CB Antenna meet Parking Garage - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 08-18-2012, 10:31 AM Thread Starter
So I was making a quick entry to the parking garage at our local hospital, my mind was on something else and my foot was on the accelerator. So long story short I really blasted my 4 foot firestik off the garage steel beams. Lost the little plastic tip cover. Biggest concern at this point is did I do other damage to the tip and what is the best way to check it without incurring damage to my radio.
Anyone know where I can get a replacement antenna tip cover? I am in the northeast and we dont have truck stops around.
2011 JKU Rubi
3.5' RK X Factor - Rock Monsters w/ 35" BFG KM2
Poison Spyder Brawler F&R + Evap + LightBar
sPod, PowerTank, Rigid 50" LED
deker9 is offline
post #2 of 16 Old 08-18-2012, 10:55 AM
2 pack from rightchannelradios.com
2010 Rescue Green JKUR
-37” Pit Bulls / Raceline beadlocks
-RJ60 rear / 5.38's / Detroit
-Rubi 44 front / sleeved and trussed / RCV's
-PSC hydro assist / Synergy TR & Drag Link
yerfttam is offline
post #3 of 16 Old 08-18-2012, 10:56 AM
You can also get an SWR meter there...might not be a bad idea to check the tuning after that...
yerfttam is offline
post #4 of 16 Old 08-19-2012, 12:42 AM
b1pig's Avatar
if youre radio has no SWR meter on it... the only real option would be to check it with a meter. i did the same thing to a fiberglass antenna made the same as most firestiks. mine worked fine without the rubbery cap on it and the top 2" of wire pulled off the top of the fiberglass stick. i left it alone and ran it that way for years.
b1pig is offline
post #5 of 16 Old 08-19-2012, 08:21 AM Thread Starter
Thanks b1pig I have a SWR which I can check it with. When you run it without the cap dont the tree branches catch the adjustment screw and change it?
2011 JKU Rubi
deker9 is offline
post #6 of 16 Old 08-19-2012, 09:21 PM
b1pig's Avatar
the one i had didn't have an adjustment screw...
in that case...
what verftam said... or..
http://www.ebay.com/itm/2-5-Black-Fi...#ht_2319wt_825
b1pig is offline
post #7 of 16 Old 08-20-2012, 12:53 AM
FrostByte's Avatar
I did the same thing awhile back, but mine broke at the other end where it screws into the base. I ended up buying one of the springs in the link below after getting a new Firestik II. I have since talked to several people who have done the same thing forgetting it was attached when driving into the garage.
http://www.firestik.com/Catalog/SS-3M.htm
Active Duty U.S. Air Force
1983 º||||||º Present
FrostByte is offline
post #8 of 16 Old 08-20-2012, 06:48 AM
Gotlime?'s Avatar
Quick release and a Firefly. The Firefly is more flexible and I only have the antenna on when I intend to use the CB. Otherwise it sits in the back of the Jeep.
08 Jeep Wrangler Unlimited Rubicon: lift, wheels/tires, bumpers, skids, sliders, winch, lights, cb. All the normal stuff, plus some.......
Build thread:
Gotlime? is offline
post #9 of 16 Old 08-20-2012, 07:05 AM
illyb's Avatar
Also look at getting a spring mount if you don't already have one. There are numerous places online to order one. I have a Firestik SS-3H mount in addition to a quick release mount. I've been really happy with my setup. Not only does it protect your antenna against parking garages, it help minimize stress to your mount by trees/limbs/etc you encounter on the trail.
http://www.amazon.com/Firestik-SS-3H...b+radio+spring
illyb is offline
post #10 of 16 Old 08-20-2012, 07:21 AM
Tail Rated's Avatar
another option is to skip the spring mount and put a quick disconnect on it. The quick disco will allow you to keep that antenna inside the truck do so those parking garages or thieves don't get at it.
Firestick (K1A) works nicely. Than use a couple of velcro strap (or dog collars) to keep your antenna accross the rollbar inside your Jeep.
...at least that's what I do.
2016 JKU
Tail Rated is offline
post #11 of 16 Old 08-20-2012, 07:35 AM
Chuck Bullitt's Avatar
I'm on my 5th or 6th antenna due to things like this. Now I just keep it off until I'm on the trails.
Chuck
2009 JK Unlimited X, mostly stock with a K&N filter.
Chuck Bullitt is offline
post #12 of 16 Old 08-20-2012, 07:41 AM
Tanimal's Avatar
Lol..
Tanimal is offline
post #13 of 16 Old 08-20-2012, 07:52 AM
Definitely look into the firefly if you don't want to have a quick disco. I've smacked this firefly on trees, garage doors, those parking garage height marking bars and no issue. I just look back and watch the thing swing back and forth. It's flexible enough to take a beating but strong enough to stand up straight while driving.
Sent from my Epic 4G Touch using Tapatalk 2
BigManAndy is offline
post #14 of 16 Old 08-20-2012, 07:58 AM
Gotlime?'s Avatar
Like I said I use the Firefly, but the Wilson Flex is a better (more flexible) antenna in my opinion. I just haven't been able to find a 3' one.
Build thread:
Gotlime? is offline
post #15 of 16 Old 08-20-2012, 08:46 AM
jeep-n-it's Avatar
i just installed the wilson flex for a friend over the weekend .. he got some package deal from right channel radios..
but they have that antenna.. tuned up great and it is much more flexible than my firestik and spring..
Shawn
jeep-n-it is offline
post #16 of 16 Old 09-08-2012, 10:59 AM Thread Starter
My antenna is behind my spare tire. Will a spring mount even do anything? Seems like the tire would prevent appropriate bending while striking those darn parking garages.
2011 JKU Rubi
deker9 is offline
