Has anyone had issues after using superchips flashpaq? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 26 Old 09-20-2012, 03:38 PM Thread Starter
I have a 2010 jku & have installed the superchips flashpaq on it. I also have an airraid intake & a gibson performance exhaust on it. I'm having issues holding a steady rpm while driving. I was wondering if anyone else had these issues or knew what to do to fix it.
kyakman24 is offline
post #2 of 26 Old 09-20-2012, 03:42 PM
Fklein6768's Avatar
What tune are you running and how long have you been running it?
Is this thing on?
www.4x4s-pod.com
Fklein6768 is offline
post #3 of 26 Old 09-20-2012, 03:49 PM
j-rod17's Avatar
Is this thing on?
yes. this.
when i put mine on 93 tune at the beginning...I had running issues.
I put it on 87, ran a full tank of 93 through it. then filled again and retuned. it was good then
j-rod17 is offline
post #4 of 26 Old 09-20-2012, 03:52 PM Thread Starter
I'm running the 87 tune on it. I've been running it for a few weeks.
post #5 of 26 Old 09-20-2012, 03:57 PM Thread Starter
I might have to try that 93 tune trick. I wonder why it would take that get it to work right though...
post #6 of 26 Old 09-20-2012, 04:05 PM
Fklein6768's Avatar
I had some surge/idle hicupps then went w the tow tune and its much better now. Running a snorkel w a viper TB so I don't know if that impacts it or not either. Play around w the tunes/gas and see if there are any differences.
Is this thing on?
www.4x4s-pod.com
post #7 of 26 Old 09-20-2012, 04:12 PM Thread Starter
I'll play around with the other tunes & see if it still has those issues. I appreciate the input.
post #8 of 26 Old 09-20-2012, 04:39 PM
JK Timmay's Avatar
I've had hesitation issues with it on my 2008. It runs really cold blooded in the morning. I'm back to stock at this point and it's much better.
Tim
JK Timmay is offline
post #9 of 26 Old 09-20-2012, 04:57 PM Thread Starter
I'm rolling on 35's too and I've seen an increase in power & gas mileage. The intake whistles when I give it gas; which I'm told is normal, but those surges I get while driving can't be good on gas in the long run.
post #10 of 26 Old 09-20-2012, 05:22 PM
spookylynx's Avatar
could just be the factory gearing and 35's I run my '10 on the 87octane and roll 37's with stock 4.11 gearing. The RPMs jump up and down all the time if I'm trying to drive too fast. especially when climbing big hills. Untill I get it re-geared I have just accepted having to drive a bit slower.
spookylynx is offline
post #11 of 26 Old 09-20-2012, 05:32 PM
j-rod17's Avatar
Mine did this jumping from 4-5 in the auto. I turn the OD off and it stays in 4th. 2,500 RPM in fourth at 70 MPH and my gas mileage improved as its not searching for gear.
j-rod17 is offline
post #12 of 26 Old 09-20-2012, 05:32 PM Thread Starter
I'm running the stock 3.73's in my on level ground & it's still jumpy when I'm driving normal. The odd thing is...it has the 4.0 engine hand written on the outside of the box & I'm rolling the 3.8. I wonder if that might have something to do with it.
post #13 of 26 Old 09-20-2012, 05:35 PM Thread Starter
I would assume that's what the tune has done is make those shift points closer.
post #14 of 26 Old 09-21-2012, 08:58 AM
On my '07 my idle is slightly rougher than it was pre-tune, but nothing I'm concerned about. I am using the mileage XS tune although I doubt it's actually doing me any good. I noticed a similar effect when I had the tuner on my WJ but it was more obvious.
I just updated my tuner again (which I forgot to do prior to switching it from the WJ to the JK) so I may try to reflash again this weekend and see if it smooths out.
phase888 is offline
post #15 of 26 Old 09-22-2012, 06:57 AM
jtphoto JK's Avatar
At what speed are you having the serge. Around 30mph mine surges because it shifts into 3rd and idle drops to 1000rpm and the throttle is very touchy down there. Any faster then that there is no serging.
Did you set your throttle response, speedo limiter and rev limiter or just plug in a tune.
I run Tow Tone on 91 octane 35s on factory 3:73 gears. This gearing is in an odd place for city driving with the 35s, 2nd is Not enough gear and 3rd is to much, gear change would help this. On the highway run O/D off for best performance and economy.
Jeff _(OllllllO)_
jtphoto JK is offline
post #16 of 26 Old 09-22-2012, 02:16 PM Thread Starter
I'm having the issue from 25mph on up to about 50mph. Because I have that performance exhaust, I can hear the engine surging. The tach doesn't move too much when it surges, but it's definitely noticeable. The throttle is much more touchy than usual as well. It does actually level out and not surge anymore when I'm at highway speeds. I might have to try one of the other tunes to see if it surges during those as well. I wonder if superchips has an update for intake and exhaust? I plan on putting 5.13 gears in there eventually, so maybe that will help too.
post #17 of 26 Old 09-22-2012, 03:54 PM
lohchief's Avatar
After doing the exhaust,and intake on my 08 I bought the superchips flashpak and installed the 87 tune.No problems at all and it helped calm down the fly by wire electronic throttle.When I had to take my jeep in for one of the recalls I took the tune out.When I got my jeep back they took care of the recall thing,then told me they updated the engine computer with a software update or upgrade...whatever.On the 35 mile trip home,my throttle was damn near perfect,the engine ran smoother,and I got a bit better mpg.I never put the 'tune' back in because whatever they did at the dealership worked better then the flashpak,so I sold it.
lohchief is offline
post #18 of 26 Old 09-22-2012, 04:13 PM
HighTower's Avatar
I have a 10 auto JKU on 35s and I think I'm having the same issue as you. When its happening are you in OD and is RPMs around 1500? If so I think it's the jeep on the edge of shifting into OD. If a hit the OD button the RPMs go up and I don't hear it until I go back into OD.
Sent from my imagination.
2010 JKU Sahara
Teraflex 2.5 Coil Lift w/ 9550 Shocks
Teraflex Quick Disconnects
Moto Metal 17" 950s
Nitto Trail Grapplers 35x12.5x17
Superchips Flashpaq
HighTower is offline
post #19 of 26 Old 09-22-2012, 04:53 PM Thread Starter
When did you have the upgrade done. I just bought my jeep about two months ago so I don't know if one needs to be done on mine.
Yes, I have OD on & it is about 1500 rpms. I'll try to turn it off to see if that helps. I'd like to have it on though cause I've picked up about 3 mpg with the tune & other upgrades. I'm getting 17 mpg even with the surge issue.
post #20 of 26 Old 09-22-2012, 05:26 PM
newmango's Avatar
I just got my flash pack last week, running the 87 tune with AFE cai and home made magnaflow cat back, night and day diff. Can't believe I waited this long to get it. ( thanks Brian) no probs so far. I am also running 33` s and 321's.
Sent from my Nexus 7 using Tapatalk 2
EX-JC
newmango is offline
post #21 of 26 Old 09-22-2012, 05:32 PM
HighTower's Avatar
For my JKU it has 3.73 gears K&N drop in filter and MBRP off road cat back exhaust. I thought it may have been the exhaust with some weird kind of drone but after swapping the muffler to one with a different internal design there were still no changes. I'm running the 87 tune now but when I did run the 93 it happened but not as often. I've yet to get a hold of Superchips support to see if its an issue that can be fix by modifying the tune or maybe seeing if upgrading to the transmission package I would just have to change that shift point for OD if possible.
2010 JKU Sahara
Moto Metal 17" 950s
Superchips Flashpaq
post #22 of 26 Old 09-23-2012, 12:54 PM Thread Starter
I turned OD off & it didn't do it anymore. But I can't drive around on 35's with it turned off. I'm very interested to see what or if superchips has to say about that. I'll try to contact them as well. If they tell me what to do, I'll definitely pass it along .
post #23 of 26 Old 09-23-2012, 03:36 PM
j-rod17's Avatar
with my 35's, 3.73, tuner, and OD off I still hit 15MPG travel 70mph on interstate. no issues.
once i gear I will get OD back.
j-rod17 is offline
post #24 of 26 Old 09-23-2012, 06:01 PM Thread Starter
That's good to know cause I'm running the same. What gear set are you changing to?
post #25 of 26 Old 09-23-2012, 06:14 PM
HighTower's Avatar
I'm also the same here with 15 MPG with OD off. I make sure not to use cruise control either.
2010 JKU Sahara
Moto Metal 17" 950s
Superchips Flashpaq
