does this tire carrier exist yet? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 08-15-2012, 06:44 PM Thread Starter
Question does this tire carrier exist yet?
is there a tire carrier for the JK similar to the GenRight Boulder for the TJ?
http://www.genright.com/ProductInfo....ductid=RTC3X40
At 26 I have already had one pretty good back injury and I like the idea of not having to lift and position 150lbs of tire/wheel onto a swing out carrier.
Wojin is offline
post #2 of 19 Old 08-15-2012, 06:46 PM
smuggler bumper
beedle4 is offline
post #3 of 19 Old 08-15-2012, 06:55 PM Thread Starter
seen it, too bulky, going to have an extra 20 gallon tank underneath and i dont want the full width wrap around. gotta watch my figure, cant have too much junk in the trunk
Wojin is offline
post #4 of 19 Old 08-15-2012, 09:17 PM
Abacabb's Avatar
I'm not even sure if they make them anymore, but River Raider Offroad had one.
2012 Jeep Wrangler - Gecko
3.5" Rock Krawler X Factor
Abacabb is offline
post #5 of 19 Old 08-16-2012, 04:42 AM Thread Starter
that is what i am looking for, sadly it is no longer on their site. may just have to ask my local shop to fab one(no welder skills here) or graft a TJ one onto a JK bumper
Wojin is offline
post #6 of 19 Old 08-16-2012, 06:34 AM
ALASHA's Avatar
The reason no one makes this is because the JK has SIGNIFICANTLY more body flex than the TJ does. There would need to be just too much play to allow for the difference in flex between the body and frame.
Your best option would be to get an HD Customs swing DOWN tire carrier but they are currently on hiatus. You may be able to find some used ones though. I think this one might still be available:
https://www.jkowners.com/forum/showthread.php?t=66738
ALASHA is offline
post #7 of 19 Old 08-16-2012, 08:07 AM Thread Starter
I plan on having a full cage tied into the frame, wouldn't this negate the difference in flex?
Wojin is offline
post #8 of 19 Old 08-16-2012, 08:10 AM
Administrator
HITMONEY's Avatar
Tell me why you would want a drop down spare vs a swing away setup?
°lllll°
Facebook Page
YouTube Channel
HITMONEY is offline
post #9 of 19 Old 08-16-2012, 08:10 AM
ALASHA's Avatar
The issue is the body mounts and how much difference in flex they allow. If you are going to have a cage tied into the frame, I would make sure there is ample room for the body to flex around it.
Unless you plan to solid mount the body to the frame and be the guinea pig for what that will do to your JK, you will always have an issue between the different amounts of flex.
ALASHA is offline
post #10 of 19 Old 08-16-2012, 08:14 AM
Chuck Bullitt's Avatar
Wasn't Poison Spyder testing their swingdown tire carrier on their JK?
Chuck
2009 JK Unlimited X, mostly stock with a K&N filter.
Chuck Bullitt is offline
post #11 of 19 Old 08-16-2012, 08:16 AM
ALASHA's Avatar
yeah and I think they stopped because of what they saw during testing. Please correct me if I am wrong
ALASHA is offline
post #12 of 19 Old 08-16-2012, 08:17 AM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
That's right Alasha - it was bending the rear corners.
RiverCityOffroad is offline
post #13 of 19 Old 08-16-2012, 11:10 AM
Good to know. I was almost tempted to grab their TJ carrier and fab it to work with my JK. Ended up with the Genright carrier.
Chuck
post #14 of 19 Old 08-16-2012, 11:19 AM
I'd imagine it's nicer because you've got a greater likelihood of sliding off ledges instead of hanging up and torquing the spare tire. At least thats why I built one for my YJ. Glad I read this post so I didn't build one for my JK. Too bad, I like that style too.
'96 Dodge 2500 12v
'15 JKU-R
RFR2212 is offline
post #15 of 19 Old 08-16-2012, 01:01 PM
More like ripping the PSC corner armor in into two pieces.
Semper Fi
highoctane is offline
post #16 of 19 Old 08-16-2012, 01:40 PM
Administrator
HITMONEY's Avatar
There are swing away ones that have the same caged design feature and still allow access to the rear without lowering a 100+ pound tire to the ground every time and then have to lift it back up.. I have just never understood this design as a practical solution.
°lllll°
Facebook Page
YouTube Channel
HITMONEY is offline
post #17 of 19 Old 08-16-2012, 02:09 PM
illyb's Avatar
I believe the River Raider guys can fab you one. It ties to mounts they weld to their crusher corners. Check their Sledgehammer build for pics of the carrier and corners.
illyb is offline
post #18 of 19 Old 08-17-2012, 06:24 PM
Why dont you just get one like the psc and instead of attaching the other two mounting points to the corner armor, instead, just weld those two points to the rear bumper as well... I have considered doing this. Yes, you would have to cut the existing arms off and relocate them... shouldn't be too much of a problem.
To clarify, yes, all four attachment points would be on the rear bumper, (2 ,on, say the top or side of the bumper, and the other two in the regular position) It would have to be a thicker bumper though, but I dont see why that wouldn't work.
jneal91 is offline
post #19 of 19 Old 08-17-2012, 06:30 PM
While that's true, the swing aways you mention (and on your Jeep) transfer 100% of that weight to the body/armor mounts. If you drop off a ledge and it catches on the tire, that's all in the body or armor. They look great, are super functional and I do like them.
However, with the older YJ/TJ style, it'll transfer the load to the bumper(and frame) and body/armor. Also I'd believe the load to be less, as there is no drop off a ledge from the bumper to tire (shock load), but a glide from the bumper to tire carrier.
I'm no engineer. But I'd run one of two things. Tire in the jeep and no hang over the bumper or a GenRight YJ/TJ style carrier to let the rear end slide over ledges.
I've seen several jeeps run a setup in the hitch mount that is a square tube that sticks out to slide off rocks and deflects contact from the tire. I think it works, but it's not what I want on my Jeep.
You're right, you're picking up a heavy spare and this style tips down in front of the tailgate and is in the way. On my 2dr I don't need that much access to the 'cargo' area. I'm glad I read this thread about flex issues. I'd have built my own carrier but seeing this, I don't know that I will.
Not the best photo, but my YJ has metalcloak corners and i built this carrier on to whatever tube bumper was on there when i bought the jeep. I haven't completely loaded the rear end of the Jeep on the carrier, but it's plenty strong (and heavy.)
'96 Dodge 2500 12v
'15 JKU-R
RFR2212 is offline
