OX Locker How It's Made series - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 09-02-2012, 02:38 PM Thread Starter
OX Off Road's Avatar
OX is doing a How it's Made series that you can follow at https://www.facebook.com/OXUSA . Give us your input of what you think. Below is an example of the beginning of the series.
Pictured below is the main part of the OX locker (the carrier). This is how we receive it from the forging company in nothern Ohio. It is loaded into a 6 axis cnc lathe with live tooling which is able to do the milling operations as well as turning in one process. This improves accuracy since no one has to touch the part.
The carrier is made of US forged alloy steel. We have it forged for the added strength, and the alloy we use is specifically chosen for it's strength and heat treat carictaristics.
OX lockers are the only lockers made of forged steel!!!
After 45 minutes on the machine here in Florida, the carrier has taken shape. It's now ready to go to Tampa to the heat treat facility.
OX Off Road is offline
post #2 of 3 Old 09-02-2012, 11:21 PM
Looking forward to more.
lamar95x4 is offline
post #3 of 3 Old 10-03-2012, 09:01 AM Thread Starter
How Its Made Series Part 2
Here the carriers can be seen going into the heat treat oven, the carrier is just one of many parts in the OX locker that goes thru this process. This particular part goes thru a heat treat process called carburization. Carburization is a process where carbon is infused into the surface of a part during heat treat. This allows the surface to become much harder than the core. The carrier is forged out of a specific type of steel whose characteristics allow the surface to be carburized to extreme hardness, at the same time the core is hardened, however not so hard as to become brittle. This is where the OX carrier gets it unmatched strength durability.
This is actually the prototype batch of Chrysler 8.25’s
Follow Us On Facebook www.facebook.com/oxusa
