Front coilover over axle? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 09-07-2012, 04:13 AM Thread Starter
Does anyone make front coilover brackets that mount directly over the axle where the coil normally sits instead of the shock location?
Would there be any problems with a setup in that location apart fom relocating the washer bottle and cutting up some of the plastic tray?
Just makes more sense to me being there, plus might need the extra wheel clearence.
Cheers.
MonkeyNuts is offline
post #2 of 2 Old 09-07-2012, 05:25 AM
frankie945's Avatar
I was going to mount mine on the upper C but after looking at the angles and how much higher I would have to place the upper mount I decided not to. I'm running a full width axle so I have no rub issues what so ever, mine are mounted flush at the bottom of tube. If you want to place them on top of the tube then like u already know you have to make room up top for the towers or hoops what ever u plan on using. Ballistic fab, ruff stuff, and genrite have some nice brackets and tabs for coilovers if your looking.
Sent from my PG86100 using Tapatalk 2
frankie945 is offline
