JK wrangler tire question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 08-18-2012, 02:17 PM Thread Starter
Question JK wrangler tire question
Very new to Jeeps so please bare with me....
I have a 10' Wrangler Unlimited Rubicon and interested in the Mickey Thompson Sidebiters 17x9. Want tires that pop out a bit and look aggressive. Any recommendations on the tire brand and size that I should go with? I don't off road much and need wheels good for snow. I'm also not lifting the car. THANKS!
Yuchi is offline
post #2 of 16 Old 08-18-2012, 02:25 PM
pyrophil's Avatar
first of all it's not a car it's a JEEP 2nd you will prob only be able to run a 32" tire 3rd welcome to the forum
pyrophil is offline
post #3 of 16 Old 08-18-2012, 02:36 PM
pooch's Avatar
well if u dont off road much then i would stick with the stock tires. the stock tires r really good in the snow, just not so much in the thick sand. haha.. by the way welcome to JKO
My Road starts where the pavement ends
Pooch
08 X Black 6 speed
pooch is offline
post #4 of 16 Old 08-26-2012, 11:37 AM Thread Starter
Would I be able to fit BFGoodrich Mud Terrain T/A KM2 285/75/17??
Yuchi is offline
post #5 of 16 Old 08-26-2012, 11:47 AM
JerseyDevil's Avatar
Haha. I said I wasn't lifting mine either. Good luck with that. Welcome to JKO
JerseyDevil is offline
post #6 of 16 Old 08-26-2012, 11:57 AM Thread Starter
lol are you saying in time I will want to lift my car or I need to lift my car for those tires?
Yuchi is offline
post #7 of 16 Old 08-26-2012, 12:11 PM
I am thinking 285/75 is about a 33 or a little larger than a 33. You could probably fit those but would likely see some rubbing some times.
Oh and welcome to the forum.
jchurch is offline
post #8 of 16 Old 08-26-2012, 12:18 PM
Not sure what kind of car you have, but this is a JEEP forum.
God murders a kitten every time you refer to a Jeep as a car.
32" tires on stock rims are about as large as you'll be able to go without additional modification.
Stock rims are 8" wide, IIRC so you'll need to take the wider rim into account and remove the air dam/plastic skid under the front bumper to avoid rubbing. Another easy mod could be wheel adapters for about $200 (less if you buy used) to avoid touching steering components under full steering wheel lock.
Check the backspacing on your wheels as well.
Dancin Dan is offline
post #9 of 16 Old 08-26-2012, 01:01 PM
bnb2010's Avatar
Don't say that, you may give someone a new hobby
Bryan
bnb2010 is offline
post #10 of 16 Old 08-26-2012, 01:08 PM
285/75/17 will need wheel spacers and 1 or 2 inches of bump stops to keep them from rubbing on your fenders when bottomed out. You won't have much travel without a small lift. 285/70/17 will be easier.
CM
F200 is offline
post #11 of 16 Old 08-26-2012, 04:56 PM
levellinebrad's Avatar
2 kittens in one thread. That's just sad
levellinebrad is offline
post #12 of 16 Old 08-27-2012, 09:25 AM Thread Starter
Sorry guys, like I said this is my first JEEP. Not used to saying that...
Would 265/70/17 be a better fit?
Yuchi is offline
post #13 of 16 Old 08-27-2012, 11:37 AM
In That class which is the correct size(32") check out the Wrangler Duratrac 265/70-17
Radsyn is offline
post #14 of 16 Old 08-27-2012, 11:48 AM
Gotlime?'s Avatar
This thread made makes my head hurt.
08 Jeep Wrangler Unlimited Rubicon: lift, wheels/tires, bumpers, skids, sliders, winch, lights, cb. All the normal stuff, plus some.......
Build thread:
Gotlime? is offline
post #15 of 16 Old 08-27-2012, 11:59 AM
angrysam's Avatar
285/70/R17 will be fine. I think the rims you are looking at have 4.5" backspacing? I 285/70R17 on 17x9 with -12 offset (about 4.5" backspacing). The only time I've ever rubbed was the plastic skid/air dam on really tight turns with a wheel slightly-fully stuffed. It's very minor and nothing some trimming won't fix.
You'll wish you'd went taller though. Just saying....
Lord, give me patience. I'm afraid that if you give me strength I'll need bail money too.
angrysam is offline
post #16 of 16 Old 08-27-2012, 03:20 PM
RookieJK's Avatar
aftermarket wheels with 4 inch backspacing and 33s will fit just fine for the mall.
Jersey
Crew
RookieJK is offline
