What to do with used gears? - JKowners.com : Jeep Wrangler JK Forum
View Poll Results: What to do with used gears
Sell 'em 6 28.57%
Keep 'em 5 23.81%
Trash 'em 1 4.76%
Bacon 'em 9 42.86%
Voters: 21. You may not vote on this poll
post #1 of 14 Old 08-25-2012, 12:14 PM Thread Starter
hipkts008's Avatar
I just changed out my 4.10's to 4.88's.
What should I do with the old gears
09 JK 4Dr Rubicon
Zone Offroad 4" lift with 35" KM2
Superwinch LP8500 in ARB front bumper
And too FEW Lights!!
hipkts008 is offline
post #2 of 14 Old 08-25-2012, 12:20 PM
axsys's Avatar
-Play a challenging game of horseshoes
-Wear it as a crown
-Weld some flat steel to the bottom and make an ashtray
-Donate it to Goodwill
-Find another one instead of buying dumbbells
axsys is offline
post #3 of 14 Old 08-25-2012, 12:23 PM
StubEXrube's Avatar
I finally threw mine out after not being able to sell 'em.
I do have some 4:88's that I can hopefully sell, but it's def harder to get good money for 4:10's...jmo.
Pinion gears can be turned into pretty wild looking bump-stops too lol.
StubEXrube is offline
post #4 of 14 Old 08-25-2012, 12:26 PM
I'll probably tack the pinion to the ring gear and make garage art out of them or something. Old parts look cool on the wall.
post #5 of 14 Old 08-25-2012, 01:29 PM
bnb2010's Avatar
Use as trot line weights?
Bryan
bnb2010 is offline
post #6 of 14 Old 08-25-2012, 01:41 PM
BenFoo's Avatar
Give them to your neighbor that collects scrap metal.
BenFoo is offline
post #7 of 14 Old 08-25-2012, 02:54 PM
Looks like Goody beat me to it. Hang em on the wall in the garage. They look cool like that.
Dancin Dan is offline
post #8 of 14 Old 08-25-2012, 03:15 PM
Tight_wad's Avatar
I sold mine to a local car lot for 200! Their price offer, 50 over my asking price.
Tight_wad is offline
post #9 of 14 Old 08-25-2012, 04:00 PM
Daniel_M's Avatar
It will be tough to sell cause the front 4.10's won't fit a Sport or Sahara D30 up front and most other Rubicon's will most likely already be 4.10. Not much of a wide market to sell them.
Wall art or Ash Tray
-Dan
2008 JK X: Sold
Daniel_M is offline
post #10 of 14 Old 08-25-2012, 06:52 PM
ADDICTION II build begins....
TXROCK's Avatar
use them as custom shifters and brake handles!
U.S. Army
TXROCK is offline
post #11 of 14 Old 08-26-2012, 08:29 AM
Norm's Avatar
If you have a canopy tent they make cool looking weights. They are heavy enough to keep the tent down in the wind. All you have to do is paint and put a string on them.
STOMPER Off-Road
Norm is offline
post #12 of 14 Old 08-26-2012, 09:01 AM
Keep them as spares! Ive broke more then one ring in pinon while on wheeling trips and I never trailer my jeep. I know there not the same ratio as your front axle but at least youll be able to get your jeep back up and running. And you never know when youll be able to help out a fellow jeeper if they happen to break down.
HOT_DAMN is offline
post #13 of 14 Old 08-26-2012, 09:05 AM
Eh? I can't think of a situation where different ratios, trying to setup a gear set on the trail and wasting all that time would do you a whole lot of good.
I don't plan on carrying a shim kit or press for a pinion bearing, I suppose you could put one back on your stock pinion, but even then you couldn't estimate the proper shim for the pinion. You could completely lock up and destroy the "spare" set of gears by just pressing on a random pinion shim and trying to run it..
If your front gears went then, you'd just pull the axle shafts, drain the fluid and drive home. If the rear gears went you'd just knock off the ring gear [if you had to], pull the rear driveshaft and drive home with front wheel drive. Different ratios would completely remove the ability to reuse 4x4 on a trail. Either way you'd be able to get home with one axle.
I'll leave the 15#-20# of gears at home.
post #14 of 14 Old 08-26-2012, 09:28 AM
Story time:
Few years back I was in Hot springs AR. Broke my rear ring and pinion as well as my carrier and I drove there from Ft. Worth. Was able to pull a carrier out of an old Jeep Wagoneer, yes they will work in a jeep JK non rubicon, and a buddy had a spare 4.10 gear set. Went to a local shop in Hot springs had them pull the old bearings, put them on the new pinion and carrier and drove it all the way back home and then some. That gear set stayed in there for several months until I could afford to upgrade to 5.13s. Even then I kept the same carrier until I stripped the spider gears out.
I agree that the gear set up isnt going to be perfect, but sometimes you gotta do what you gotta do to get back home.
HOT_DAMN is offline
