seat belts flap when doors are off its annoying - JKowners.com : Jeep Wrangler JK Forum
post #1 of 49 Old 09-14-2012, 08:36 PM Thread Starter
jknewgirl's Avatar
Any ideas on how to keep the seat belts from flapping when the doors are off? Does anyone else have this problem? It makes it hard to talk to people while your driving
jknewgirl is offline
post #2 of 49 Old 09-14-2012, 08:38 PM
Mr.RonGilbert's Avatar
Bungie cords are your friend... you can get the little black ones at a hardware store. I use one on each seatbelt and life is good.
Some of that double sided velcro tape stuff would work good as well..... hardware store about 9 bux a roll... would be more than enough.
Mr.RonGilbert is offline
post #3 of 49 Old 09-14-2012, 08:39 PM
lunneborgc's Avatar
Velcro strips from home depot or lowes. Cut them to length and wrap them around the roll bar
2011 Green JK Rubicon Unlimited Purchased 10/18/2011
Previous Jeeps include a 99 TJ Rock Crawler, 74 CJ-5, 06 TJ Rubicon, and a 2001 TJ
lunneborgc is offline
post #4 of 49 Old 09-14-2012, 08:39 PM
PhrogMech46's Avatar
Velcro straps from lowes
See Garage for Mods
PhrogMech46 is offline
post #5 of 49 Old 09-14-2012, 09:01 PM Thread Starter
jknewgirl's Avatar
Thanks guys! I'll see which way i like the best!
post #6 of 49 Old 09-14-2012, 09:54 PM
I just slide it in the seat adjuster handle on the side of the driver seat. FREE!
Ed Shenck is offline
post #7 of 49 Old 09-15-2012, 06:25 AM
2010jk's Avatar
^^^ this is how I do the driver side. the pass side I just take the down belt / shoulder belt and pull it over the head rest. Hope you get what I mean. But be care full when you use the the driver belt in the flip leaver, as over time the leaver will come off, When mine did that I just glued it and has never come off.
2010jk is offline
post #8 of 49 Old 09-15-2012, 06:37 AM
FireTrail741's Avatar
I've read of people cutting a slot in the plastic and putting the belt inside the B pillar plastic.
FireTrail741 is offline
post #9 of 49 Old 09-15-2012, 08:02 AM
.:eMETAL:.'s Avatar
velcro or bungie cords... either way is good, plus you never know when something like that may come in handy on a trail and then you have them!
.:eMETAL:. is offline
post #10 of 49 Old 09-15-2012, 08:23 PM
djkbooth's Avatar
if you go to walmart or auto part store and buy the cheap velcro seatbelt pads that are like 8 inches long that go around the belts and put them on the flapping part, problem solved and the belt will slide freely in them when buckling and unbuckling, thats what i did
djkbooth is offline
post #11 of 49 Old 09-15-2012, 09:19 PM Thread Starter
jknewgirl's Avatar
thanks! now I have so many choices!
post #12 of 49 Old 09-15-2012, 09:53 PM
illyb's Avatar
Also free: just turn up your radio louder.
In all seriousness, the folks on this thread have given some good advice for cheap solutions to your problem. I've run the velcro solution for a while now, though with my new four points I don't need velcro any longer.
illyb is offline
post #13 of 49 Old 09-16-2012, 03:25 AM
D5Fire's Avatar
Send a message via Yahoo to D5Fire
Pull the B pillar trim out and run the inside portion of the belt in that, mine already has a groove at the bottom so there was no cutting done to the trim piece.
Fortis cadere, cedere non potest
Poison Spyder BFH w/ trail stinger, custom rear BFH, crusher flares, rocker knockers, evap skid, hood louver. Rock Krawler 2.5 Max Travel, Teraflex rear tire carrier, River Raider cowl snorkel,Warn VR 10,000 lbs winch, sPod, Rigid 50"SR.
D5Fire is offline
post #14 of 49 Old 09-16-2012, 06:43 AM
chasman's Avatar
Under 10 bucks and 10 minutes............
chasman is offline
post #15 of 49 Old 09-16-2012, 08:18 AM
This is the best way. It's free and easy to do. It works on both sides and the seat belts still retract mostly normally. If there is too much tension don't put the clips in back all the way.
Mike
'07 2 door soft top
Espo78 is offline
post #16 of 49 Old 09-16-2012, 08:23 AM
Here is a pic of what I'm talking about...tried to upload it but I guess it was too big so I had to host it.
Mike
'07 2 door soft top
Espo78 is offline
post #17 of 49 Old 09-16-2012, 08:38 AM
Nucknphuts's Avatar
You can also use the velcro straps that come with the vehicle from the factory, although if you bought used they are probably long gone. I used some KAVU large velcro watch bands.
Nucknphuts is offline
post #18 of 49 Old 09-16-2012, 11:47 AM
axsys's Avatar
I also did this. Bonus is that when the doors go back on you can strap them around the armrest for some extra padding.
axsys is offline
post #19 of 49 Old 09-16-2012, 12:01 PM
jeepRcreepR's Avatar
I just clip them into the buckle. Problem solved.
07 JKU Rescue Green with 3.5" RK Mid-Arm Flex w/ Bilstein 5100s, 5.13's, Eaton E-Locker, 35" MT Baja ATZ, 17" DC Torque wheels, Monstalined tub, Home-made front bumper with Smittybilt XRC-8 winch, Wild Boar rack w/ IPF 968 lights, K&N Intake, Gibson Exhaust.
Future Mods: 2wd-4wd conversion = completed!
jeepRcreepR is offline
post #20 of 49 Old 09-16-2012, 12:05 PM
txjeeplover's Avatar
This is the way I tackled this issue. Quick, cheap, and you won't alter or disturb the safety recoil/emergency tightening feature of the belts or the interior of the JK.
2008 2 Door Rubicon
4" Zone Lift
15x10 Ion 138
35x13.50R15 Toyo Open Country MT
A bunch of other stuff done and yet to do
txjeeplover is offline
post #21 of 49 Old 09-16-2012, 12:08 PM
If you are suggesting that putting the belt inside the plastic trim like I pictured above somehow makes them unsafe you would be mistaken. The seatbelts act as designed.
Mike
'07 2 door soft top
Espo78 is offline
post #22 of 49 Old 09-16-2012, 05:30 PM
v10kingsnake's Avatar
Exactly.
2009 Sahara Unlimited. 5.7L Hemi truck setup. Rock Krawler 5.5 coil over LA. Maxxis Trepador 40's . ATX Rims, XRC front rear and side armor. RROR Crusher corners, RROR flat flares. Warn XD9000i. Prorock 44 with RCV shafts. 5.13 gears, ARB front and rear lockers.
v10kingsnake is offline
post #23 of 49 Old 09-16-2012, 05:43 PM
Originally Posted by v10kingsnake View Post
Exactly.
You two have obviously not driven with the doors off or at times with the windows down!
post #24 of 49 Old 09-16-2012, 05:45 PM
The cut in the B pillar plastics is for the 2011's+.
post #25 of 49 Old 09-16-2012, 07:26 PM
D5Fire's Avatar
Nope mines an 09 and it has the cut there from the factory
D5Fire is offline
