Rock Hard Ultimate Sports cage... opinions and thoughts? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 29 Old 08-24-2012, 01:00 PM Thread Starter
damon.l's Avatar
after a good discussion here a couple of weeks back on cages id like to get opinions on this cage.
http://www.rockhard4x4.com/product_p/rh-1030.htm
with this...
http://www.rockhard4x4.com/product_p/rh-1030a.htm
i havnt read or heard anything bad about it, but it may not have the exposure that some of the other name brands have.
anyone have this one? thoughts, opinions?
damon.l is offline
post #2 of 29 Old 08-24-2012, 01:02 PM
little squirt's Avatar
I had their cage in my LJ and it was great. Will do one in my JK when funds come around after tires.
little squirt is offline
post #3 of 29 Old 08-24-2012, 01:11 PM
Since you asked for opinions, I'm pretty good for that. Whether or not it's worth anything is another story
My concerns.
I didn't like the all of the clamps everywhere, asethetically it looks a bit hokey. It also tying back into the stock door bars, where-as the OR-Fab replaces them. There is no option for a floor mount kit [OR-Fab], which also gives you a total of 10 3/8" fasteners in the pinch seam versus only 6.
Much like the OR-Fab they just claim that it is .120" 1-3/4" "tubing". No mention if it's DOM, or what kind of tubing it actually is.
Their welded joint here makes me nervous
For what is offered as kits for the JK, I think they would go in the order of Poly Performance, OR-Fab w/Floor Kit, Poison Spyder, Rock Hard/River Raider.
River Raider is down there because the entire front ties to the firewall. I'm not sure that's the best place but I also haven't looked into how strong that area actually is. I hope they have..
post #4 of 29 Old 08-24-2012, 01:13 PM
Wow, do not like that. What else is holding that bracket on other than those 3 bolts? Also, very short, thin weld. Also do not like.
Wangmuf is offline
post #5 of 29 Old 08-24-2012, 01:18 PM
2k2wranglerx's Avatar
mmmm self tappers
2k2wranglerx is offline
post #6 of 29 Old 08-24-2012, 01:20 PM Thread Starter
damon.l's Avatar
to my untrained eye i spotted all of that too. i didnt want to say anything and sway any opinions cause i may have been wrong and i find i get a more honest answer out of people if i dont give my opinion first.
imo this cage really doesnt do anything for a safety factor (again, to my untrained eye). its price is ok, but eh...
goody, on your previous suggestions i still like poly's, but there are a few of the bars placements i dont care for in the event of a high speed collision, namely the ones down by the drivers left leg and pass right. it may be no issue (again, untrained eyes) but to me it looks a bit dangerous.
damon.l is offline
post #7 of 29 Old 08-24-2012, 01:24 PM
mmmm self tappers
That's a valid argument for a couple of the cages.
However since they are in a sheer load situation, their method of threading isn't all as important. Sure it comes off as being very cheap, unsafe and a poor choice, but looking at their location, there isn't much of a benefit of through bolting them. Poison Spyder through bolts their streamers, so it has a bolt on the bottom of it. It's compressing an open rectangular channel, any vertical load at that point will just crumble the rectangle and loosen the fastener.
I'm not saying that I'm thrilled to have self tappers in my Jeep, but they are pretty functional.
post #8 of 29 Old 08-24-2012, 02:01 PM
TrailDuty.com
PhilD's Avatar
They are not self tappers, they are threaded, but as already mentioned it's not a big issue either way. The rectangular channel behind the bolts is not open, the RH piece has a filler on the inside, with threaded holes in that the bolts fit into. I have the RH cage and added a piece of 1/8" to the outside, so that the sheet metal is pretty well sandwiched between the RH piece and the 1/8".
You'd be surprised how much force it would take to rip them free, but they in no way compare to a proper floor mounted and braced to frame setup. I installed the RH cage in 2007 and I am surprised that they have not come out with an optional brace down to the floor by now.
The RH cage strengthens the factory cage and will help in a roll over, it may prove to be a one off use, but I have no doubt you'll be better off with it than without it. A complete new fully welded cage is obviously the best solution, then you have various options down from that until you get to the RH cage. All will be better than nothing, and in simple terms the more you are willing to spend the more you will get.
PhilD is offline
post #9 of 29 Old 08-24-2012, 02:04 PM
Poly has redesigned their kit so the a pillars go through the dash now! They should have a thread up here very soon about it. They are hoping for it to be available in about 2 months!
Sent from my C771 using Tapatalk 2
Minner is offline
post #10 of 29 Old 08-24-2012, 02:20 PM
TCdawg's Avatar
Very interesting! I'm looking forward to seeing this as the way their A pillar mounts to the floor now leaves a little to be desired...not in strength but aesthetics and room.
TC
TCdawg is offline
post #11 of 29 Old 08-24-2012, 02:26 PM
Ive been talking with them and it is a tube through the dash, will need to take you time for a clean instal and will have to relocate the factory speakers. You can see a glimpse of it on their rebuild of their 07 thread and they have been installing it on a 2012 4 door the past few days so look for a thread from them soon
Minner is offline
post #12 of 29 Old 08-24-2012, 04:33 PM
Guest
Poly has too much development going on right now... I dont see that happening in 2 months. Not talking down on Poly... just saying. If it does happen I will be looking like this guy ---> Either way if Poly makes it, I buy it thats just the way it goes.
XXXXXXXXXX4LCKD10RUBIUNLTD is offline
post #13 of 29 Old 08-24-2012, 04:38 PM
Its already been developed, they put it in their 07 and fitting it to a 2012 4 door right now. They told me if all goes well with the 2012 then it would go into production and could possibly take preorders in a month and ship in two
Minner is offline
post #14 of 29 Old 08-24-2012, 05:02 PM
HeloJeff's Avatar
Good to hear they are going through with the development of that cage. I really like that design better then the tube in front of the dash
HeloJeff is offline
post #15 of 29 Old 08-24-2012, 05:22 PM
Thisguyhasadd42's Avatar
looking forward to this, as I am in the market for a cage and Poly has impressed me the most so far.
2010 Mango 2dr 6spd Rubicon
Thisguyhasadd42 is offline
post #16 of 29 Old 08-24-2012, 05:26 PM
Ya I think they will have a lot of people interested, I plan on preordering mine when I can so hopefully I won't have to deal with backorders
Minner is offline
post #17 of 29 Old 08-24-2012, 07:48 PM
TCdawg's Avatar
X2
I was planning on doing a OR Fab front w Poly rear or just go full custom.
If Poly will be updating their design with a "through the dash" type A pillar, I'm in.
TC
TCdawg is offline
post #18 of 29 Old 08-25-2012, 06:37 AM
TCdawg's Avatar
do you have a link to this 2007 build thread? I can't seem to find it.
TC
TCdawg is offline
post #19 of 29 Old 08-25-2012, 06:40 AM
Give me a sec
Minner is offline
post #20 of 29 Old 08-25-2012, 06:42 AM
https://www.jkowners.com/forum/showthread.php?t=74851 Here you go, its toward the end of the thread.
Minner is offline
post #21 of 29 Old 08-25-2012, 06:49 AM
TCdawg's Avatar
Thanks! The only thing that has kept me from going with the Poly cage is the A Pillar down tube in front of the dash. I'm really hoping this new design is something that they will produce.
TC
TCdawg is offline
post #22 of 29 Old 08-25-2012, 06:52 AM
We should find out shortly how the instal went on the 2012 so lets cross our fingers that it went well
Minner is offline
post #23 of 29 Old 08-27-2012, 06:17 AM
spedly's Avatar
The dash sub structure is pretty much the same from 07-12 so it shouldn't be an issue with their through the dash cage. I didn't notice any read difference in sound loosing the small dash speakers either.
spedly is offline
post #24 of 29 Old 08-27-2012, 07:37 AM Thread Starter
damon.l's Avatar
it we are talking about loosing the tweaters in the dash, no biggie. just get a coaxial speaker and put it in the dash down underneath the steering wheel and glovebox.
if we are taking about moving the bigger speakers down in the dash, i think id rather keep the kit that doesnt do the through the dash design.
damon.l is offline
post #25 of 29 Old 08-27-2012, 10:52 AM
bthomas's Avatar
this x2
bthomas is offline
