Holy !7 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 08-25-2012, 03:33 PM Thread Starter
Holy $h!7
So I just finished getting alignment on my 08 unlimited rubicon with 3.5 RK max flex kit.
On the way home at about 35 mph I experienced the death wobble and thought I as going to die! The 37's were totally in control of the jeep and it sucked.
So now what should I do, return to alignment shop or "diagnose" death wobble myself?
And I have no clue what to do, nerves are a little on edge after this.....
2008 Unlimited Rubicon Black
RK 3.5 Max Travel:Fox Shocks:Fox Front Steering Stabilizer:Ace Front Stubby w/ Stinger:Ace Tubular Fenders:Ace Rear Bumper w/ Tire Carrier:Level 8 ZX Wheels:37-12.5-17 MTR-Kevlar:Engo 9K Winch:Currie Anti-Rock:Synthetic Winch Rope:6 panel sPOD:Rigid Lights:AEV Procal
1badjk is offline
post #2 of 8 Old 08-25-2012, 03:39 PM
Yeah, that'll scare the shit out of you for sure.
There's a million questions that help pin it down, but the fact that you just got an alignment makes me wonder if the trackbar's torqued to spec (120ftLb's IIRC). Make sure it's on level ground when you torque it down.
Plan Man has an entire thread devoted to this issue.
BTW, might want to move this into modified tech. Might get a better tech response to your issue.
Hope it works out soon.
Dancin Dan is offline
post #3 of 8 Old 08-25-2012, 03:57 PM
Daniel_M's Avatar
I doubt alignment will cause the death wobble as you described. Best bet is to check what Dan mentioned, your TB.
Planman is the man when it comes to diagnosing Death Wobble and non Death Wobble shimmies.
-Dan
2008 JK X: Sold
Daniel_M is offline
post #4 of 8 Old 08-25-2012, 03:58 PM
Change of toe can influence death wobble. I'd look at that..
post #5 of 8 Old 08-25-2012, 04:07 PM Thread Starter
I know for a fact that they adjusted the toe angle. If correcting the toe so that you can drive straight causes death wobble then what the hell do you do??
I am going to check into the above mentioned threads to try to get this nailed down ASAP!!
1badjk is offline
post #6 of 8 Old 08-25-2012, 04:11 PM
Toe, tell them to dial it in to planmans numbers, I believe it's 1/8th in.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #7 of 8 Old 08-25-2012, 06:35 PM
glomb23's Avatar
Everyone covered some things to look into pretty well. One question I have is are you still on stock balljoints, and how many miles on them if so? After the alignment did the tech that did it torque everything on the ground or in the air? Do you have the printout of the specs from after the alignment?
Greg
glomb23 is offline
post #8 of 8 Old 08-25-2012, 06:36 PM
So you can drive straight? Toe doesn't cause or correct any pull. Camber and Caster are the only angles that can cause pulls. The steering wheel is set straight via the drag link.
