Rampage Sport Rack Fitment - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 09-05-2012, 07:50 PM Thread Starter
TXCAJN's Avatar
Rampage lists the product as fitting 07-10 but I can't see a reason why it wont fit a 2012. Does anyone have any insight or opinions?
2012 JKU Altitude
2014 Grand Cherokee Overland
TXCAJN is offline
post #2 of 20 Old 09-06-2012, 06:21 AM
BLKNGLD's Avatar
I loved my rack in my '07. Was disappointed to see it wasn't available for my '12.
Would also like to know if anyone has tried this rack on a '11 or newer.
BLKNGLD is offline
post #3 of 20 Old 09-06-2012, 10:56 AM Thread Starter
TXCAJN's Avatar
Fuck it...I emailed the mfg. ^^^I'll let you know what they say.
2012 JKU Altitude
TXCAJN is offline
post #4 of 20 Old 09-06-2012, 11:45 AM
I sent them an email last week and they responded saying it is in the works for the 2012...but did not say when.
Edmond is offline
post #5 of 20 Old 09-06-2012, 12:28 PM Thread Starter
TXCAJN's Avatar
Well that sucks......................thanks for chiming in though
2012 JKU Altitude
TXCAJN is offline
post #6 of 20 Old 09-06-2012, 06:29 PM Thread Starter
TXCAJN's Avatar
So here is the response from Rampage regarding the fitment of the rack on a 2012...
"Hey Ryan, the rack will fit fine if you do not have the factory sub woofer in the back, if by chance you have the speaker the rack will still work but you have to modify the brackets to fit it.
Basically you have shave off two little tabs on the brackets and redrill a hole to relocate the bracket up which in turn raises the rack about a ˝ inch clearing the speaker."
I ordered one and will confirm fitment after install.
2012 JKU Altitude
TXCAJN is offline
post #7 of 20 Old 09-07-2012, 07:02 AM
mschaffer66's Avatar
In my 07 the bracket was rubbing on the sub woofer. I just got it kinda lined up and cranked it down...it works.
The only thing I can say is that the whole thing seems to be a touch off center so one pin barely engages and the other seems too deep.
Wrap the pins with something where they slid through the rack or the rattle will quickly drive you insane. I found a small piece of hockey tape took care of it.
2007 Sahara Unlimited - Dana 60/14 Bolt - 5.38's with ARBs - 40x13.50x17 Goodyear MTRs - 3.5" Rock Krawler X Factor Plus - Rubi Rock Rails - XRC 10,000lb Winch
mschaffer66 is offline
post #8 of 20 Old 09-07-2012, 09:45 AM
Interesting,
I just found the reply they sent me...
"Thank you for your interest in our products. The current sport rack
does not fit in the 2011 and newer JK Wranglers due to the new interior
design made by Jeep. We are in the process of redesigning the rack so that
it does fit with the new interior set up. We hope to have the new rack
system available in the new few months."
Edmond is offline
post #9 of 20 Old 09-07-2012, 10:42 AM Thread Starter
TXCAJN's Avatar
Interesting,
Go figure...I'll let you know how it works out for me.
2012 JKU Altitude
TXCAJN is offline
post #10 of 20 Old 09-07-2012, 10:45 AM
http://www.amazon.com/Rampage-86617-.../dp/B00431PPDO
In case any of you guys are interested...
I also am a Prime member so I had that big bitch shipped next day for $4 extra.
post #11 of 20 Old 09-07-2012, 12:13 PM Thread Starter
TXCAJN's Avatar
Thats were I ordered from yesterday...definately the best available deal on that rack.
2012 JKU Altitude
TXCAJN is offline
post #12 of 20 Old 09-07-2012, 12:57 PM
Cool. I'm addicted to Amazon...
You will like the rack though. It's for sure not Poly quality...but it also isn't $600 either.
It feels a little cheap and the flip up "hinge"(two pieces of tube sleeved) doesn't seem like a great design. But I never really intended on the flipping up thing being something I use. I just wanted a rack that was meant to fit in the back of a JKU, Bestop is not, and that wasn't $600.
post #13 of 20 Old 09-07-2012, 01:25 PM Thread Starter
TXCAJN's Avatar
I agree...I may flip the thing up on rare occassion, but enough to be concerned about the hinge quality. I debated with myself over the Poly rack, but I couldnt get past the price..
2012 JKU Altitude
TXCAJN is offline
post #14 of 20 Old 09-07-2012, 10:20 PM
I got mine from Amazon as well and I think it was the same price. Though the sub-woofer in the back was too tall and the pin on the rack wouldn't engage, so I had to do some trimming and use a heat gun (on the sub) to make it fully engage/lock
SurfnSnow is offline
post #15 of 20 Old 09-15-2012, 06:24 AM
Just got mine in from Amazon and unfortunately it does NOT fit the 2012 jku. There is far to much plastic body molding in the rear "trunk" area of the jeep. The basket itself fits fine-the support brackets fit and there is no problems with space-but the latches need to be mounted to the roll bar ( small hole on 07-10 ) that is covered by the body trim. Not sure if how or if to start cutting the molding to access the roll are to mount is, but not worth it imho. I am going to keep the rack in hopes that the only the bracket gets modified- but this is highly doubtful. there are threads on this that go back to 2011 with rampage having an early fix ( spring 2012 ) and now that it is fall, i imagine the engineering is more difficult than thought.
robchad67 is offline
post #16 of 20 Old 09-15-2012, 05:49 PM Thread Starter
TXCAJN's Avatar
Well I went ahead and cut into the plastic molding and got the thing mounted. The driver side cut was pretty simple but the passenger side with sub woofer took some time.
I'll throw up some pics when I have time.
2012 JKU Altitude
TXCAJN is offline
post #17 of 20 Old 10-06-2012, 04:16 PM
2012 Jku with rampage sport rack
Well I got it installed on my 2012. This fits well in the trunk area and the only issue was the cutting of the body panels. If anyone wants the general measurements to cut into the plastic than removing the two side panels i will post them. The cutting went pretty easy with a drill hole and then a small blades hand jigsaw cutter. Finished up with a razor blade trimming a sliver at a time. I am going to caulk the area to make a cleaner look and will post more pictures when complete. Seems like a great buy- 192 shipped overnight from amazon. A little heavier than I thought it would be.
post #18 of 20 Old 10-06-2012, 04:18 PM
Little better look
Here is another view of the cut. Needs to be cleaned up a little.
post #19 of 20 Old 10-08-2012, 06:25 AM
Do these not fit a 2dr and can they be raised to clear a dust cover?
texasmike74 is offline
post #20 of 20 Old 10-08-2012, 07:01 AM Thread Starter
TXCAJN's Avatar
You'd have to do some fab work to raise this basket. Or you could buy some tube clamps and go that route...
2012 JKU Altitude
TXCAJN is offline
