you did order Synergy Poly Progressive Springs,
Thank You
Need smooth ride asap.
nkahovka is offline
post #22 of 24 Old 11-22-2012, 09:47 PM
Progressive springs
Hello, I am Aleks.
Thank You
nkahovka is offline
post #23 of 24 Old 11-22-2012, 09:49 PM
kjeeper10's Avatar
Originally Posted by nkahovka View Post
Hello, I am Aleks.
Thank You
Hey Aleks.
Your jeep is stock I assume ?
Can't get much more cushy than the stock setup.
Have you looked at changing the shocks ?
post #24 of 24 Old 11-24-2012, 04:31 AM
12xu's Avatar
Hello, I am Aleks.
Thank You
Drop some air pressure.
The sidewall has the max rating, that's not what the optimal ratting is.
I find most places will blow your tires up to 45lbs of pressure or more.
Try high 20's.
Or do the chalk test to to see what the optimal tire pressure for your jeep/ tire is.
12xu is offline
