High lift jack - JKowners.com : Jeep Wrangler JK Forum
post #1 of 28 Old 08-23-2012, 10:28 AM Thread Starter
High lift jack
Being the newb that I am, which high lift is best for jk with RK 3.5 lift?? I have found a 42", 48", and 60". Thanks for the help!!
2008 Unlimited Rubicon Black
RK 3.5 Max Travel:Fox Shocks:Fox Front Steering Stabilizer:Ace Front Stubby w/ Stinger:Ace Tubular Fenders:Ace Rear Bumper w/ Tire Carrier:Level 8 ZX Wheels:37-12.5-17 MTR-Kevlar:Engo 9K Winch:Currie Anti-Rock:Synthetic Winch Rope:6 panel sPOD:Rigid Lights:AEV Procal
1badjk is offline
post #2 of 28 Old 08-23-2012, 10:37 AM
If you have a place to store it, 60".
post #3 of 28 Old 08-23-2012, 10:37 AM
Where do you plan on mounting it?
post #4 of 28 Old 08-23-2012, 10:42 AM
BullyWagon's Avatar
48 is the usual choice. If you have a place to keep it a 60 will give you more lift.
BullyWagon is offline
post #5 of 28 Old 08-23-2012, 11:07 AM
BeerMonkeY's Avatar
like everyone said the 60 is the best death per inch but its tough to find a spot to carry it
'92 YJ
'13 WK2
BeerMonkeY is offline
post #6 of 28 Old 08-23-2012, 11:29 AM Thread Starter
I would like to figure a way out to mount it vertically on the back of the jeep. Other than that the only thing I know is across the hood
1badjk is offline
post #7 of 28 Old 08-23-2012, 11:31 AM
Vertically will hit every garage you ever drive into I bet. Across the hood would put a lot of the weight far from the mount to center the assembly on the hood.
Not many people run 60s, they're a pain to locate.
post #8 of 28 Old 08-23-2012, 11:31 AM
Gotlime?'s Avatar
48 will fit under the rear seat of an Unlimited.
Most I've seen mounted vertically extend past the roofline and in my opinion, that's just something to get hung up on if you wheel anywhere with "stuff" overhead.
08 Jeep Wrangler Unlimited Rubicon: lift, wheels/tires, bumpers, skids, sliders, winch, lights, cb. All the normal stuff, plus some.......
Build thread:
Gotlime? is offline
post #9 of 28 Old 08-23-2012, 12:59 PM
TG426's Avatar
maybe a tire carrier with a hilift mount that holds it on an angle?...for a 60"
personally, I have a 48" mounted to the RROR rollbar mount, needed something that kept it inside and worked with the ORH soft top (trek-top style) but I still have stock suspension.
Tom
2010 Wrangler Unlimited Sport
TG426 is offline
post #10 of 28 Old 08-23-2012, 01:15 PM
Smile Hi Lift Jack Mount
My 09 JKU Rubicon has a rear Smittybilt XRC bumper with a 2" receiver.
My son manufactured a "T" bar of 2" square tubing. My 48" jack is bolted to the upper side of the horizontal "T" bar and inserted into the 2" receiver. My jeep is lifted 3.5". It does not scrape at high angle approaches.
bigapplephx is offline
post #11 of 28 Old 08-23-2012, 01:18 PM
Gotlime?'s Avatar
My solution is the best one out there.
Build thread:
Gotlime? is offline
post #12 of 28 Old 08-23-2012, 07:24 PM
Abacabb's Avatar
I've never had any problems with the 48". I'd recommend getting the Lift-Mate with it.
Here's where I mounted mine... I made the mounts for both of them and never had a problem or heard them rattle.
2012 Jeep Wrangler - Gecko
3.5" Rock Krawler X Factor
Abacabb is offline
post #13 of 28 Old 08-23-2012, 07:27 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Keep telling yourself that!
https://www.jkowners.com/forum/showthread.php?t=68894
JKCTAZ is offline
post #14 of 28 Old 08-24-2012, 02:04 AM
I have a 60" on mine, just about maxed out the 48 every time I had to lift the jeep up.
Here's how I mounted mine
Thats a 48" in the pic, the 60 sticks up quit a bit over the top and like said before makes parking in just about any garage impossible.
HOT_DAMN is offline
post #15 of 28 Old 08-24-2012, 03:32 AM
levellinebrad's Avatar
I use a 60" and lay my rear seats down flat and carry it there. I rarely have any one riding in the back seats.
levellinebrad is offline
post #16 of 28 Old 08-24-2012, 04:28 AM
BeerMonkeY's Avatar
i hope you secure it with some straps, that will easily kill you or passengers in a accident
'92 YJ
'13 WK2
post #17 of 28 Old 08-24-2012, 04:37 AM
I have a 60" mounted on the hood! And I have a re 3.5" kit with 37's
Sent via your mom on a tricycle wearing a paper crown from Burger King
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42Ē MTR's
17" Spyderlock Beadlocks
post #18 of 28 Old 08-24-2012, 06:59 AM
Gotlime?'s Avatar
Originally Posted by JKCTAZ View Post
I like that.
I have a 2 kids and a GF so when we're out, space is at a premium. Your method would take away a little room behind the seats, which is valuable real estate in my world. I like your way though.
Build thread:
Gotlime? is offline
post #19 of 28 Old 08-24-2012, 07:06 AM
I like my Rock hard mount.
post #20 of 28 Old 08-24-2012, 07:36 AM
Fargin's Avatar
I've watched a highlift take out the back window of a Cherokee after an unexpected bump on a dirt road. Definitely tie it down.
Fargin is offline
post #21 of 28 Old 08-24-2012, 07:37 AM
It is strapped down.
post #22 of 28 Old 08-24-2012, 08:33 AM
Northernmedic's Avatar
I run mine under the rear seat. It fits great there and will not go anywhere in an accident. With the weather we have, I didn't want to run it outside of the jeep for it to get filled with crap and rust out. Whenever I need to use my hilift I run a chain around the axle to the frame. This works as a limiting strap (only shorter) and I have never had an issue with my 48".
Northernmedic is offline
post #23 of 28 Old 08-24-2012, 09:38 AM
dukabor's Avatar
That's a 60"...... they are pretty wide......
dukabor is offline
post #24 of 28 Old 08-24-2012, 12:23 PM
What bumper and tire carrier is that?
JeepNutt1983 is offline
post #25 of 28 Old 08-24-2012, 03:39 PM
Smittybilt XRC
Sent via paper airplane
