Pinch seam poll - JKowners.com : Jeep Wrangler JK Forum
View Poll Results: Better?
Bent pinch seam 4 6.25%
Cut Pinch seam 51 79.69%
aannd... BACON 9 14.06%
Voters: 64. You may not vote on this poll
post #1 of 26 Old 08-21-2012, 12:16 PM Thread Starter
Blackout's Avatar
Pinch seam poll
For you guys running flat fenders 35' tires and no lift .. what is the better way to go
How I LEARNED TO STOP GIVING A SHIT AND LOVE MINDLESS SELF INDULGENCE
Itís time to reevaluate the way we coddle the future generation. Making mistakes and getting hurt is how you grow. Teaching kids to fear Pop Tarts is how you promote xenophobia. Letís get it together, America.
Blackout is offline
post #2 of 26 Old 08-21-2012, 12:19 PM
unsub's Avatar
If your wheels come close to the pinch seam, cut it. If don't like the way it looks ,cut it.
Crew
unsub is offline
post #3 of 26 Old 08-21-2012, 12:23 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
Break out the sawzall, put in a new blade, cut pinch seam. Revel in your glory.
Or pull the tire off, hammer, try to make it look right, hammer some more, put the tire back on and have to cut off more and less cleanly than if you'd of just cut it off in the first place.
Cut it.
Marcus
RiverCityOffroad is offline
post #4 of 26 Old 08-21-2012, 12:26 PM
unsub's Avatar
Angle grinder for the win, throw some sparks!
Crew
unsub is offline
post #5 of 26 Old 08-21-2012, 12:31 PM
Abacabb's Avatar
This.
Also if your running 35' tires with no lift, pinch seams are the least of your worries.
2012 Jeep Wrangler - Gecko
3.5" Rock Krawler X Factor
Abacabb is offline
post #6 of 26 Old 08-21-2012, 12:50 PM
Why the hell is Chrysler still producing JK's with the pinch seem like this? WTF
'16 2dr Willys
'15 2dr Sport
ShafferNY is offline
post #7 of 26 Old 08-21-2012, 01:01 PM Thread Starter
Blackout's Avatar
Also a good question
Blackout is offline
post #8 of 26 Old 08-21-2012, 01:12 PM
unsub's Avatar
I talked to the designer of the JK in a bar and asked the same thing. He told me it would be a good spot to learn to cut painted steel, before you cut the hood to fix the air box problem with hydolocking your motor when you drive it like they do in the commercials.
Crew
unsub is offline
post #9 of 26 Old 08-21-2012, 01:30 PM
2010jk's Avatar
^^^^^^ Too funny.
2010jk is offline
post #10 of 26 Old 08-21-2012, 01:42 PM
How does it affect Chrysler? Would you think it's worth thousands of dollars to retool the tub manufacturing process to accommodate what people add after the fact? I have many other questions on "why", stupid pinch seam isn't one of them.
How about weak axle tubes? C-gussets? Top leaks? Plastic backed ball joints? 9/16" holes with 14mm fasteners in them? Weak-ass steering boxes?
post #11 of 26 Old 08-21-2012, 02:14 PM
TJDukit's Avatar
Do it right the first time and just cut away. It will look much cleaner in the end.
'09 JKUR. Metal Cloak overlines, TF 3" LA, 35" Nitto Trail Grapplers, Home built winch bumper, custom built sliders, RK Drag Link and HD Pro Tie rod, Adams front shaft, TF Big Brakes, Speed Bumps, Warn M8000
I.Y.A.A.Y.A.S.
TJDukit is offline
post #12 of 26 Old 08-21-2012, 02:35 PM
JCKnauer22's Avatar
Send a message via AIM to JCKnauer22
hit that bad boy with a cut off wheel and call it a day
I met a wild-eyed spinster on the back of a bus
She asked if there was any part of her I'd like to touch
When I told her "Yer nuts!" she got mad at me
And lectured on female anatomy...
JCKnauer22 is offline
post #13 of 26 Old 08-21-2012, 03:12 PM
FireTrail741's Avatar
Once you do it, you will see it is a no brainer! As long as you have all of your fingers when you are finished.
Saws all then angle grinder lightly to clean up the cut.
FireTrail741 is offline
post #14 of 26 Old 08-21-2012, 03:36 PM
bnb2010's Avatar
Cut it.
Marcus
Haha sounds like experience
Bryan
bnb2010 is offline
post #15 of 26 Old 08-21-2012, 05:08 PM
nc_fjizzle's Avatar
Cut it. It isn't hard to do.
ΣX
Order from River City Offroad
nc_fjizzle is offline
post #16 of 26 Old 08-21-2012, 05:17 PM
JKWolf's Avatar
Snip the Tip!
2008 JK 2dr
2.5" Rock Krawler System, 35" Goodyear Duratracs
BFH Front, Genright Aluminum Carrier
Originally Posted by SoCo_Fox View Post
I don't care whose fault it is, somebody is going to get a kick in the dick and a swat on the twat.
JKWolf is offline
post #17 of 26 Old 08-21-2012, 05:23 PM
Thisguyhasadd42's Avatar
Cut it! Takes about 5 min with a sharpie and sawsall
2010 Mango 2dr 6spd Rubicon
Thisguyhasadd42 is offline
post #18 of 26 Old 08-21-2012, 05:44 PM
maine07jk's Avatar
I agree this design makes no sense!
maine07jk is offline
post #19 of 26 Old 08-22-2012, 07:29 AM Thread Starter
Blackout's Avatar
Ok so what you guys are saying is I should bend it....
No really cut it is thats what i was thinking at the start but just wanted to check with the masses thanx all
Blackout is offline
post #20 of 26 Old 08-22-2012, 07:33 AM
maine07jk's Avatar
We in salt and winter crap worry about cutting anything and rust if you don't get it sealed back correctly.
post #21 of 26 Old 08-22-2012, 02:49 PM
ttechris's Avatar
I cut mine(takes about a minute a side and looks great.) After the cut I filled the slight gap with JB weld.
ttechris is offline
post #22 of 26 Old 08-22-2012, 02:52 PM
PhrogMech46's Avatar
I used a sawzall for the initial cut, then used a grinder to shape and clean the cut. I rattle canned it but I will be "sealing" it with epoxy and using Mopar touch up paint over it.
See Garage for Mods
PhrogMech46 is offline
post #23 of 26 Old 08-22-2012, 10:01 PM
JKO Dickhead
Asmmns's Avatar
Cut mine...sealed it up with some two part epoxy...then bed lined it !
__________________
CURE SMA !
Asmmns is offline
post #24 of 26 Old 08-22-2012, 11:19 PM
TJDukit's Avatar
So where are the comments from the guys voting to bend it. I want to see their input on why they think it is better. Not that it would have ever changed my mind. Cutting it is better.
I.Y.A.A.Y.A.S.
TJDukit is offline
post #25 of 26 Old 08-23-2012, 05:56 AM
damon.l's Avatar
def cut. i wish i had something better than a hacksaw when i did mine, but alas its all i had and it did the job. its not pretty but i dont worry about my tires.
damon.l is offline
