AEV brake booster pump relocation bracket - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 08-17-2012, 11:45 AM Thread Starter
Does anyone know if AEV sells this bracket seperate from their bumper. Only answer I was able to get from calling AEV was a round about "it comes with the AEV front bumper...."
Ron
"Some people spend an entire lifetime wondering if they made a difference in the world.
But the Marines don't have that problem." ..... Ronald Reagan
wanderingtrail is offline
post #2 of 2 Old 12-24-2012, 07:54 AM
You are in luck. I just installed a ARB winch bumper on my new '13 JK and faced the same challenge. Fo a temporary fix, removed the unit from the frame bracket and just pried up the first arm. This allowed clearance and preliminary installation of the bumper. I used the back bracket arm to swing the unit back far enough to clear the 9k winch, then used a very heavy duty tie wrap to secure the buster unit, while still using the back mount bolt as the anchor point. This is only a temp fit, and was planning to fabricate an alternative after returning from our family Xmas trip.
With a little research I found a alternative at Rough Country. Here is the Rough Country solution to the problem and installation guide.
http://roughcountry.com/install/1043.pdf
You can order it from ebay at the following store: Billisticjeep, cost less than $20 bucks including shipping.
http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
Good luck.. :-D
muddy-ru is offline
